Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 05-01-2006, 11:02 AM   #151
Genesisfactor is on a distinguished road
that's true, but i'm talking about everything else that's not made to look like the Northern lights, like subte details. I dunno, Its important to me to be able to see into other cars or read detials like the liscene plate.
yea, i keep forgetting yoru lens has fisheye, so it gives that FatF/2F2F nitrus hyperspeed look. Still is a great daytime video.
Also, my computer lags on some of yoru divix clips and i ahve no idea why. Its a 2.0P4 with 768 Ram and plays most games well. I would be certian it owuld have no problem with yoru clips, and i know i have the newest codecs. Possible soltuoins? I'll just re-dl and reinstall the codecs forow and hope it fixes it
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Genesisfactor is offline   Reply With Quote
Old 05-01-2006, 11:45 AM   #152
TomG's Avatar
TomG is on a distinguished road
its probably washed out because of the way the camera meters. Even a center weighting would still have some of the dash in view which is a lot darker than the sky outside so it is overexposing, I wouldn't have thought there would be a way round it short of actually having the camera outside so it doesn't see anything other than you want it to meter for.
btw, the videos lag on mine too, in that, they each pause a couple of times when playing back. I have a P4 2.6 Northwood HT and a gig of dual channel PC3200 so I doubt its my machine...
www.gallery.meh.me.uk
TEAM SESQ
TomG is offline   Reply With Quote
Old 05-01-2006, 12:01 PM   #153
Raw Wave
shotgunefx's Avatar
shotgunefx is on a distinguished road
I also get the lag, thought it was my machine
It's funny, I tried upgrading today after doing these, then every video encoded after that was frigging upside down so I had to uninstall it and go back to the previous version.
I'll have to try screwing some more with the dsp features, though they didn't seem to do much last time around to improve the situation.
As far as the compensating, there's got to be something else to it. With different lenses, it does a much better job of compensating. I can aim it at a bright light and see the element. Maybe it's a combination of the low F and the wide lens. The other ones I've tried that fare better are more narrow to various degrees.
For instance, one that adjusts from F-1.5 to 16 fairs slightly better than the wide angle F1.6 even at F-1.5. At about 2,it's close to perfect.
In all the experiments in the house, I never had that washed out effect ever. Even aiming a red laser at it, some of the surrounding scene could be seen with good composition (unless you hit it dead center and then the whole thing was white/red), maybe it was a voltage problem for the camera or the lilliput. In the first videos, the camera was hooked up to the camcorder at all times. The last, to the screen. Though I was driving around with just the screen at first with no problems.
shotgunefx is offline   Reply With Quote
Old 05-01-2006, 02:28 PM   #154
spaceskater's Avatar
spaceskater is on a distinguished road
I've been really busy with the finals but I got some time in the weekend to play around.
@shotgunefx I think your problem in a combination of the wide angle and the windshield-dashboard reflecting light back to the camera. In all the tests I did when I had the camera mounted inside it gave me a lot of problems espatially with washing out.
I mounted the camera in the front grill (see photos) and it compensates very well for light changes. Unfortunately I have no way to capture video yet since I have no capture card.
About the HUD: I've been playing around with some Fresnel lenses and some polarizing filter. With the polarizing filter results are amazing in terms of picture clarity BUT it really restricts your view to the outside! I also found that if you magnify the image enough the light is diffused and the second image due to the double reflection is barely visible thus you don't need the polarizer.
About the HUD photos. First is no magnification, second is one lenses, third is two lenses. With two lenses the double image is minimal but the photos are not that clear, camera could not focus. ALSO using two lenses the image was focused further away in the distance.
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
spaceskater is offline   Reply With Quote
Old 05-01-2006, 03:23 PM   #155
so fresnel is all we need? what about the your image, is that off a nitemax LCD or another one?
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Old 05-01-2006, 03:33 PM   #156
Yes that is the NiteMax LCD. Well the negative part is that you need some space above the lcd. Like the first lens in 2 inches second at 5. Total 5
Old 05-01-2006, 05:41 PM   #157
so you successully completed the vga mod? or is that composite? what do you mean space? for displaying the image?
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Old 05-01-2006, 07:30 PM   #158
nope it's composit. But it is very sharp. 640 x 480. I didn't get the chance to play with the vga input. I am to busy with finals so I am hopping some of the other guys will figure that out
About the space, you need some distance between the lcd and the Fresnel lenses otherwise they will not magnify the image. That means that the LCD has to be deep in the dash if possible with the lenses on top.
Old 05-01-2006, 10:48 PM   #159
gah, i only have s-video and VGA outs...looks like i' stuck with VGA till further notices as i dont' want to mess with the S-Vid out yet. Now i need a video capture card with Composite out as well just to plau with this cause now i want to.
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Old 05-01-2006, 10:55 PM   #160
I only have s-video out too but one of the components of s video is composite video. It is extremely easy to get composite from s-video. Radioshack sells that cable too. if u want to make it yous self check out this place:http://www.tkk.fi/Misc/Electronics/c...eo2cvideo.html
Old 05-01-2006, 11:00 PM   #161
billforde is on a distinguished road
What about a svideo to composite adapter. Cheaper than ati's
My Jeep Liberty Install
billforde is offline   Reply With Quote
Old 05-01-2006, 11:08 PM   #162
oooo...now i just need to figure out a way to get $5 and i'm golden! thanks man!
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Old 05-02-2006, 12:00 AM   #163
NiteMax Mark's Avatar
NiteMax Mark is on a distinguished road
The Sanyo chip on the NiteMax LCD Controller is made to accept S-Video. If the board itself carries these signals out to the world, you'll be able to feed it S-Video directly and you're done.
I will try to find the time to look at the details and post instructions on getting S-Video to work directly without any adapters!
NiteMax Mark is offline   Reply With Quote
Old 05-02-2006, 01:18 AM   #164
That would be great!! It would increase the quality of the picture too! Not VGA but good enough! Once again thanks so much Mark!
Old 05-02-2006, 05:33 AM   #165
Raw Wave
shotgunefx's Avatar
spaceskater
I'll verify tomorrow or the next day, but pretty sure it's the lilliput and not the camera causing the white out. All those videos were shot only minutes before. I think when I plugged in the cam to the lilliput it glitched it. Easy enough to verify.
The other thing I need to do is put the cam on regulated voltage.
For the in car testing, I'm just running it to the ACC socket. I know with some of the cheaper cmos cameras, the picture brightness varies somewhat with voltage. Maybe the same here?
For the polarizing film, did you use it as the display or just lay it over the lilliput? The privacy film I use is sort of like a polarizer, but with a somewhat wide angle. When I layed it over the lcd itself, the double reflection was just about gone.
Did some night driving and it's raining like crazy. Even if the light can be compensated, polarizing I don't think will be a bad idea. You can see that wet ground reflects a lot and hides detail (lane markings for one).
I encoded these at a lower rate. The pause is gone, but obviously, the quality isn't as good. In particular, when it's dark. No IR illumination in any of these.
Front Camera vid-1 9271 KB
Front Camera vid-2 3968 KB
This one's a little interesting. One, it shows how the camera distorts. That's a somewhat tight spot, but you'd never know it.
The other is the flickering light, denoted by the arrow. If you watch the vid, there's this light just flickering (not to the eye of course, just the camera). I think when I pull out, it's at least somewhat my headlights, but before when I'm not moving... dunno.
Not sure of the cause, but as the car pulls up to it, it becomes a massive glow.
Front Camera vid-3 5708 KB
Headlights off briefly, fairly dark road
Front Camera vid-4 2737 KB
PROJECT: 2004 Xterra Carputer elgenyo Fabrication 9 06-01-2007 04:23 PM
VW Golf mk3 - carputer project Sh0cker Show off your project 43 12-09-2005 10:14 AM
My Carputer Project, need advice natesimpson74 General Hardware Discussion 1 09-21-2005 01:14 AM
My carputer project: Solaslim nthai Show off your project 57 10-28-2003 03:43 PM
New CarPuter Project: Need Input! Tremek General Hardware Discussion 12 01-31-2002 03:07 AM
