The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Thread Tools Display Modes
Old 09-18-2007, 11:45 PM   #61
Raw Wave
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
Quote: Originally Posted by envisionelec View Post
Sure, if you can get 9V in (at 0dB)! I've not yet seen a headunit that can do this (no matter what the screen printing on the faceplate says).
Hi Volt heads are great if you need them. Problem is - 2V heads work just fine if your downstream equipment is any good.
sorry to ask so many questions; but say we're going s/pdif into the behringer... what's the output voltage? I'm not overly worried about it since my amps have balanced inputs so induced noise is less of an issue for me, but it would be good to know
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Sponsored Links
Old 09-18-2007, 11:45 PM   #62
My Photos: (0)
Quote: Originally Posted by RedGTiVR6 View Post
head unit...what's that?
Ah geez. Right. That's like talking about Jesus in a Buddist temple. Or the Browns in Cincinnati. Whoops.
So, you guys could help me with the in car computer stuff? My closest connection for this was building a, "biscuit PC" power supply (before they were plentiful) back in 1998 for my brother's MP3 player he built for his ride. His rig of a power inverter was unreliable and he always forgot to turn it off. I built the supply on a piece of perfboard and rewound the transformer from an old car amp. It was a little electrically noisy, but worked fine.
He then bought the indash eMPEG Rio(?). I think he still uses that...
envisionelec is offline   Reply With Quote
Old 09-18-2007, 11:51 PM   #63
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
heh - yeah - we might be able to help with that...lol
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 09-18-2007, 11:54 PM   #64
My Photos: (0)
Uh, that would be as high as you want. To around 9VRMS before clipping. Way overkill if you ask me.
Quote:
on a different note...you will only have the voltage out that you put in...so say I go with the Hippo HiFi USB DAC...which only has something like .5v output...means I'll only have .5v out to of the Behringer to the amps, correct?
If your amp can accept a 0.5V input with acceptably low noise, then there is no problem. You can increase output gain of the Behringer somewhat, but at the expense of noise. I'd build (or buy) a high end preamp before the Behringer is there was a significant problem.
It's only 0.5VRMS Max? That is lower than line-level.
Old 09-18-2007, 11:56 PM   #65
My Photos: (0)
Good, because I'm a computer genius. Right.
Old 09-18-2007, 11:59 PM   #66
Raw Wave
scott_fx's Avatar
My Photos: (0)
meaning that this is a car computer site... no head units
edit..woops sloooowww on the draw on this one!
M10k
My Car Pc Install
Old 09-19-2007, 12:02 AM   #67
_
My Photos: (73)
well, a quick search tells me it's actually 4.1v but I'm double checking that right now.
Jan Bennett
Old 09-19-2007, 12:09 AM   #68
Raw Wave
scott_fx's Avatar
My Photos: (0)
hmm.. well what is the best way to figure out the best out how to set your gains. do you set the behringer close to 9v but not clipping and set the amp's gain low, or do we set the behringer low and turn the amps gain up?
M10k
My Car Pc Install
Old 09-19-2007, 12:16 AM   #69
_
My Photos: (73)
I would set it to where you can set the amps at the lowest gain. This will allow the amps to run most efficiently.
Jan Bennett
Old 09-19-2007, 12:32 AM   #70
Raw Wave
scott_fx's Avatar
My Photos: (0)
I would agree with you but i'm just wondering if the gaining at the amp would be cleaner since the amp is built to much higher standards then the dcx (i am assuming here)
i guess i'll just have to test it
M10k
My Car Pc Install
Sponsored Links
Old 09-19-2007, 07:59 AM   #71
_
My Photos: (73)
hey scott - do you think you might be able to get some pictures with measurements of the boards in the Behringer by chance?
Jan Bennett
Old 09-19-2007, 10:01 AM   #72
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
I know it's less than ideal, but at least it's easy. If you plan on using the DAC, why not just use a simple 2 channel attenuator for volume on the output of the dac going into the behringer units?
Dave Navone and I think PAC makes a simple one.
PAC LC1
David Navone N-22V
Dammit. Now I'm wanting to use the behringer units but one is affordable 2 makes it less affordable for me
durwood is offline   Reply With Quote
Old 09-19-2007, 10:08 AM   #73
_
My Photos: (73)
Are you referring to the N-22V?
It's an option, I just need to be sure it's going to be linear enough...
One concern I have is that it needs to be connected between the HU and the amplifier...don't know why it wouldn't work between HU and processor? I'd also need to change from RCA to XLR to go into the processor.
Jan Bennett
Old 09-19-2007, 10:19 AM   #74
Car Audio Moderator
durwood's Avatar
My Photos: (0)
yep that's what I meant (fixed)
I don't see why it wouldn't work. I guess it's cheap enough to try out. Ideally it's not int he optimal location (should be at the end of the chain, but at least it's an option.
Old 09-19-2007, 10:45 AM   #75
_
My Photos: (73)
it's def an option!
Jan Bennett
Sponsored Links
vB code is On
Trackbacks are Off
FS: 250 watt DC to DC Power Supply EsKALad Classified Archive 0 11-11-2005 07:58 PM
DC to DC ATX 250w Power Supply & Honda Type-R for sale! l9nux Power Supplies 0 02-09-2005 02:49 PM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 09:29 PM
Is there any sk41g shuttle users using OPUS 150w dc to dc power supply inniss777 Power Supplies 8 11-04-2003 11:03 AM
what is the cheapest DC to DC ATX power supply available? Squeezer Power Supplies 9 07-29-2002 01:17 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
