Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 01-16-2008, 12:43 AM   #1
capslock is an unknown quantity at this point
Thuneau Frequency Allocator on Via / Geode / other underclocked systems?
Has anybody been able to run Allocator Full on a typical low power system such as
- Via Eden at 800 to 1300 MHz
- Via C7 at 1000 to 1500 MHz?
- Geode LX 800 at 500 MHz (this sounds more like it will run Allocator Lite, if at all)
- Athlon 64 underclocked to 1000 MHz?
Eric
capslock is offline   Reply With Quote
Old 01-18-2008, 08:01 AM   #2
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
I asked a similar question over in thuneau forums on an EPIA M10000. The answer from them was not going to be fast enough. Their minimum recomendations was a Pentium 4 or equivalent AMD.
Lite should work ok though I believe. If you already have the hardware, you could try out the demos.
System always under construction
durwood is offline   Reply With Quote
Old 01-18-2008, 01:47 PM   #3
pwntbypat is an unknown quantity at this point
I was able to run console with FA pro, voxengo delay, and xvolver on a geode 1750, however don't expect to do anything else... period. moving the mouse causes studders and skips
pwntbypat is offline   Reply With Quote
Thuneau Frequency Allocator on Via, Geode LX or underclocked Athlon systems? capslock General Hardware Discussion 2 01-16-2008 12:44 AM
