The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Thread Tools Display Modes
Old 05-20-2006, 08:49 PM   #1
My Photos: (0)
help with micro switch
I have a IBM latop in a mini dock, docking station.
I though I could just wire up an extension into the on/Off switch on the docking station.
But when I opened it up the on/off button push against a rod that extend down to the main circuit board where there is a tiny switch.
anyways, I can solder, no problem, BUT the little switch has 5 leads coming out off it!?!?!
one side has 3 and the other side has 2.
anyone know why the switch would need 5 leads??
and switch 2 do I need to solder to turn it on??
thanks
blackcar is offline   Reply With Quote
Sponsored Links
Old 05-20-2006, 09:17 PM   #2
My Photos: (0)
The top right pin has the word "SW1" near it, so I'm guessing that's one of them, still need to find the matching pin for that
Old 05-20-2006, 09:19 PM   #3
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (71)
more than likely there is still only 2 that need momentary contact with each other
to start it..... picture?
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 05-20-2006, 09:21 PM   #4
turbocad6's Avatar
My Photos: (71)
ahh, pictures...
just test the 4 corner ones.... pick one, then touch it with a jumper to one of the others..... continue until it starts..... those are them....
Old 05-20-2006, 10:03 PM   #5
My Photos: (0)
Often times there are redundant leads on surface mount tact switches like the one in the picture. Looks at the traces on the PCB and see where they go. You will see that that there are only two different traces leading away from the switch. They usually have 4 leads. I have never seen one with 5. Maybie there are two common pins, a normally open and a normally closed.
Rickertsen2 is offline   Reply With Quote
Old 05-20-2006, 10:18 PM   #6
BassBinDevil's Avatar
Vehicle: 1957 Ford panel delivery
My Photos: (0)
Try measuring between the different leads with a voltmeter. If you find a voltage, keep the leads connected and push the button, and see if the voltage goes to zero when the button is pressed.
BassBinDevil is offline   Reply With Quote
Old 05-21-2006, 01:20 AM   #7
My Photos: (0)
Shouldn't voltage only go throught when the button is pressed??
finally found my volt meter
OK, I've found that when I have connectors on
the top left and bottom right pins AND the button is pushed I get connectivity.
(when the button is released, connectivity is broken)
On the other hand, without holding down the button
I only get connevtivity on the Top left and Top right pins
BUT there is NO change if the button is pushed......
Right now I'm guessing I should use the first scenerio, right?
Old 05-21-2006, 01:59 AM   #8
turbocad6's Avatar
My Photos: (71)
dude, it really is as simple as test jumping one by one to see which one fires it
Old 05-21-2006, 02:02 AM   #9
My Photos: (0)
yeah, I just don't wanna fry the board (it's happened before in the past )
I'll give that a try tomorrow, time for some sleep
Old 05-21-2006, 11:50 AM   #10
W3bMa5t3r's CarPC Specs
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
Vehicle: 2004 4Runner SR5 V8 4WD
My Photos: (15)
Check out my sig as well. Lots of good info from numerous users. Covers this a few times. Laptop Power On Module
W3bMa5t3r is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Remote On/OF Switch for an Inverter PapaPrem Newbie 5 03-09-2005 10:54 AM
Capture GPS data at the flip of a switch Mr. Inquisitive GPS 4 02-02-2005 06:06 PM
Savage Switch Botton Group Buy via UK's Iconstyling.com.... TheBigDog General Hardware Discussion 3 07-21-2004 10:51 AM
Need clairification on wiring on/off switch syclone477 Newbie 9 03-23-2004 04:59 PM
Help With Extending Laptop Docking Station's Power Button JeffesonM General Hardware Discussion 10 04-14-2003 01:13 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
