Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 11-22-2006, 02:41 PM   #1
Gip
Gip is on a distinguished road
Poor man's guide to remove power supply noise from audio
Intro
Well... You just connected your notebook to a car power adapter and to the amplifiers... But... WTF! You hear a very loud buzz from the speakers, and you can barely hear the music playing on your PC! Please, help me Mastro Gippo!
Example of a noisy environment:
Car -> DC-DC Inverter, 12V to 19V -> Laptop -> 3.5mm Jack to RCA cable -> Amplifiers
Here is the solution!
What you need:
-2 old modems (56K or lower, with the little transformer)
(get them from your nearest dumpster)
-the 3.5mm Jack to RCA cable (or whatever connector you need)
-soldering iron and standard stuff
-optional but recommended: a proto-board
Before you start
Standard disclaimer: I'm not responsible if you break your stuff or die. This method works for me and for that kind of noise. It won't eliminate any other kind of noise. Please do this only if you know what you are doing, and ask help to someone that knows electronic better if you are in doubt.
Let's go!
Carefully remove the tranformers from the modem PCB using the soldering iron (heat one pin and gently pull the transformer, then heat another pin, then another, then the last, repeat until the transformer falls into your hand - warning, hot pins!). Beware, these transformers are very fragile and you can break a pin if you pull out too heavy!
Now you should have two transformers, just test them to check if they work using an ohmeter.
The windings should have an impedance (resistance...) of 150ohm.
Cut the adapter cable in half, or at the point that suits you best, strip a bit of wire out of the ends and pre-solder them.
Solder the transformers on the proto-board, then solder the cables following this schematic:
I'm not so good at paint, so I added 2 pictures of the finished product so you can get an idea of the circuit. The white wire is only for holding the other two wires,so I don't break them if I pull too hard.
The end!
Connect the cale between the PC and the amplifiers... And it's done! Total cost: about 10$.... (even less if you already have the two modems, or if you find them for nothing).
And the quality??
This circit will not add any interference/distortion to your signal. You may have some impedance issues (the signal should increase a bit in amplitude) but the output will be 99.999999% the same as the input.
I hope you apprecate this topic and maybe make it sticky... I'm very busy at wok, but I will try to give support to anyone who needs help.
Bye
Gip
Gip is offline   Reply With Quote
Old 11-22-2006, 02:48 PM   #2
Raw Wave
Rob Withey's Avatar
Rob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to behold
This is simply a ground loop isolator.
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 11-22-2006, 02:50 PM   #3
Ruffy's Avatar
Ruffy is an unknown quantity at this point
interesting
if i have induced noise i'll try it
Ruffy is offline   Reply With Quote
Old 11-22-2006, 02:51 PM   #4
Gip
A poor man's ground loop isolator....
Old 11-22-2006, 03:25 PM   #5
Nomader's Avatar
Nomader is on a distinguished road
considering i bought my ground loop isolator for 12 euros then this is a veeeeery poor man's groung loop isolator
but nice to read how to do it and have fun to make
Nomader is offline   Reply With Quote
Old 11-22-2006, 04:39 PM   #6
Raw Wave
Chris31 will become famous soon enough
That is called "a poor man, 2 spare modems, other bits and alot of time" solution.
I think the poor man with no spare modems would just buy the premade one
Nice tutorial though
Chris31 is offline   Reply With Quote
Old 11-22-2006, 05:50 PM   #7
Ruffy's Avatar
I have spare modems, many of them. Most people that have build computers through the years have at least one.
I also I have RCA jacks and mini 1/8" plugs, same thing as above.
With alittle knowledge of the tools anyone can make it in like 10 minutes or less. I know I could.
A Premade one can be bought for under $20. But wheres the thrill of making something yourself with that?
Hell you can buy those transformers for $2-5 each and make your own for under $10
Old 11-22-2006, 05:58 PM   #8
Ruffy's Avatar
transformer
http://www.allelectronics.com/cgi-bi...:600_OHM_.html
$1.00 x 2
or
http://www.allelectronics.com/cgi-bi..._600_OHM_.html
$1.00 x 2
http://www.allelectronics.com/cgi-bi...CA_JACKS_.html
$1.25
http://www.allelectronics.com/cgi-bi...RF_BOARD_.html
$0.75
+ shipping = $11.00
At those prices you might as well buy extra parts and make several of them to make up for the high cost of shipping
Old 11-22-2006, 06:41 PM   #9
Raw Wave
Cool
How about a nice project box + gromets for the board to finish it off?
Old 11-22-2006, 08:02 PM   #10
Ruffy's Avatar
Cool
a true poorman dont need no sticking project box
he wraps it up in 19 cent electrical tape!
You could use a film canister, as if people still buy film...
Old 11-23-2006, 02:44 PM   #11
Gip
Well, I must admit it, this tutorial is mainly for people like you (and me), who have tons of "junkies" too hard to throw away because "you never know..."!
And I must ABSOLUTELY quote "A Premade one can be bought for under $20. But wheres the thrill of making something yourself with that?"!!! Are we the same person?
Btw, I'm not really a "poor man", and I don't think that everyone having enough money and effort to spend in a carputer is a REAL poor man, but I simply LOVE the challenge of efficiency. I always want to obtain the best results with the smallest effort... And I succeed most of the time! Sorry for you guys that prefer to buy premade things, paying more and learning nothing, but I'm a geek and I'm proud of it! Well, actually I'm not a real geek, since I have a girlfriend, but who cares!
PS: my circuit is wrapped up in 19 cent red electrical tape...
Last edited by Gip; 11-23-2006 at 02:50 PM.. Reason: Oh... And if you need it I can also post a version with balanced outputs, but this requires 4 transformers...
Old 11-23-2006, 03:31 PM   #12
Raw Wave
Rob Withey's Avatar
Some of us are geeks that already know how stuff works, and recognise that sometimes the most efficient way to get stuff done is to buy a mass produced device.
I'm surprised you didn't wind your own transformers...!
Old 11-23-2006, 05:10 PM   #13
Gip
Touche... But what about the satiafaction! Btw, I myself already know how and why this stuff works, you surely can imagine that I haven't tried to put every single component of a modem pc board in series of the audio cable to find out tha the transformer works better!
You will be surprised to know that in the past i even wond (mmmh... past of "to wind"? sorry for my english.....) my own transormers...
Old 11-23-2006, 06:20 PM   #14
Ruffy's Avatar
wound. You were on the right track with the word. The English language is not friendly.
Old 11-23-2006, 06:37 PM   #15
miwise's Avatar
miwise is an unknown quantity at this point
worked nicely for me. I already had a ground loop isolator (from radio shack) b/w the computer and both amps, but I was getting a loop b/w the sub amp and highs amp. I installed this b/w the 2 amps. Worked great!
Lexus SC400/Factory Amps/Sub
HP/AMD 1.1 Ghz Mobile/Upgrade Imminent
512 RAM-DVD/7" Touchscreen
WinXP-Shelled to Roadrunner for now
Progress:
Software: Still trying to decide
Hardware: 95% done. . .need GPS
Installation: 90% done. . .clean up phase
miwise is offline   Reply With Quote
Noise on audio from laptop pip Laptops, Netbooks, Tablets, UMPCs, etc. 6 11-24-2006 08:09 PM
Power Supply MrGee Newbie 9 06-21-2006 05:44 PM
Shuttle G5 1100h and Opus Power Supply Caelric Power Supplies 9 11-16-2005 05:13 PM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 10:29 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
