Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 03-06-2006, 02:36 PM   #1
Boost Gauge
I wanted to either find for purchase, or design and build, a boost gauge for my car, so rather than having a gauge sit somewhere on the dash, I could have the readout on my screen.
I know Phidgets has a PSIG meter which you can use with an API setup. Does anyone else know of other solutions or somewhere to purchase something pre-made?
I just need 0-20psi.
Willow is offline   Reply With Quote
Old 03-06-2006, 03:39 PM   #2
Tainted Love
Cris's Avatar
Why not use OBDII?
Cris is offline   Reply With Quote
Old 03-06-2006, 03:47 PM   #3
archimense's Avatar
You can't get boost pressure through ODBII. You would need a proprietary protocol that is car specific to be able to read boost.
Jetta Install Photos
Audi S4 Worklog
01' Audi S4 Twin Turbo / 00' VW Jetta VR6.
archimense is offline   Reply With Quote
Old 03-06-2006, 04:01 PM   #4
Daley's Avatar
I think I'd personally go with the Phidgits option. You'd need to build yourself a front-end for it, but at least you wouldn't have to worry about drivers and all that.
BTW, what kinda car? Being a gear-head, I'm just curious.
To find your favorite restaurants in Houston, check out http://www.thehubgrub.com.
If it's not fun, you're not doing it right!
Daley is offline   Reply With Quote
Old 03-06-2006, 04:48 PM   #5
2005 GTO CGM-M6
Can't use OBDII for the reason he said above, plus, the car doesn't come stock with any boost devices
Old 03-06-2006, 05:17 PM   #6
MySQL Error
Scouse Monkey's Avatar
you could use a regular boost gauge and have a shaft encoder on it to the PC. Or look for a pressure transducer. quite easy really but the former is easier to calibrate in a way.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 03-06-2006, 05:21 PM   #7
MySQL Error
scott_fx's Avatar
the gauge wouldnt be able to turn a shaft encoder
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 03-10-2006, 06:45 PM   #8
Stonewall78's Avatar
Take this article from Audi world and work from there http://www.audiworld.com/tech/elec94.shtml
Also boost data via OBDII is going to be way to slow to be useful.
Stonewall78 is offline   Reply With Quote
Old 03-10-2006, 06:54 PM   #9
MySQL Error
yes it would. i bet you.
optical ones have no drag.
Old 03-11-2006, 02:57 AM   #10
MySQL Error
scott_fx's Avatar
i didnt even think about an optical encoder. you are correct sir!
M10k
My Car Pc Install
Old 03-11-2006, 05:59 AM   #11
MySQL Error
hehe wanna know a secret....me neither at 1st...had to think to get myself out of that one!
Old 03-11-2006, 09:22 AM   #12
MySQL Error
scott_fx's Avatar
ha.. ok, well since we are getting all 'dr phil' over here and being honest... i never even heard of an optical encoder until you posted it and i did a search :-) they are pretty cool... now how can i use one in my setup! :-)
M10k
My Car Pc Install
Old 03-11-2006, 10:00 AM   #13
MySQL Error
haha love it.
the other option is a pressure transducer. Honeywell do some with RS232 interfaces but all you need is to interpret the signal - probably resistance which you can do with most I/O boards, phidgets, joystick port etc etc
hell you could always take the optical enocder out of a mouse scroll wheel or off the ball and use that!!!!
Old 03-11-2006, 02:16 PM   #14
Raw Wave
Might as well use a pressure sensor such as MPX4250AP, changing output voltage with pressure, cost about $20.
Amplify the voltage (if needed) and send the measured pressure to PC, use serial or USB, easily done with PIC MCUs.
http://www.vpv-motorracing.com/MPX4250AP.pdf
Chris31 is offline   Reply With Quote
Old 03-11-2006, 02:20 PM   #15
Raw Wave
Opps
He want premade
Ignore my last post
Any Gauge Face Creation Ideas? xhazn Fabrication 14 05-18-2005 09:09 AM
Best way to connect 8 gauge wire to 12-16 gauge wire? SwapMeet Car Audio 22 03-09-2005 11:27 AM
Mounting motherboard in WRX gauge pod housing.. Giuliano General Hardware Discussion 0 07-19-2004 10:01 AM
WRX owners. Clock or Boost Pod Gauge area. Center channel Speaker. LESLIEx317537 General Hardware Discussion 5 04-02-2004 05:37 PM
question about relays and high gauge wires Heedunk General MP3Car Discussion 12 05-10-2001 12:13 PM
