Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 12-09-2007, 10:00 PM   #31
TheGemInIMan's Avatar
TheGemInIMan is an unknown quantity at this point
Quote: Originally Posted by BiG K View Post
The only problem I can see, with it being aluminium, it conducts electricty, so you have to be VERY careful not to short anything out!
Also could be a tricky issue with vents etc??
Here's a tip for ya for a grounding plane ...
If you can get hold of a laminator just grab some foil and laminate the foil ... make sure you have about 5-10mm clearance all round so that the laminate seals itself ...
Warning the laminate MUST be put into the laminator with the closed/joined end first (as it's supposed to be, normally) otherwise you might find the whole lot wrapped round the laminator heater ... otherwise it's a case of dismantling the unit ...
The foil is then protected from shorting out anything ... peel back a bit of the laminate (possibly the corner) and shove a piece of wire in between the laminate and foil ... secure in place (super glue or bolt it down ... or whatever) then connect that wire to the earth connection in question ... it works a treat so long as you follow the warning above ...
As for the vents ... use a scalpel to cut out the holes/slits needed ...
cheers,
Gem
TheGemInIMan is offline   Reply With Quote
Noise on audio from laptop pip Laptops, Netbooks, Tablets, UMPCs, etc. 6 11-24-2006 08:09 PM
Power Supply MrGee Newbie 9 06-21-2006 05:44 PM
Shuttle G5 1100h and Opus Power Supply Caelric Power Supplies 9 11-16-2005 05:13 PM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 10:29 PM
