08-02-2006, 10:09 AM
#361
whose lcd will you be using, if it's Mark's, he might help you out with technical power wiring information.
getting a signal from pc, would be vga to s-video converter , link was in the previous post.
Personally if you want to find out yourself, i yjink you should hook up some AA batteries with multimeter, i woundn't recommed though
Yev
R. T. F. M
08-02-2006, 10:14 AM
#362
haha mark and i are in decently close contact. he's a great guy. RCA is the source for the LCDs. Wee tried VGA and then S-vid is theory, but at 640x480, rca is viable and native, so therefore easiest. I need an Svid to RCA adapter for it to do dual monitor on my R51. The LCD requires a 12V at i forget how many ohm power supply without the PCB. there was a site i saw with some really cheap prices on wires and adapters for video; i have to find it again.
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
08-02-2006, 11:11 AM
#363
Raw Wave
Quote: Originally Posted by Genesisfactor
visibility was never a probem, it was getting rid o a double image produc by hte glass. e we going to try andsee if polarizin the light wld do it, but shotun never got arond to it. I'mgoing to step up in a bitand try it, i just have to figure out how to power y LCD and then get an image on it from the computer.
Are we talking about projecting the lcd or reflecting it?
If it's the later, I was too concerned
http://www.mp3car.com/vbulletin/show...9&postcount=65
If it's projecting it so it's larger, that's a whole nother ball of wax. I think the easier solution might be a bigger lcd and just reflecting it.
I haven't abandoned working on this, just too buy with other projects, like the front end.
08-02-2006, 04:07 PM
#364
i'm actually thinking about trying both. See, when i was researching micro displays, such as those found in projection TVs, i found that the resolution is really low by computer standards, but the picture came out great on the TV. I'm wondering if, using the NM LCD, i can increase the size of the screen without buying a larger LCD with more res that we actually need. I mean, all in all, even when we do get ti working, the most resolution hogging thing i will need it for is a divx movie. Why watch it at a ~1:1 reflected scale with the LCD when you can do 3-5:1 with a magnified reflection. Ofcourse with magnification, light intesity is sacrificed, so yes, we'd have to technically project it using, hopefully usinjg LEDs. But even if its an extra few steps, it will make the HUD far more daylight visible than what i used to get and therefore end the restriction to night time use as solely a nightvision device.
Yev's link, and i'll edit it in later, used a TV wiht a 2.5" lcd with pretty decent results for <$60 worth of work and supplies (not sure if that included the old TV). LEDs are cheap and well...yeah. After that's done, then its back to the old double image problem, then getting a few visual settings done right, comptuer wise, and then we're golden.
And i get you on having other projects, i'm working wiht AIVMS and Media Portal. Both have PPC remote controls built in. Hopelly sama and lost will make some headway in the computer vision stuff when they regain focus on that. I have a few ideas, but we can only handle like, i dunno, 10 projects at a time, i mean geez, we're not superman  . What are you working on, out of curiousity?
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
08-02-2006, 04:29 PM
#365
nice well don't count on me i just hit 2000.00 limit on my credit card with this set up
http://forums.vwvortex.com/zerothread?id=2709993
Yev
R. T. F. M
08-02-2006, 04:37 PM
#366
lol, ouch, dude, what are you building!? THat thing sounds like it's going to be hot. i've done that a few times (hit my liquid asset limits). If i figure anything out and come up wiht a design, i'll TRY to put it together in inventor that way you don't have to spend the moeny with R&D. Just keep it coming with the help and suggestions, which have been really good thus far.
***after reading link*** IM or email me, i have some cheap suggestings for a few of your "pending" items. It doesnt' seme like it adds up to 2gs, but hey, math is one of my weak points right now.
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
08-02-2006, 05:45 PM
#367
Raw Wave
You can definitely project it in theory, I had mine just with the backlight and a pitch-blackk room, an 8ft screen. Very, very dim of course. Though projection takes lenses, light and room.
Though think of the other problem with projection, you need to be careful that sunlight isn't going to be spot focused on the screen or the lcd.
What have I been working on?
I snagged some leather Katzkins off ebay dirt frigging cheap, so trying to finish up redoing the leather.
Trying to polish my front-end
Working on the digital dash
This just got a lot more interesting and complicated. They finally made headway in cracking my ECU. So I'm going to ditch the ELM (and the software) and focus on this. Why? With the new cable I can read the ECU directly as well as tune and reflash. Not only can I get a ton more info than normally available (and maybe even operate my switches via pc), but the update rate goes from a paltry 10-15hz to over 200hz
And about 15 minutes ago, I won $450 in the lottery, so I'm off to order the cable and some things for another project, going to try a poor man's transflective for my lilli
08-02-2006, 05:53 PM
#368
well total car renovation, the speakers, custom sub, and center console, and pc of course
here is what i am thinking,
R. T. F. M
08-02-2006, 05:56 PM
#369
congrats on winnings
Yev
R. T. F. M
08-02-2006, 06:00 PM
#370
Raw Wave
Don't think that will quite work. One, the lcd will be like an ant under a magnifying glass around noon, but the bigger problem is the reflection.
With that setup, you'll see the light source.
Try this test. Take a piece of glass (or clear plastic) and angle it in front of you like the HUD would be.
Now use a flashlight as the "projector". Not only will you see the projected "image" from the flashlight, but you'll also see the flashlight's reflection itself and it will be much brighter than the projected image.
I think the trick that needs to be done is to oriented the setup as such so that the reflection of the projector is angled as such so it's not in your line of sight normally.
08-02-2006, 06:06 PM
#371
windshield design is a big issue as well not all the caes have the similar, in may car it's pretty even, with limited curve at the place it would project, but of course it's a trial and error thing.
Yev
R. T. F. M
08-02-2006, 06:16 PM
#372
Raw Wave
Yev
It definitely factors in, but you should seriously try that simple test to see what I mean. I tried dozens of things so far and it's tough (that's why it ain't done yet  )
In your pic, what side are you on, and I'm assuming you want the mirror to reflect the image?
08-02-2006, 07:06 PM
#373
correct.
i am still debating on this one, what;s unique about persicope design, you could focus, and adjust the image in many ways
cons
lens and a sun may detroy lcd as you have metioned
i have to look how big of a cavity i can create to place it in
i can't make any conclusons due to lack of real experiments
Yev
R. T. F. M
08-03-2006, 07:31 AM
#374
This landed on my desk at work this morning. Anyone want me to look at anything specific??
08-03-2006, 10:26 AM
#375
can you photo copy it cover to cover
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
| Thread Tools |
| Display Modes |
Linear Mode
