Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 08-10-2006, 10:16 PM   #31
AIVMS handles relay operations quite well. You can control it from a touch screen :
or by voice command, or by a Pocket PC:
Thats actually a recorded button press sequence for controlling a home automation system with a WiFi connected PPC, but you get the idea..
Being able to control relay's simply by calling the system using a phone or cell phone is pretty nice too. I mean seriously, if your friends are impressed by something simple like relay operation from a touch screen, calling your car with your cell phone and rolling the windows up should cause a few coronaries.
Mechanic is offline   Reply With Quote
Old 08-11-2006, 07:46 AM   #32
red_parchel's Avatar
amiganut - that makes a lot of sence!
i think once my relays and computer are in placeim gunna do it that way, so if you could it would be much appreciated to know those values, no rush of course!
thanks again ..
Carputer Status:
MobileOne: Gentoo reinstall/optimization - coming soon!
MobileTwo: ubuntu quick fix while MobileOne's out of service
--worklog--GeekBlog--
Audio: stage 2 nearing completion
red_parchel is offline   Reply With Quote
Old 08-12-2006, 11:16 AM   #33
I guess you could even remove 4 of the relays of the original borad and use them on the secondairy board and wire the inputs of the second bord directly to the first board. That way you eliminate relays controlling other relays. If you can tell me what kind of relay card you have I could probably figure out how to connect them together.
I will look into the resistor values and the transistor types this weekend. and I hope I can post a reworked schematic by sunday. Keep in mind that I'm not 100% sure it will work. It should work in theory and I think it will work in practice.
Nice to know that at some of you guys apreceates this idea and are actually thinking of using it. The schematic and board layouts will be freely available to anyone who wants them.
amiganut is offline   Reply With Quote
Old 08-14-2006, 10:49 AM   #34
lez
lez's Avatar
Quote: Originally Posted by Mechanic View Post
AIVMS I mean seriously, if your friends are impressed by something simple like relay operation from a touch screen, calling your car with your cell phone and rolling the windows up should cause a few coronaries.
Yes well I'm working on that one, but just getting the new chip to program and perform a hello world test is still about a week away............
Biggest setback is I forgot to order new crystals, I have 4mhz, I need 20mhz...
<edit>
Decided on the board design for initial testing.
If no image above its here...
http://the-usb-pic-gsm-car-alarm.blogspot.com/
Lots of led's for status and errors, usb socket for pc comms, simple 232 on a header for the phone, relay outputs for control of car features, watch this space.
Lez.
XM 2.1TD ~ Morette triple headlights+HID ~ Leather kit ~ XC70 alloys
Exhaust rear boxes removed ~ meshed air filter
lez is offline   Reply With Quote
StreetDeck Functions god_of_cpu DigitalMods (Scripts / API) 22 01-15-2008 10:44 PM
Single Pulse to Lock and Unlock Using a mechanical latching relay rotarypower101 Hardware Development 3 08-16-2006 02:40 PM
Lock-start-puter circuit. KyleYankan Hardware Development 17 07-17-2005 12:05 PM
Serial Relay Controller lifeboat General Hardware Discussion 0 06-29-2005 02:55 AM
Will someone help me program my relay control module cproaudio Software & Software Development 6 09-04-2002 04:50 AM
