Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 08-12-2006, 01:53 PM   #406
Quote: Originally Posted by alpha_maverick View Post
that being MY worklog...
...and linked to in my sig...
I think its a well written piece of work on a promising idea that is only not executed due to the loss of the car. The individual has some interesting ideas on a modular design and news to get ovver his accident induced ADHD and other newfound cognitive disorders to get his act together and finish his HUD, get the voice control on the AI and HTPC and PPC working properly, get the UI right
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Genesisfactor is offline   Reply With Quote
Old 08-12-2006, 02:48 PM   #407
sorry, wrong link. I feel like an idiot. I am using Linux, so I just middle-clicked, thinking that this was the last thing I had highlighted.
in it, it says it uses 50/50 reflective combiner. I am pretty sure that this is the only way to get rid of the ghost image.
in order to get it to focus at some arbitrary distance, I believe that 3 lenses are required. set the assembly focal point to near the drivers head (after reflection) and fine tune it to get the apparent distance you want.
I am in the process of a motor swap, so I do not have the funds to attempt this right now, but I am fairly certain that it will work.
alpha_maverick is offline   Reply With Quote
Old 08-12-2006, 03:52 PM   #408
That is defintiely more interesting than your last link . dont' worry we all make mistakes. If you can research this 50/50 combiner, that would be cool!
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Old 08-12-2006, 04:10 PM   #409
Raw Wave
shotgunefx's Avatar
I don't think it's just a 50/50 "two way" mirror (which I'm planning to buy for experimenting btw), they use it for teleprompters, and samples are available on ebay cheap. I think under 10 bucks. Just search for "two way mirror" and you'll find the seller.
A few problems I see with the type of pictured system, it's big, in a passenger car, would most likely be a big hazard to someone's skull mounted on the ceiling.
You'll also have what amounts to a extremely bright flashlight shooting out of the windshield. Not a problem for the military, but for street use, I think it would get you lot's of unwanted attention.
I really think the only way you can project a hud on a budget (as opposed to reflecting one, which isn't such a bad idea and it's easy) is to oriented it such that the light source isn't viewable from your position, (ie from near the bottom) but then you have to worry about the image being distorted.
Though that would be an easier thing to work around. You'd basically have to scale the scanlines smaller as you reached the top of the screen. But at least the transorm is linear and there are plenty of optimized algorithims for scaling scanline "textures". I'm certain almost all gpus are optimized for this nowadays.
If you were using something like OpenGL or D3D, you could just paint the image frame on a plane and tilt it away from you.
shotgunefx is offline   Reply With Quote
Old 08-12-2006, 04:28 PM   #410
a combiner is the same as a beamsplitter. 50/50 means that 1/2 is reflected and half is allowed to pass through. some are directional, meaning that from one direction, nothing (not much) is reflected, but from the other side, it's half and half. http://www.edmundoptics.com/onlineca...productid=2035
Reflected and projected are the same thing!!!! you are not focusing the image on the plate! you focus it on your retina (or near it)! you align the optics to reflect the light so that it is (relatively) square to your eye-level and adjust the focus so that the image appears at the end of the hood, etc. kinda like the focus knob of binoculars.
GTG, more later
Old 08-12-2006, 04:52 PM   #411
Raw Wave
shotgunefx's Avatar
GTG, more later
If you read up on some of the combiners in use, in particular the military stuff, they aren't simple planes, often they are curved and laser etched, ie, way way out of our league.
I understand that projected and reflected light are the same, the difference I'm getting at, if you lay an LCD on your dashboard, you'll see the LCD on the windsheild, pretty much focused. Yes light is emitted and that's what you're seeing, but what you are seeing is the source, so there is nothing to get rid of.
If you project the image onto the glass from behind you or (anywhere close to it), you will see the reflection of the projection source itself. There's the rub. Light is light, I don't see how you can make the emitter disappear and not what's emitted. I think the best you can do (on the hobbyist level) is get it out of the field of view.
All the huds I've seen that are on cars are basically VFDs or similar, your not seeing it projected through a lens so to speak, it looks like they are just reflected off a window.
Old 08-12-2006, 09:01 PM   #412
if you look at the bottom of the beamsplitter page I linked to, there is a plate that would be approximately the appropriate size for our application, and it is flat. I was proposing what others were: hide the display assembly in the dash. Something that just came to me: Why could we not use a small sheet of privacy glass to guard the expensive LCD and lenses? put the privacy glass on the dash as a dust/light cover for the lense and LCD, and put the LCD/lense assembly latterally across the inside of the dashboard.
what you are seeing as "reflected" is just an unmodified focal length (distance from eye to glass+distance from glass to LCD) The lense assembly allows you to extend your focal length beyond the glass, out to infinity.
would that not work? I know it would be large at first, but as "we" progressed (I will not be able to assist, except with the theory of stuff), the package would get progressively smaller.
Old 08-12-2006, 10:27 PM   #413
Yevmeister's Avatar
sounds interesting, the only things is how would privacy screen protect the lcd, when at some point sun would beam, though the lens on lcd,
Yev
R. T. F. M
Yevmeister is offline   Reply With Quote
Old 08-12-2006, 10:42 PM   #414
when you shut the car off, the privacy glass would turn off, going translucent, keeping (most of) the light from getting to the lense aray, and burning the LCD. When driving in direct sunlight... wait... is there a way to have an electronically adjusted tint, like on new cars interior rear-view mirrors? What about a light diode/check valve? Nevermind on that one. Perhaps it would be better to just put some sort of fans on the LCD, to prevent it from overheating, like on projectors, and just ignore teh privacy glass.
side note: only half of the sunlight will reach the lense/LCD array, the other half will be largely cancelled out by the AR coating on the back of the plate, since it was supposed to be reflected away (forward).
To bypass these needs, you would have to project from above, rather than below. That doesn't work for most of us, though.
Old 08-12-2006, 10:50 PM   #415
Yevmeister's Avatar
gotcha, well the fans are a must no matter what, if you will use a projection source
Yev
R. T. F. M
Old 08-12-2006, 10:59 PM   #416
Yevmeister's Avatar
like i have stated in my previous post, you can also have a flip holoscreen, with rear view projections
R. T. F. M
Old 08-12-2006, 11:05 PM   #417
Tint adjustmetn is done by slightly shift polarized elements i beleive. I knwo what your'e talking about, but no, now thngs are getting too "hi tech". A simple motoized cover, PIC, and a photocell will do the trick quite nicely. See, the sun is a major reason why i DON'T want to use magnification. I would rather do a reflection, but in all honesty, with a 2.5" LCD, i have no choice. The one thing i'm still wondering is how to fit al the elements in the top cover of my gauge cluster. THe LCD would be hard enough, but a magnifying system...
Anyways, lost in thought, alpha, listen, i will not say it won't work, nor will i say its impractical, nor challenge you in any way. This is a real find. But i woudl ask that you come up with something for us. lol, not a working prototype, but, as its been said before, we need all the minds on this as we can get. i want to see your findings in yrou research, even if you ar short on cash. maybe you can guide us/me. .
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Old 08-13-2006, 12:09 AM   #418
Raw Wave
shotgunefx's Avatar
The problem I see is that you will see the light source as well as the projected image. Regardless if the beam is split. If half of the image is directed towards you and half away from you, I still think you'll have the same problem at half intensity. Because the projected source is split too.
I guess what I'm getting at is projecting it is like a point source where a reflected LCD is more like an orthogonal projection.
Like this pic from earlier..
It's just a projector hacked from an old camcorder viewfinder. It's projected through the fresnel and then onto the wall. Notice how you can still see the projection source at the bottom left? If I were projecting onto glass (after the fresnel), you'd see it there too IIRC.
I'll have to find my stuff and give it another try.
Also, that privacy glass (electrochromatic glass IIRC) that your thinking of, I once looked into it awhile ago, dont' know how practical it is. It's real expensive, but it's also a current draw. I door would probably be better.
Old 08-14-2006, 09:52 PM   #419
quantum's Avatar
Hey all,
Came across this if anyone's interested on E-bay
Short throw motorized projection lens:
http://cgi.ebay.com/Short-Throw-Lens...QQcmdZViewItem
Partstore.com has it listed for $800.00.
http://www.partstore.com/ProductDeta...1455&s=froogle
I bought one off e-bay for myself for $25.00 shipped. If nothing else, maybe I'll make a projection TV for my den.
Guys, I am also really digging the holo-display panels, going to do some experiments this weekend with a rear projection night vision setup...
GF - as far as I know, all polarized films have some color to them, never seen one crystal clear, although some sites claim they are, not really...
COMPLETE! - 2002 Cadillac DTS - Summer 2008
http://www.mp3car.com/vbulletin/show...-complete.html
quantum is offline   Reply With Quote
Old 08-14-2006, 10:16 PM   #420
crystal clear would be nearly impossible, wouldn't it? I dunno, i'm trying to find the pinouts of the RCA in of the LCD still. I got my s-vid to rca adapter today. Go ebay.
Forgive me, but i'm not all there today....how wouuld you utilize the lenses withthe projection. Yeah, i'm really not there at all today...
\BTW, 512K of RAM means its time for an upgrade. Change it quick, i won't tell anybody!
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
PROJECT: 2004 Xterra Carputer elgenyo Fabrication 9 06-01-2007 04:23 PM
VW Golf mk3 - carputer project Sh0cker Show off your project 43 12-09-2005 10:14 AM
My Carputer Project, need advice natesimpson74 General Hardware Discussion 1 09-21-2005 01:14 AM
My carputer project: Solaslim nthai Show off your project 57 10-28-2003 03:43 PM
New CarPuter Project: Need Input! Tremek General Hardware Discussion 12 01-31-2002 03:07 AM
