The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Thread Tools Display Modes
Old 09-11-2007, 09:29 PM   #31
Dennis5587's CarPC Specs
Dennis5587's Avatar
Vehicle: 2006/Mazda/3
My Photos: (0)
my god... this is the biggest manual I have ever seen
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Dennis5587 is offline   Reply With Quote
Sponsored Links
Old 09-12-2007, 12:16 AM   #32
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
have you tried the software? it's pretty cool/simple
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 09-12-2007, 07:52 AM   #33
Dennis5587's Avatar
My Photos: (0)
no not yet... All I had last night was my mac
edit: the software is good, makes things a lot easier. You can change parameters on the unit as well which makes it nice, two options to tune. I havn't been able to try everything but I do like the EQ, seems able make tuning a lil easier and very precise
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Old 09-18-2007, 05:11 PM   #34
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
6 analog outputs.....damnit!
need 8...at a minimum...
Keep us updated on this guys. Looks very promising for those who need fewer analog outputs.
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 09-18-2007, 05:38 PM   #35
MySQL Error
scott_fx's Avatar
My Photos: (0)
you can link more then one unit together :-)
12 analog outputs is easy to attain :-)
M10k
My Car Pc Install
Old 09-18-2007, 05:43 PM   #36
_
My Photos: (73)
at that point though, price is no longer really an issue as it's more in the range of the DBX and size is a big concern...
Jan Bennett
Old 09-18-2007, 05:45 PM   #37
MySQL Error
scott_fx's Avatar
My Photos: (0)
from what i've read there isn't a lot to the insides so you can condense it pretty efficiently and it also doesn't need the front panel to be hooked up to function properly. but i dont know a lot about the dbx so i dont have much to comment about how they compare
M10k
My Car Pc Install
Old 09-18-2007, 06:05 PM   #38
_
My Photos: (73)
If there are any pictures of the inside of this thing I'd be very interested.
The front panel is not necessary at all for operation?
Jan Bennett
Old 09-18-2007, 06:08 PM   #39
MySQL Error
scott_fx's Avatar
My Photos: (0)
not needed if you control it with the computer :-).
i'll look for pics
M10k
My Car Pc Install
Old 09-18-2007, 06:11 PM   #40
Dennis5587's Avatar
My Photos: (0)
I'll take pics when I go home, the inside is virutally empty, there is just the power supply, which we swap out, the front pannel, which is most of the space, the rear pannel, and a small board for processing inside. You only need 3 of these 4, 2 of the 3 connects useing a ribbon cable, and the only other connection uses wires for power. Totally downsizeable.
On the downside, my amp is messed up http://www.mp3car.com/vbulletin/car-...300-4-amp.html
edit: You could also relocate the front panel to a more convienient spot... but it would be tricky splitting the panel up
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Sponsored Links
Old 09-18-2007, 06:18 PM   #41
MySQL Error
scott_fx's Avatar
My Photos: (0)
http://www.diyaudio.com/forums/showt...943&highlight=
M10k
My Car Pc Install
Old 09-18-2007, 07:30 PM   #42
_
My Photos: (73)
ok - so reading on the web site and reading through the manual...and they don't even speak a word of this...
how many EQ points? how much adjustability on each frequency? which frequencies? adjustable frequencies?
what about xo points? there's just not much on these VERY important technical aspects in the manual or on the web site....which is a bit dissapointing as these are areas that are critical to determining if a piece is worth buying or not in this field.
reading through the manual it's painfully obvious that who ever wrote it has very little knowledge of audio and processing because many of the terms are swapped and are used incorrectly...hrmmm
Jan Bennett
Old 09-18-2007, 07:36 PM   #43
MySQL Error
scott_fx's Avatar
My Photos: (0)
there isn't any regulation on how many eq points you can have as many as you want. basically it has a certain amount of processing power. you choose what you need to. let me get you a better answer description...brb :-)
M10k
My Car Pc Install
Old 09-18-2007, 07:52 PM   #44
MySQL Error
scott_fx's Avatar
My Photos: (0)
post 25
http://www.diymobileaudio.com/forum/...hlight=dcx2496
but that thread has a lot of good info too
M10k
My Car Pc Install
Old 09-18-2007, 10:45 PM   #45
Dennis5587's Avatar
My Photos: (0)
9 EQ points of adjustment, you can adjust each point + or - by .1db up to 15db frequencies are:
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
56
57
58
59
61
62
63
65
66
68
69
71
72
74
75
77
79
80
82
84
86
88
90
92
94
96
98
100
102
104
107
109
111
114
116
119
121
124
127
130
132
135
138
141
145
148
151
154
158
161
165
168
172
176
180
184
188
192
196
200
205
209
214
218
223
228
233
238
243
249
254
260
266
271
277
284
290
296
303
309
316
323
330
337
345
352
360
368
376
384
393
401
410
419
428
438
447
457
467
478
488
499
510
521
532
544
556
568
581
594
607
620
634
647
662
676
691
706
722
738
754
770
787
805
822
840
859
878
897
917
937
957
979
1000
1020
1040
1070
1090
1110
1140
1160
1190
1210
1240
1270
1290
1320
1350
1380
1410
1440
1470
1500
1530
1570
1600
1640
1670
1710
1740
1780
1820
1860
1900
1940
1980
2030
2070
2110
2160
2210
2250
2300
2350
2400
2460
2510
2560
2620
2680
2730
2790
2850
2920
2980
3040
3110
3180
3240
3310
3390
3460
3530
3610
3690
3770
3850
3930
4020
4110
4190
4280
4380
4470
4570
4670
4770
4870
4980
5080
5019
5031
5042
5054
5066
5078
5910
6030
6160
6300
6430
6570
6720
6860
7010
7160
7320
7470
7640
7800
7970
8140
8320
8500
8680
8870
9060
9260
9460
9660
9870
10100
10300
10500
10800
11000
11200
11500
11700
12000
12200
12500
12800
13000
13300
13600
13900
14200
14500
14800
15100
15500
15800
16100
16500
16900
17200
17600
18000
18400
18800
19200
19600
20000
If this gets copied anywhere, I want credit, cause this took a very long time to type in...
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Sponsored Links
vB code is On
Trackbacks are Off
FS: 250 watt DC to DC Power Supply EsKALad Classified Archive 0 11-11-2005 07:58 PM
DC to DC ATX 250w Power Supply & Honda Type-R for sale! l9nux Power Supplies 0 02-09-2005 02:49 PM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 09:29 PM
Is there any sk41g shuttle users using OPUS 150w dc to dc power supply inniss777 Power Supplies 8 11-04-2003 11:03 AM
what is the cheapest DC to DC ATX power supply available? Squeezer Power Supplies 9 07-29-2002 01:17 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
