Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 05-10-2006, 09:46 AM   #211
Custommx3's Avatar
Check this...
http://www.kollsman.com/company/news/pr_11152005.asp
They are comming to my work to display this according to a co worker. I was invited to the demonstration and will try and take pics and post them.
Hes going to call them soon to setup a demo, but there is no deffinative date as of yet.
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
Old 05-10-2006, 06:37 PM   #212
Raw Wave
shotgunefx's Avatar
Quote: Originally Posted by Custommx3
Check this...
Looks a little big for a dash, but nice.
shotgunefx is offline   Reply With Quote
Old 05-11-2006, 08:53 PM   #213
My man uses Levitra.
Peoples's Avatar
neat looking at this stuff
http://www.el-op.com/default.asp?cat...EB41669D20C%7D
i always thought they had transparent LCD overlays, i didnt realize all huds were projected
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 05-13-2006, 02:20 AM   #214
Custommx3's Avatar
What about something like this?
http://www.apollodisplays.com/ArtistaUSB.php
or this
http://www.brilliancorp.com/PDF/N2E/..._CEK_BR_E2.pdf
2007 Mazdaspeed 6
Old 05-13-2006, 05:28 AM   #215
sama's Avatar
nice find! easy to get multple display this way. I wonder how much video a usb bus can handle before it slows down
///Mputer - Velocity - TomTom - Vision - Bezel - CarPC
sama is offline   Reply With Quote
Old 05-13-2006, 10:15 PM   #216
Hey mark or shotgun, have either of you figured out how to get S-Vid to work or should i stick to RCA? I'm about to take apart one of the cameras just to see it work
Also, mark, i'm getting inconsistent powerons off the car adapter. What could be causing that? When it works, it works great, when it doesn't it doesn't. The sad thing is that the image it produces is alot cleaer than my eyes can see...and the nitemax has been a very useful Ops tool
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Genesisfactor is offline   Reply With Quote
Old 05-14-2006, 03:05 AM   #217
Raw Wave
shotgunefx's Avatar
Haven't spent any time on it as of late. Honestly, at that resolution, I don't know if you'd see any big difference from Composite vs VGA.
I did order any auto-iris lens to hook up the the Ultra Color CCD. Hopefully that will help with the night shots.
Old 05-15-2006, 01:53 AM   #218
Raw Wave
shotgunefx's Avatar
Found some cheap TV projection lenses at
Electronics Goldmine
Figured they were worth a shot for $5. I'll let you know what's what when they arrive.
Old 05-17-2006, 03:10 AM   #219
Raw Wave
shotgunefx's Avatar
Alright, so I'm waiting on my new lens with auto-iris to come.
Then I remember that giant compustar lens I have. I went to hook it up and apparently had the wrong datasheet. This lens has it's own iris circuitry built in instead of the camera driving the iris directly. So you feed it power and video and adjust the knob to determine compensation (anywhere between peak and average intensity.)
What a difference. Here's two short (~500k) videos showing the iris turning on. This lense is F1.2 so the blinding effects are even more noticable than with the other cams. As you can see, the pics with the iris fully open are fairly useless. As an aside, the lamp is not that bright, those bulbs are only 15w.
vid 1
vid 2
So if the iris of the new lens being driven by the camera is similar, then that and a polarizer should be a giant improvment.
update
As an aside, when I was testing this earlier looking outside, I shut off all the lights (to kill the reflection on the window) and while toggling the iris, a alligator clip came loose and shorted something. Only I didn't know it.
In short order, the picture went out, then in the dark I saw little blue sparks and then the wires start to burn. I fumbled for the plug in the dark and yanked.
My camcorder was unscathed, but judging by the smell and scorch mark on the board of the nitemax, figured the nitemax, and probably the electronics of the auto-iris lens were toast.
Everything survived , let's hear it for good engineering.
Old 05-17-2006, 03:20 AM   #220
lol don't you hate it when little aligator clips slide off.
Silentbob343 is offline   Reply With Quote
Old 05-17-2006, 03:39 AM   #221
MySQL Error
Scouse Monkey's Avatar
not up to speed with this thread yet but wanted to say:
1. good stuff guys...i have been doing a HU disply on the glass infront of my speedo etc. It is only 1" high so the curvature does not cause a problem. However i have to use a mirror on the bottom and relfect back up so I might try using a thin sheet set at an angle behind the glass instead.
2. Be careful with LCDs left pointing up at your windshield in sunlight as the UV will destroy the lcd panel over time. i was planning on having my nav screen pop up out of the dash but might experiment with a hud style.
also...i need a ****ing nitmax camera...or something similar any suggestions/links?
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 05-17-2006, 06:32 AM   #222
Raw Wave
shotgunefx's Avatar
As far as the cameras, I think Mark still has a lot of the Nitemax components. The only thing he doesn't have is the power supply board, but that's easy enough to get around.
For instance, all the vids I've been posting, it's just one of the Nitemax Ultra color CCDs
Old 05-24-2006, 12:43 PM   #223
Raw Wave
shotgunefx's Avatar
Finally got those projection tv lenses from Electronics Goldmine today.
Pretty sweet for $5 a piece. I grabbed two (in case I want to make a projection tv.)
They're pretty big, I think it's a triplet lens. But not so big that it would be impossible to fit in a car.
So as a test, I took my camcorder (which has a screen the same size as the nitemax) and went into a dim (not totally dark room).
Even with the puny lcd backlight on the camera, easily could project it to about 15-20" image on the wall from under two feet away
Old 05-24-2006, 01:17 PM   #224
Raw Wave
shotgunefx's Avatar
A few pics...
The lens. Appears to have a polarized coating on it.
Now for the following shots, keep this is mind, the lcd is on a tripod, but the lens and camera are hand held. With no flash, the long exposure and my shaky hands, very hard to get a half decent picture. Also I'm projecting it onto a bumpy, flat-coat painted wall.
This is the lcd projected to about the size of a 32" TV. Keep in mind too, it's just the ****ty lcd led backlight illuminiating the LCD
Old 05-24-2006, 01:39 PM   #225
i have $5...time to go shopping! How much plus shipping?
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
PROJECT: 2004 Xterra Carputer elgenyo Fabrication 9 06-01-2007 03:23 PM
VW Golf mk3 - carputer project Sh0cker Show off your project 43 12-09-2005 09:14 AM
My Carputer Project, need advice natesimpson74 General Hardware Discussion 1 09-21-2005 12:14 AM
My carputer project: Solaslim nthai Show off your project 57 10-28-2003 02:43 PM
New CarPuter Project: Need Input! Tremek General Hardware Discussion 12 01-31-2002 02:07 AM
