Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 02-12-2007, 08:46 PM   #76
rock99rock is on a distinguished road
Quote: Originally Posted by Kamakazie2 View Post
correct make sure tell them that its for a 2003 3series
.. the software will be for the Roadrunner front end. you will also need a 10k ohm resistor from radio shack.
the hookup is not that hard.
This is a solution i have been looking for in order to get my carputer in the works... excellent Kamakazie!
So with your software, you will also be able to control an ipod as well?
I read somewhere that there is weather information laced in RDS... see anything like that?
And FINALLY- Can you find a way to record HDRadio to the hard-drive? Better yet, use the RDS information and have that translated into an ID3 tag, or filename for the audio file? That is my ultimate goal, and you have just opened that door.
Thanks,
Rock
rock99rock is offline   Reply With Quote
Old 02-12-2007, 10:11 PM   #77
Kamakazie2 is on a distinguished road
Thanks,
Rock
First of all let me clarify.. i am using already created software called Ibusrr or Ibuscomm. I dont want to take anyones credit
Now for the good stuff. I am certain that we can create some sort of recording feature but i would like to get full functionality first.
You will be able to fully control your ipod with this unit using the optional ipod cable as well as an AUX input.
Right now i am building a test skin to control the radio from within RR.. right now i have a nice hex filled screen with tons of raw data. Once i get the screen wokring fully i want to develop 2 way communication to display the RDS information.. I am a hardware guy so if anyone (HINT HINT!!) Could possibly help me code some software it would be greatly appreciated
-Jack
2006 Chrysler 300C AWD
IBM T30 Thinkpad / RoadRunner
XMPCR/GPS/SIRIUS
(RIP) HDRadio project: http://www.mp3car.com/vbulletin/hardware-development/93791-someone-here-has-able-crack-hdradio-car.html
Kamakazie2 is offline   Reply With Quote
Old 02-13-2007, 01:29 AM   #78
theheel is on a distinguished road
are u serious..i should order the one for a 2003 3 series or is this a j/k that i didnt get...its that smiley... cant tell if you are serious or joking ...
I wish i knew how to do fiberglass work...
theheel is offline   Reply With Quote
Old 02-13-2007, 01:51 AM   #79
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Wiredwrx has a little shameless behaviour in the past
Yes, and since you have asked several similar questions, let me give you the low down.
Every BMW since, I believe, 1990 or so (I might be wrong on the year) uses something called the I-Bus to communicate between modules and systems. It uses the I-Bus when you press a button to unlock the doors, the door module sends a signal along the I-Bus to the lock module, which opens. THe CD changer communicates with the buttons on the radio through I-Bus. The diusplays gets thier information over I-Bus. EVERYTHING happens over the I-Bus.
The I-Bus data has been decoded, and has been for several years. With the I-Bus, assuming someone wanted to "do something" say, emulate a CD changer, they can develop something that reads the CD controls from the I-Bus, and send the appropriate information back over the I-Bus to the car, so that the car thinks there is a CD changer. This only requires an I-Bus encoder/decoder, and the proper programing.
This HD radio was created for the BMW's with I-Bus. It connects to the I-Bus, and communicates with and over the I-Bus. What they have done here is, using an I-Bus encoder/decoder, connected to the computer, decoded the information that goes over the I-Bus for the HD radio to work. They then, I assume using the instruction from the HD radio, monitored the buttons (although, there are libraries of which codes are sent with which button push in the Bimmers) to determine which codes are sent, and how the HD radio responds, so that they can program a computer to send and recieve the proper codes through the encoder/decoder to the HD radio.
Hope that explains things a little.
Michael
Wiredwrx is offline   Reply With Quote
Old 02-13-2007, 05:22 AM   #80
sama's Avatar
sama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud of
I think it was 95 onwards, and that it started with E39s 'cos it was bm's flagship, till 6 series came out.
///Mputer - Velocity - TomTom - Vision - Bezel - CarPC
sama is offline   Reply With Quote
Old 02-13-2007, 09:37 AM   #81
thanks for the breakdown on ibus WiredWRX. I suggested the 2003 3 series because it does not require any of the additional cables to run. Some of the Higher end Bmw's use digital audio converters to transfer the audio. For the car pc use we will use the standard analog audio.
-Jack
XMPCR/GPS/SIRIUS
(RIP) HDRadio project: http://www.mp3car.com/vbulletin/showthread.php?t=93791
Old 02-13-2007, 12:28 PM   #82
RadiantX's Avatar
RadiantX is an unknown quantity at this point
Any chance of a standalone application? I'm not a big fan of RR, but would love to add this to my CarPC setup.
RadiantX is offline   Reply With Quote
Old 02-13-2007, 12:30 PM   #83
strohj's Avatar
strohj is on a distinguished road
or perhaps sharing the code so we can port it to streetdeck ?
strohj is offline   Reply With Quote
Old 02-13-2007, 12:32 PM   #84
RadiantX's Avatar
That would work too, heck I'll even take a shot at creating an interface for it if I know how it communicates. I'm taking a look into this iBus rarr that was posted.
Old 02-13-2007, 12:44 PM   #85
Thumbs up
Right now its running by using the BMW ibus analyzer software.. so it should be simlpe to make a stand alone program. Im just working on ironing out the actual BMW codes to send to control.
this weekend i will be mapping out the codes and hopefully working with some of the ibus guys to make the software. Right now here is what we have:
Manual Mode (1 on the BMW)
< = Tune .2 dn (< on the BMW)
> = Tune .2 up (> on the BMW)
Scan Mode (2 on the BMW)
< = Scan Dn (< on the BMW)
> = Scan up (> on the BMW)
Preset Mode (3 on the BMW)
< = Preset Dn (< on the BMW)
> = Preset Up (> on the BMW)
Input Mode (5 on the BMW)
< or > Switches between FM-AM-AUX-IPOD
Settings mode (6 on the BMW)
I will dosument this later.. it should be set to Tr3 - Which will allow for 20 character diaplsy
All of this will be organized in a nice manual once i get it figured out
-Jack
XMPCR/GPS/SIRIUS
Old 02-16-2007, 05:01 PM   #86
Tonight is testing night for Roadrunner! IbusRR is nothing but a specialized version of Ibuscomm which takes commands from Keypresses or Other software to send the Ibus code. Unfortunatley i have only used it with RR.
What is to be expected: Full control of the HdRadio unit but still no feedback from the unit until i can get someone to pull the raw output into roadrunner or any stand alone software of their choice.
-Jack
XMPCR/GPS/SIRIUS
Old 02-16-2007, 05:20 PM   #87
YellowMater is an unknown quantity at this point
Can't wait. I have been following this forum for over a year and replacing my head unit was a big concern. I'm putting together a system now and have already ordered my dice unit. Thanks for all your work.
YellowMater is offline   Reply With Quote
Old 02-16-2007, 05:35 PM   #88
Dont forget the USB to Ibus interface!
-Jack
XMPCR/GPS/SIRIUS
Old 02-18-2007, 10:23 AM   #89
Ok, i finished the skin for RR to control the Radio.. it works! Now i just need to find out how to import the RDS information into RR..
We all have Warfield to thank for this wonderful software that works with Rolf Resler's Ibus interface...
I sent a PM to warfield to find out more about controlling the software via a stand alone program.
-Jack
XMPCR/GPS/SIRIUS
Old 02-18-2007, 10:24 AM   #90
I ordered the USB interface the same day I ordered my Dice.
What's your dream car? Aaron Cake Off Topic 172 10-02-2007 08:34 AM
In a real PC car struggle markland556 Off Topic 10 06-27-2007 12:36 PM
First Car PC Questions - Pretty Long Post Sorry :D [56k death] FiReToY Newbie 9 06-08-2006 06:15 PM
Employee Discounted Cars: Flatout BIG LIE! sdashiki Off Topic 33 10-31-2005 06:53 PM
Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail! hd54321 Power Supplies 1 02-24-2005 01:42 PM
