04-18-2008, 10:43 AM
#16
Just want to make a note...
When you do the software routing, you would assume output 1 would be tied to RCA output 1 on the card, however this is not the case. Output 1+2 on SW are output 7+8 on hardware, 3+4 SW go to 5+6 HW, 5+6 SW to 3+4 HW, 7+8 SW to 1+2 HW.
04-18-2008, 11:11 AM
#17
Are you still having hibernation problems? Because I would assume that if you shut down the PC, then Console would shut down also and when you startup again, then you would have to run console again. Am I getting this right?
04-18-2008, 01:43 PM
#18
I've had mixed success with the Firewire 410. Sometimes it would work with hibernation and sometimes it wouldn't. More often than not it wouldn't work. But putting console in the startup folder takes care of loading console at startup.
04-18-2008, 01:48 PM
#19
Car Audio Moderator
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
I think the hibernation problem is with ASIO. What does it do for you guys-skip and stutter?
I have meaning to try this out with an Autoit script.
http://www.rpi.edu/~desimn/suspendtrigger/
System under construction
04-18-2008, 01:55 PM
#20
No, the device doesn't come back up in my case and it errors any time I try to play music.
04-18-2008, 02:20 PM
#21
Durwood, so basically, the app you're referring to, we would just select the programs (in this case..console + plugins and whatever frontend I'm running) that you want to "halt" or "pause" when we go into hibernate then when you de-hibernate/startup, the script would basically "un-pause" the programs? Does it prevent the programs from being shutdown wit hhibernation? Is this how it works or am I in lala land?
Machinehead, I don't see why you're having that problem.
04-18-2008, 04:17 PM
#22
I don't see why I'm having that problem either, trust me it's annoying. Cold boots take over a minute on my system while hibernate takes less than 30 seconds. I'm working to optimize my system to speed up cold boots.
The app Durwood is referring to allows you to run scripts or programs going into and coming out of hibernation. The function I used to use it for was disabling and re-enabling USB devices with Devcon.
04-21-2008, 09:56 AM
#23
Yeah I'll have to ditch my card and getting something with ASIO and 6 or 8 ch. output.
04-23-2008, 10:35 PM
#24
I use a 1010lt and have no problems coming out of hibernation but I use vsthost instead of console. I still have to put a couple commands into the ExecTBL in RR, something like close winamp on suspend and then sendkey to restart vsthost engine and then open winamp on resume. Works great however RR doesn't send the commands until I touch the screen (aka: move the mouse).
05-18-2008, 09:54 AM
#25
Is the M2ATX power supply with that Intel d201gly2a MB good enough with 1gb of ram, to run this sound card?? Im kinda a newbie, and I dont know where to find this out?
05-24-2008, 09:04 PM
#26
Also,
what are the easiest steps to take to have an output to a 4 channel amplifier, and a output to a mono subwoofer amplifier?
07-18-2008, 03:49 PM
#27
It should work although you may run into some issues with shuddering during high cpu loads. The celeron processor of the d201 is the limiting factor.
The output to the amplifiers is done through console completely.
| Thread Tools |
| Display Modes |
Linear Mode
