Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 01-19-2007, 04:23 PM   #16
Skum is an unknown quantity at this point
I had tons of problems with the generator noise, and had tried a lot of stuff (but apparently gone in the wrong direction). Then finally turning to the net (where I of course should have started) I found this, which works perfectly! Thanks a million man!
Skum is offline   Reply With Quote
Old 01-19-2007, 04:41 PM   #17
ROMbler is on a distinguished road
Arg! I just threw away two modems I had kept for the longest time. I have tons of parts that I finally decided to organize and consolidate. The only stuff I chucked were the modems and an 8MB graphics card. I should have known better. I like your tutorial and would have preferred to build the isolator over junking the parts. Never fails when you decide to chuck something
ROMbler is offline   Reply With Quote
Old 01-19-2007, 05:13 PM   #18
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
http://www.mp3car.com/vbulletin/car-audio-faq/79248-induced-noise-ground-loop-trouble-shooting-guide.html
some of you should venture into the Car Audio forum more often...
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 01-22-2007, 04:44 AM   #19
raxy is on a distinguished road
sorry to disagree with the solution.
telephone/modem coupling tranformers are good only for telephony,
that mean they are made for telephony bandwidth : 300-4000Hz
below and above this range, nothing is guaranted and the cheaper the device, the narrower its frequency response.
Did you measure 20Khz and 20Hz output levels compared to a reference @ 1KHz ?
raxy is offline   Reply With Quote
Old 01-22-2007, 11:07 AM   #20
spuzzdawg is on a distinguished road
I might be making a big assumption but I would have thought that the interference noise had a relationship to the RPM of the engine, in which case the telephony bandwidth is almost perfect - I guess it could go a little higher
Spuzzdawg
spuzzdawg is offline   Reply With Quote
Old 01-22-2007, 11:39 AM   #21
Raw Wave
Rob Withey's Avatar
Rob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to behold
The transformers don't filter out the noise. They isolate the grounds.
If it was a case of filtering, a simple high pass RC filter would do the trick.
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 02-04-2007, 09:54 AM   #22
Don't know how I forgot it worked by isolating the grounds by the time I got to the end of the thread - thanks for correcting me. A lil OT Rob Withey but how did you get the neat little pop up table for your car specs?
Spuzzdawg
Old 02-04-2007, 10:31 AM   #23
_
Spuzzdawg -
http://www.mp3car.com/vbulletin/announcements/93477-carpc-specs-user-profile.html#post987518
In the forum announcements.
Jan Bennett
Old 02-06-2007, 04:31 PM   #24
bosstone74's Avatar
bosstone74 is on a distinguished road
I just grounded my motherboard to the chasis of the car...and it was gone
BossTone74
bosstone74 is offline   Reply With Quote
Old 02-07-2007, 03:06 AM   #25
Spuzzdawg
Transformer limited bandwidth means bass end treble will be substracted from your music, this by no means is expected
Old 02-15-2007, 06:50 PM   #26
Virus3000 is an unknown quantity at this point
Thanks, will try this
Virus3000 is offline   Reply With Quote
Old 09-11-2007, 08:56 AM   #27
jasbirriyat is an unknown quantity at this point
Cool Hmmm, cheaper way available
well, i had the same problem with my car pc. i just added a ferrite ring on the RC cable. gave about 3 -4 round around the ring. and the ferrite ring is for about 0.5 usd i think.
jasbirriyat is offline   Reply With Quote
Old 09-20-2007, 04:41 PM   #28
Snortonnorton is an unknown quantity at this point
very impressive that you can build your own.
but a good working GLI is 15 bucks at circuit city made by Tsunami in the car audio section, and it's more durable so I don't have to worry when I shoved it behind my dash.
Snortonnorton is offline   Reply With Quote
Old 09-21-2007, 02:53 PM   #29
BiG K is on a distinguished road
How about this for a poor mans solution to interence??
I bougth a USB creative soundblaster Live, works great etc. But if my phone is near it, with the sound high, it can get alot of interference. So I started experimenting.
I chucked it into a large anti-static bag and hey presto, approx 50% of mobile phone interference gone!
Plastic is not the best thing to wrap things up in and besides, 50% is still quite annoying!
So I wrapped it up in foil.....normal everyday kitchen aluminium foil. Worked a treat, by my reckoning, approx 95% of inteference gone!!
I am willing to bet if I put two layers and grounded the foil, I could possibly get 99% if not possibly 100%??
If it works for mobile phone inteference, could possibly work for other types of inteference??
Since this is a cheap simple way of cutting inteference, maybe someone could put it to use and let us know??
Also, why stop at the sound card? Why not enclose the PSU and/or computer in this manner??
The only problem I can see, with it being aluminium, it conducts electricty, so you have to be VERY careful not to short anything out!
Also could be a tricky issue with vents etc??
BiG K is offline   Reply With Quote
Old 12-09-2007, 12:30 PM   #30
altinono's Avatar
altinono is an unknown quantity at this point
it's work
thinx Gip
altinono is offline   Reply With Quote
Noise on audio from laptop pip Laptops, Netbooks, Tablets, UMPCs, etc. 6 11-24-2006 08:09 PM
Power Supply MrGee Newbie 9 06-21-2006 05:44 PM
Shuttle G5 1100h and Opus Power Supply Caelric Power Supplies 9 11-16-2005 05:13 PM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 10:29 PM
