Quote: Originally Posted by
gtz
these forums mess with the homeade diagrams.. trust me i am positive its wired correctly.. i just am trying to find out why the relay wont control it.. i dont want to use the big relay unless i have to because the small relay i currently am trying(and having probles with) is wired up inside a project box along with multiple other circuts wo keep them all nice and neat looking.. and i have it running out of the project through 15 pin dsub connectors to ensure i can easily remove and install things as needed.. that wait if a relay goes out i can just disconnect the box and change / add things inside without haveing to mess with all the wiring..
Try paint or describe it better. I have no idea what wire 1 and wire 2 are, and what black and red wires are, which is ground, which is accessory, which is positive, which is for the invertor switch, which is the inverter wires or wire colors.
Be as specific as you can. You seem to think it is wired correctly, and it may be. If it is wired correctly, it doesn't make any sense, unless you are putting to much power through the relay, and fusing it, but I would believe if it was fusing, it would never return to normal. That is why I believe you have it connected incorrectly, but with out knowing the wiring diagram, that is impossible to say.
Michael
