Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 06-03-2006, 11:15 AM   #256
For now, you don't, He's out of town. I forgot when he said he'd be back. Sorry! Hehe, apparently, i took a page out of his book and was out of contact almost all week:P...
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Genesisfactor is offline   Reply With Quote
Old 06-03-2006, 02:11 PM   #257
spaceskater's Avatar
@shotgunefx How is the auto iris lens working? does it compensate for the glare of other cars lights in the night? Could you share the pinout BTW. I think I will order one very soon. The glare is really killing me at night.
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
spaceskater is offline   Reply With Quote
Old 06-03-2006, 02:24 PM   #258
Raw Wave
shotgunefx's Avatar
It was working fine, haven't put it in the car yet.
Rather I was going to, but I broke one of the wires, no big deal, but I can't find my molex KK pins amongst all my crap.
I'm digging for them now so I can install it and take some vid tonight.
In testing in the house, the iris worked pretty well. I'm just hoping it doesn't dim it to much on the street. I don't think it will as unlike my test, the headlight won't be trained on the lens.
The pinout on the camera side for the DC Iris is in the main nightmax thread here.
The lens comes with a sheet that tells you what pins are what.
You have one of the UltraCCDs correct? The regular nitemax board is different. Not even sure if it can drive an iris lens.
shotgunefx is offline   Reply With Quote
Old 06-03-2006, 03:26 PM   #259
Raw Wave
shotgunefx's Avatar
I'm about to say **** it.
I find my molex tool and crimp pins and as I'm about to do the last one, one of the wires soldered to the board breaks.
I'm not soldering these again. They solder pads are so friggin close together (~0.015") under the header and my hands shake like a freaking vibrator.
[img]http://www.leeland.net/lib/leeland/****ingccd2.jpg[/img]
I'd try another CCD with the header intact and those picoblade crimps I ordered, but no they ******* disappeared.
Just had to vent.
Old 06-04-2006, 01:45 AM   #260
I hear you brother I always have moments like those when messing with projects. Whether working on my car, gun, or some sort of electronics it never fails, something stupid happens and makes me want to take a hammer to it. Keep with it though, and it'll work out in the end. You've done some great work so far and now you need to put it all together.
Silentbob343 is offline   Reply With Quote
Old 06-04-2006, 02:40 AM   #261
Raw Wave
shotgunefx's Avatar
Yeah, just really aggravated. I hit that a lot, with most things.
It got worse. So as I start to solder the wires to the pads, I find the crimps. Great!, these things are miniscule. You drop one and it's just gone.
[img]http://www.leeland.net/lib/leeland/****ccd3.jpg[/img]
My little pliers were gargantuan for the task. 3 of them went pretty easy, of course the 4th one was a ***** for some reason (always a catch).
So I mount them in the socket, put little nibs of plastic between the pins to keep them from touching and glue the **** out of it.
I go to hook it up and realize, like an idiot, I glued it into the wrong 4 header post. $#$@!*$#@!*!@#!!
So I decided to call it a night and head to the bar. Feel much better now
Old 06-04-2006, 02:46 AM   #262
It got worse. So as I start to solder the wires to the pads, I find the crimps. Great!, these things are miniscule. You drop one and it's just gone. My little pliers were gargantuan for the task. 3 of them went pretty easy, of course the 4th one was a ***** for some reason (always a catch).
Glad your feeling better, sometimes you just need to step away and forget about it for a bit.
Old 06-04-2006, 05:10 PM   #263
Raw Wave
shotgunefx's Avatar
Ok,
So tried again today. *****ing ridiculous. After ten times, I could not repeat me success at getting the tiny crimps on.
So I went to try and solder them, but pretty much impossible a second time due to residue from the first, etc.
I tried wirewrapping. Not enough room, but I wrapped it onto a header pin, then backed it off a bit and removed it from the regular header and carefully placed it over the pico header. Almost worked but I could keep all four on to secure it, one would always slide off.
After a rampage or two, I had an idea. I have a ton of molex SL connectors. They are similar but much bigger. The opening is narrower than a KK crimp, but still a lot bigger than the picoblade crimps.
So I attached some crimps with some heatshrink over that (to keep the pins from touching when placed on the board) and then used a pair of pliers to make the opening a slit. Worked perfect.
Then I doused the pins on the board in hot glue so they won't slide off or short. The camera is working fine (except it appears the lens or CCD now has some dirt embedded which results in some small spots in the picture).
I'm going to try and clean them up and should have some video tonight.
Old 06-04-2006, 05:42 PM   #264
Great news. Looking forward to the video, put the new Merc. S class in it's place .
Old 06-04-2006, 08:01 PM   #265
Raw Wave
shotgunefx's Avatar
Well, there's good news and bad.
I'm starting to think a proper HUD isn't going to be workable. Not a projected one anyway.
In doing some tests, the lens itself is highly visible on the collimnator. Much more so then the actually projected image.
All the aftermarket huds you see are just basically LCDs or VFDs reflected off the windsheild.
That's fine for "gauges". You have to refocus your eyes, but it's no different then traditional gauges as you have to look down and refocus.
But for something like a video feed that your going to look at a lot, I think it's got to be focused at or near infinity to not be a dangerous distraction. How you can project an image like that, without having the projector itself reflecting as well, I have no idea.
I'm not saying it's not possible, just probably too hard for most of us. Any optics experts around here?
Old 06-04-2006, 09:05 PM   #266
hmmm, the new Merc has LCD screen in the dash behind the steering wheel that displays the gauges, speedo etc, and is replaced with a video feed from the camera when NV is turned on.
In-Car H.U.D Video, interesting concept displays on a different piece of glass like in planes. He did a "How To" for a UK computer mag as well:
http://www.jasonbradbury.com/jason_b...d_video_1.html
"He gives you the whole design on the video, really.
Piece of plastic held over a TFT or whatever at a 45 degree angle. You want to be sure you use proper sizes, etc. Based on the video, it's a CD player case, so about 13cm to the side. Based on that the screen should be around a 3"x5" or so(7.62cmx13cm or whatever, perhaps smaller).What you could do is recess it into your dash, run the cabling, and then build a mounting bracket above the screen, maybe with a protractor to insure 45 degrees. 45 degrees is good because one quarter of the light goes through, one quarter straight back at the display and one half straight at you. Great design mate! I'm American but I would like to buy you a pint because you have clarified how to do it so well."
The Cadillac system was projected on to the windhshield, do you happen to know what method/materials they used?
http://www.marlow.com/Applications/D...ion_system.htm
http://www.cardomain.com/ride/2071139
Here is a guy who owned an 01 DTS with night vision. He removed the system to put in a custom mesh grill. Perhaps he has some knowledge of how the image was projected on to the windshield.
In my searches an article kept popping up from a 1998 erdition of Advanced Imaging magazine, but they were all pay to download links. Don't know if it would have anything relevant to help with the HUD problem.
http://www.powells.com/cgi-bin/bibli...2-1595951059-0
Haven't found any specifics..."The other part of the package is a Head-Up Display (HUD) projector, mounted in the instrument panel behind the steering wheel. It takes aim at a small, half-mirrored section of the windshield just below the driver's main line of sight."
"The display
http://autoweb.drive.com.au/cms/A_50...wsarticle.html
"an active matrix liquid crystal display IJIJD (head up display).
The head-up display (HUD) is integrated into the dash in front of the driver. The HUD projects a virtual image near the front edge of the hood having a horizontal field of view of 11 degrees and a vertical field of view of 4 degrees. The image-to-object ratio remains at about one-to-one. Keeping the image near life-size helped the driver related objects in the HUD image with objects in the forward road scene. It also helps the driver judge the distance to an object.
A HUD helps allow the driver to maintain head and eye positions to view the road and the display simultaneously. The HiUD, producing a virtual image, has the advantage of providing an image that is at far-field focus and, therefore, does not require the driver to refocus his eyes as the eyes move to the display and returns to the driving scene."
List of display technologies:
http://bg.advancedimagingmag.com/buy...atCodeParam=09
Thin sheet optic+holographic diffuser, really neat PDF something ford did with the Navy for better night vision systems. Clearly shows the advancements made from the Cadillac system:
http://www.onr.navy.mil/about/confer...nning_gwot.pdf
How GM is doing their HUD display actually in between the glass:
http://www.dupont.com/safetyglass/en...ts/hud_gm.html
Tein's concept and I just thought they did shocks, ahh VSD is really just a "super bright" VFD:
http://www.tein.com/defi/vsd_top.html
Old 06-04-2006, 10:08 PM   #267
Raw Wave
shotgunefx's Avatar
The Bradbury take is easy but problematic.
He's just having it reflect off a piece of plastic. The problem is that if you want to superimpose graphics over the road as opposed to just reflecting it, you need to focus the image. Otherwise, to look at the display, the road ahead will be out of focus to your eyes. It would be really no different than having an lcd sticking out of your dash and looking at that.
For this route, I'd forget about the 2.5" lcd and look at a PSOne 5" screen.
I don't think it's impossible by any means to correctly project it, but the more I read, the more it looks like there's going to be a lot of heavy lifting as far as optically designing something which is certainly over my head.
Here's some more links that have tidbits on the caddy system.
http://www.jkllamps.com/caseStudies/...seFamily&id=31
http://www.sbir.com/target_projectors.htm#custom
http://www2.dupont.com/Automotive/en...s/case178.html
If you look at the first pic on the carrier you linked to, you can see the tiny little projector at the bottom of the hud glass. It appears to be projected straight forward. With the constraints of the dashboard, most of us are going to need to have the image source in the dash and reflected off the collimnator. I think this is were it gets tough.
Though now that I think about it, I had a sony camcorder that broke but I took the parts off it before I tossed it. It has a minutare lcd in the eyepiece, probably about the same size as a regular CCD camera. If I could figure out how to drive it, I could probably just use it like a camera in reverse and project it forward using an adjustable Cs-mount lens. Hmmm
BTW, here's a good link on aircraft huds.
http://www.ausairpower.net/TE-Fighter-Cockpits.html
Old 06-04-2006, 10:30 PM   #268
Raw Wave
shotgunefx's Avatar
Here's a pic of the camera board with the SL connectors for the IRIS.
Here's the sony cam's mini lcd I was talking about.
Old 06-04-2006, 11:59 PM   #269
That looks like an interesting solution, it will be a mini LCD projector.
Old 06-05-2006, 12:19 AM   #270
Raw Wave
shotgunefx's Avatar
It almost looks like a CRT, but I'm not sure. The package is fairly long and the tube it's in is basically a wire wrap. I believe there was a sticker on the inside that said something about "X-Rays" when I opened it the first time
PROJECT: 2004 Xterra Carputer elgenyo Fabrication 9 06-01-2007 04:23 PM
VW Golf mk3 - carputer project Sh0cker Show off your project 43 12-09-2005 10:14 AM
My Carputer Project, need advice natesimpson74 General Hardware Discussion 1 09-21-2005 01:14 AM
My carputer project: Solaslim nthai Show off your project 57 10-28-2003 03:43 PM
New CarPuter Project: Need Input! Tremek General Hardware Discussion 12 01-31-2002 03:07 AM
