12-09-2006, 03:08 AM
#1
Notebook power button
Does anyone know how to relocate the power button of a notebook. I was thinking of soldering 2 wires to the switch but not sure where the connection points are on this switch.
Thanks in advance
Wing the thinking ape
12-09-2006, 04:29 AM
#2
FLA
First off, this site has TONS of info- try searching next time, it helps keep the clutter to a minimum.
But, the easiest way to find which connect to turn on the laptop is to use a multimeter across the terminals until you find the pair that closes the circuit. I would recommend unplugging the laptop and taking out the battery. Just look for continuity.
00 Focus LX soon to be boosted!
88 Escort GT Turbo DFI
12-09-2006, 02:10 PM
#3
Calm Down Or Get A 2 Week Vacation -Love The Forum Policeman
You have to "beep out" the circuit with a continuity tester. Push the button, and touch the probes to thse littel "metal" solder blobs around the button. There are 4. When you touch the correct 2, and push the button, it will beep. Those are the ones.
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
12-09-2006, 03:19 PM
#4
I think you will find that any combination of solder point, one on each side will be a short/break circuit, thats how most microswitches are setup
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
12-10-2006, 01:55 AM
#5
Thanks for all the replies.
I found that the two points are the metal square going around the switch and the bottom right blob.
It's incredibly small, don't think I can solder a loose wire to it without destroying the buttons connection to the circuit. Might have to attach a needle point to my soldering iron.
12-10-2006, 02:05 AM
#6
I've got a bit of a crazy idea to build a wood frame around the laptop and have a screw/spring/motor rigged just above the button. Probably have a 9volt battery connected to the motor and a switch. Would at least keep the laptop in tact.
12-13-2006, 07:10 PM
#7
A motor? If you're going to go that way I would think a pressure switch might be better. Something unrelated, but uses one:
http://redwolfairsoft.com/redwolf/ai...l?prodID=17941
------- I'm hungry
12-13-2006, 08:00 PM
#8
use a cheap solenoid.
hookup 12v to a it, put a resistor to drop voltage and a momentary switch which will push solenoid until you release the button.
12-13-2006, 11:09 PM
#9
Lol, very very cool ideas.
Hehe, that thing looks like it'll punch a hole through my laptop =)
12-14-2006, 02:12 AM
#10
Lol, well the pressure switch is just the rubber part/hose. The rest of it is a laser sight for an Airsoft Gun. I suppose this is a better example:
http://www.tacticalflashlights.com/f...ics/PL2326.jpg
------- I'm hungry
12-14-2006, 07:58 AM
#11
Thanks kaboom, I'll see if I can pick one up from my local electronics shop www.jaycar.com.au
| Thread Tools |
| Display Modes |
Linear Mode
