09-05-2007, 08:09 PM
#1
MySQL Error
Behringer DCX2496 -- dc power supply
for those of you that are interested in an alternative to the h701 this may be up your alley:
http://www.behringer.com/DCX2496/index.cfm?lang=eng
with this mod:
http://www.diymobileaudio.com/forum/...ad.php?t=19371
just thought id throw it out there. btw, the behringer has a spdif input. the chassis looks big but i'm sure you could hack it apart and condense it. hell, talk to veritas_forge and he could probably make a custom case for it
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
09-06-2007, 10:11 AM
#2
Car Audio Moderator
And don't forget, the Behringer has a serial port and software to control settings via PC.
System always under construction
09-06-2007, 01:32 PM
#3
Quote: Originally Posted by scott_fx
Wow, you guys are fast. Thanks so much for spreading the news.
Aaron
09-06-2007, 03:07 PM
#4
Car Audio Moderator
aaron-
I'd sticky this for you but I think you should contact mp3car first to make sure they are ok with that per forum rules
09-06-2007, 06:20 PM
#5
MySQL Error
if i would have know about this about 6 months ago i would have jumped on this combo to test out in my system :-( I would have been a perfect candidate :-) pc, balanced inputs on my amps and fully active! damn it!
M10k
My Car Pc Install
09-06-2007, 06:28 PM
#6
MySQL Error
how small do you think you could get that behringer if you took it out of the case? do you have a top down of all the components inside the case? do you need to have the front panel connected to have the unit work? (wont need that since i'll have a pc)
M10k
My Car Pc Install
09-06-2007, 06:38 PM
#7
hmmmmmmm... just when my sound card turns out to be backordered....
2006 Mazda 3 Behringer DCX-2496 JL300/4 Focal 6W4311B Focal TN52 JL500/1 JL10w6v2
09-06-2007, 08:44 PM
#8
it has a digital in... but it's an xlr connection... would this work with a digital line out from a soundblaster?
09-06-2007, 08:46 PM
#9
Car Audio Moderator
Scott-
Steve aka Whiterabbit took his apart I believe. YOu might want to contact him over at DIYMA.
09-06-2007, 08:49 PM
#10
MySQL Error
great, i'll track him down.
thanks
M10k
My Car Pc Install
09-06-2007, 08:53 PM
#11
MySQL Error
the owners manual states spdif input so i'd contact them before you go this route, but this link may help you:
http://www.rane.com/note149.html
or this:
http://cgi.ebay.com/HOSA-ODL-312-OPT...QQcmdZViewItem
M10k
My Car Pc Install
09-07-2007, 04:00 AM
#12
You would need either the box linked on ebay, or the instructions in the document from RANE, as the input on the Behringer is an AES/EBU and not straight SPDIF.
So..what he said.
09-07-2007, 07:29 AM
#13
Quote: Originally Posted by durwood
aaron-
Thanks, Durwood. I was in the process of asking them about this when someone already posted to the forum.
09-08-2007, 04:31 AM
#14
MySQL Error
So..what he said.
the manual says it's straight s/pdif too though... i wonder if a simple cable would actually work.
http://www.sweetwater.com/store/detail/K2Digi/#anchor
i think it has something to do with the new chipsets can actually handle the lesser signal of s/pdif as well as still handling aes. I have been researching this a bit now :-)
M10k
My Car Pc Install
09-08-2007, 03:26 PM
#15
If you have the money,it is more expensive then the HOSA,but it can do more:
http://www.audiolines.com/product.ph...cat=218&page=1
(Behringer ULTRAMATCH PRO SRC-2496)
| Thread Tools |
| Display Modes |
Linear Mode
