07-27-2006, 01:23 AM
#16
Cool ideas. I too have a serial relay controller, but haven't had time to code anything usefull. Does anyone want to share their software? I realize that it might not work for mine, but I think if we could share, we could come up with something really nice.
Possible frontend plugin?
www.mobile-effects.com
Free file hosting, picture gallery hosting for installs, PM me.
Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
07-27-2006, 08:08 AM
#17
hey snyper, i do my coding in java, if you'd like a copy of what i have so far ill post it or pm me ..
Carputer Status:MobileOne: Gentoo reinstall/optimization - coming soon!
MobileTwo: ubuntu quick fix while MobileOne's out of service -- worklog-- GeekBlog--
Audio: stage 2 nearing completion
07-27-2006, 08:29 AM
#18
This sounds interesting, I might want to give this a try later down the road. Just curios but is the VB API a COM DLL?
07-29-2006, 01:00 PM
#19
mscomm32.ocx?
07-29-2006, 01:59 PM
#20
emm, stand up and be counted all you that HAVE A RELAY BOARD WORKING IN YOUR CAR..........
Lots have wanted them and had big plans for when some working designs came out, afaik, no one actually uses one.......
<holding breath>
Lez.
XM 2.1TD ~ Morette triple headlights+HID ~ Leather kit ~ XC70 alloys
Exhaust rear boxes removed ~ meshed air filter
07-29-2006, 02:17 PM
#21
eh...
Most ppl like the idea, but don't want to hack apart their car's wiring. And then there's ppl that don't have power windows/locks, etc. Like me (my daily driver).
Soon it will come, and everyone will be hacking their wires, just like they're into hacking the dashes now.
07-29-2006, 02:50 PM
#22
i think that the fact that you can even control things from your computer is crazy it doesn't matter what you can do with it. every time you show people what you can turn on and off they will be amazed anyway! i pop my fuel door, door solenoids, rear hatch, neons etc. anything with a switch...
07-29-2006, 04:44 PM
#23
<holding breath>
i want one!, and will have one as soon as im back in my country, haha, i'll post pics for you when i finally get started
08-04-2006, 11:26 AM
#24
Quote: Originally Posted by SnyperBob
eh...
I see no reason to have to hack into your wires. Using those vampire connectors should be fine, as long as you know what you are doing...
I have it working in my basement, does that count? No? Damn.
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
08-04-2006, 11:16 PM
#25
I say it counts .. IF ... it is in test stages before going into the car .. as mine is ...
08-10-2006, 03:35 AM
#26
Quote: Originally Posted by red_parchel
well those are some good idea's ... i think im gunna need a bigger rely board ...
it requires 8 relays to open and close 4 windows!
my little app looks like this as of now ... or last night im sure tonight it will be different ..
Might be a silly and kind of late tip. But as far as I know it shouldn't be too hard to control 4 windows with 4 switches. 2 switches to select wich window (2 bit selector) and 2 switches to make it open or close. You could make it a 3 bit selector and you can even make it possible to select combination of windows. That way you can even controll all windows at once.
Should be easy. I can post a scheme later this day on how to do it. I don't have a relaycard (don't even have a car yet) but I've studied electronics and in my opinion it would be easy to use this idea.
08-10-2006, 08:16 AM
#27
i have yet to put it in just have the software workin, which is not hard to change, so please post this, i am very interested in using less then my entire card to open and close windows!
08-10-2006, 09:55 AM
#28
A few people in here are pic basic users, anyone that falls into that catagory who fancys work on a project to build a PIC controlled cellphone conected car alarm email me at:
caralarm@devonkingtravel.co.uk
I'm starting on the software/hardware design stage, have some prelim idea's as I have tried a few ideas already, hardware will be a simple pic and a serial talk phone.
So, if you have a few suitable pics to play with, a way to program them, pbc 2.45, and dont mind using yahoo groups or google, drop me a email.
Its looking so far like this for coms....
cellphone---serial---Pic----USB or serial ---- carpc
As for the alarm side, its simple a few spare input pins on the pic and an output pin to drive a loud horn, pic would also dial you up and/or text you.
I started work on this a year ago, but went onto the relay board, finished that, then my programmer died, now I have a new programmer and I'm off again, but dont fancy doing it all myself.
Lez.
08-10-2006, 10:28 AM
#29
What about using a window rollup module from a car alarm? DEI has the 530T that will handle up/down for up to 4 windows, and uses a ground trigger to operate.
Here's a link to the manual - http://www.directedstore.com/manuals/530T.pdf
"It's a blessing . . . and a curse."
08-10-2006, 07:21 PM
#30
Okay, this is what i have now. You need a secondairy control print that makes you select which window you want to control. And makes you tell it what to do with the window. It consists of a Dual 1 to 4 decoder/demultiplexer to do the window selecting. I use 1 to control the window up event and one for the window down event. When you use the sel1 and sel2 inputs (should be connected to 2 relay outputs on the card thats connected to the PC) to select the window 3 (1 on and 2 off makes window 3 selected) you can use up or down to roll the window up or down. So on this secondairy print you have 8 relays again to control the windows eventually but you only use 4 on the relay card on the PC. I hope my schematic makes any sense.
Keep in mind that this only exists in my mind and as far as I know it should work. Only possible sort of problem is that this circuit expects logic 1 and 0 levels at the inputs. And I have no idea on what values the resistors should be. I also don't know if the transistors are capable of driving the relays but it's just to get you guys going. If you are realy interested I can figure out the values and I could look up the right transistors for this job.
| Thread Tools |
| Display Modes |
Linear Mode
