Quote: Originally Posted by
veedubya
Chris - what? no 5V? uhh am i wrong in thinking that the Data lines from the parallel port go high = 5V and thats what triggers the NPN to switch on and complete the circuit on the RC controller.
Not sure if you read my OP but why do I need 12V relays.
I have tested with seperate NPNs and i had my RC car plowing into the wall with the laptop taking a ride. This was controlled via VNC from main computer sans the video.
Enforcer - I have had good luck with VNC and video at work.
Just follow this circuit, its basically the same as the one I have described above >>>
http://www.southwest.com.au/~jfuller/sio5works.htm
No, the ULN chip does not need a supply, because all it does is sink its output to the ground when you apply the +5v to its input. Dont get confused with the 5V you apply to the chips input with the chips supply voltage. Notice there is no connection for the +5V supply on the ULN.
As for the relay, I suggest it cause you cant exactly do much with LEDs to control the RC car. If all you want is turning the LEDs on/off yes you can connect them directly to the LPT port no need for this drivers, LEDs with limiting resistors. Of course it is always better to use a buffer to avoid over loading the LPT port.
The ULN chip is typically used to drives relays.
or maybe I didnt read your original post properly
