The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Thread Tools Search this Thread Display Modes
Old 11-06-2006, 10:32 AM   #1
pcmofo's Avatar
Vehicle: 2000 Honda Civic
My Photos: (0)
AutoPage 860 + 2000 Honda Civic Wiring diagram Help!
I have an AutoPage 860 alarm/remote starte 2 way unit. I was able to get into the autopage dealers section of the web site (pass:autopage )lol and download a nice version of the instruction manual. I then decided the best thing I could do is to draw a diagram of the connections of wire colors between my car and the unit now before I connect them and it will make everything go smoother because I can double check my work now instead of when I am stuffed under my dash. Anyway here is the hookup diagram I made... I have a few places that tripped me up... I labeled them with a big red ? and a number so you know what part I am refering to... If anyone would like either connection diagram I can post those too.
OK ? 1. top right.
The 2000 honda civic chart I downloaded from here says that Accessory is a yellow + wire. Another diagram has told me it is a white/black wire... which is true? (I am going to test all of the wires regardless to verify each one of course but like I said its nice to know ahead of time)
?2 top left.
The pink wire is set to output a double pulse to unlock all of the doors. My civic wireing diagram shows a lock/unlock and a passanger unlock. I assume that the pink double pulse wire goes to the same door unlock as the blue unlock wire and does not get connected to the passenger unlock wire... but why would it be in the diagram then if no one used it? Any thoughts on which is correct to use?
?3 bottom left
According to the instructions the hood pin needs to trigger both the instant blue trigger and negative safety wires and that they need to be isolated from eachother with a diode. Also the trunk pin needs to be connected to the instant trigger. This way if the trunk opens the car alarms but does not shut off and if the hood is opened the car shuts off and alarms. Is this connection correct?
?4 bottom right
This is a copy of the connection for a starter kill relay that I got from the instruction manual. I have attempted to simplify it and make it less confusing yet still work. Is it connected correctly?
?5 bottom
I want the dome light to function. The connection diagram for the civic says " connect to door trigger " so would this be correct? Would tripping the dome light somehow cause the alarm system to think that someone opened the car door and set the alarm off?
Thats about it.. I might use one of the extra 3 channels to latch on or off a relay connected to my computer turn on wire in my car if I wanted to just turn on my car. The computer turns on the amps. If music starts playing though and the system is armed I would assume that it would set off the system?
Anything else fun I can do with the extra outputs?
Thanks for your help guys
MII1200 - 512MB - 60GB - 7" Lilliput - SiRF Star III - BT - Wi-Fi - Rear Camera - Full Audio System - Custom Dash
Project Log
|----------| Software
|----------| Hardware
|----------| Fabrication
|----------| Installation
pcmofo is offline   Reply With Quote
Sponsored Links
Old 11-09-2006, 02:11 AM   #2
walky_talky20's CarPC Specs
Vehicle: 1986/Toyota/Celica
My Photos: (0)
Regarding Question mark #1:
Here is the underdash wiring diagram for your 2000 Honda Civic LX.
2000HondaCivicUnderDashElectrical.pdf
It shows the ignition switch in the top left. The accessory wire you need is indeed 3 different colors depending on where you tap into it. If you tap in directly off the ignition switch before the underdash fuse box, the wire will be White/Black. Coming out of the fusebox through fuse #27 (to the radio) it is Yellow/Red, or through fuse #28 (to the cig lighter) it is Yellow/Green.
There also appears to be an "Option Connector" in the underdash fusebox that is also connected to the White/Black Accessory line. Perhaps there is a empty spot for a fuse there. It might be easy to just plug in there rather than tap into the wire.
Peace.
** Denotes an "in car" post
In-Car posts made from passenger seat - be safe,Don't Post and Drive.
walky_talky20 is offline   Reply With Quote
Old 12-23-2006, 03:00 AM   #3
My Photos: (0)
diagram for 200 mazda protege and autopage rs-860
i love your diagram for your civic,i also install one of this unit on my car and everything is working but the remote start,i'm confused with how to hook this one on my mazda. when i ran the test ,it tells me that it's not sensing the tach. i already had a code alarm on it and i know i install the tach wire to the correct one on my car, which is a purple wire on the firewall connector.what i think its that i'm connecting the relay for the starter wrong. this kit comes with a relay and a set of wiring for that relay,but does this unit has the relay built in already for the cut off to the starter?if you can please do one of those diagrams for my car i will be so appreciated. thanks,
TRINIDAD23 is offline   Reply With Quote
Old 01-14-2007, 05:44 PM   #4
My Photos: (0)
Trinidad23 Make sure you go through the tach learn mode on the autopage. Tach wire is under the hood, it can be hooked up but if it doesn't learn the tach remote start wont work. Blue wire with the test connector usually taped up on the driver side, near the firewall on the civic. You can also use an injector wire for tach aswell.
level12 is offline   Reply With Quote
Old 01-14-2007, 06:19 PM   #5
My Photos: (0)
OK ? 1. top right.
Use the whiteblack wire in the ignition harness.
?2 top left.
If you want all the doors to lock and unlock together dont hook up the pink wire. As for drivers door priority it may be through the programming menu if you use that wire.
?3 bottom left
Looks right to me
?4 bottom right
it should work, if it doesnt try this
http://the12volt.com/images/relayno.gif
?5 bottom
I usually dont hook this up as the door trigger wire being hooked to the door pin wire works quite well.
Use the door trigger wire and hook up to the Light green/red wire in the car and you should be good to go
Depending on the shock sensor settings chances are it will go off due to the music playing
Its upto you, window rollup modules, etc...
Good luck and take your time and you should be fine, pm me if you need anything else.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
2000 Honda Civic Dash LCD intigration pcmofo Fabrication 17 03-19-2006 11:09 PM
2001 honda oddsey wiring diagram for dvd dirocco103 General MP3Car Discussion 1 01-15-2006 08:44 PM
2000 Honda Civic w/ Dell Laptop LostCosmos Worklogs 1 08-10-2005 09:12 PM
LCD for 2000 Honda Civic cybler LCD/Display 2 08-03-2005 03:15 PM
2000 Honda Civic DX Hatchback 1BlackHatch Show off your project 31 02-16-2004 10:07 PM
Sponsored Links
Ad Management by RedTyger
