Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 01-29-2008, 11:08 AM   #31
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Quote:
You can pick up a Soundweb 9088 on ebay for around $400-700 USD, they also show up in the UK on ebay too. A 3088 would be perfect for a car application (no networked audio = cheaper). They can be Line, mic/line or AES inputs. If you had digital source (audigy?) and digital amps(?) you could stay digital all the way through your signal chain.
Any ideas on a price for the 3088? Also, any ideas of someone to modify the PSU for 12v use?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 01-29-2008, 11:22 AM   #32
z_lust is an unknown quantity at this point
Yea, the last two are just an example of using different textures to achieve a themed look.
The point being you can create any kind of interface you want. You can even run the application in full screen mode (like kiosk mode for IE).
Download the software and start playing.
Another difference between Soundweb and London is Soundweb is a serial interface between PC and the device, London uses Ethernet.
I tested the Soundweb on an inverter, It booted fine, but I did not listen to the audio to see if I am getting any noise through the inverter. I am concerned because we use a switching power supply, and they do not like inverters. I may need help from the power supply guru's to modify the PSU for DC-DC operation. I have an inside track as I can get the schematics of the powersupply to work from.
Some additionl random facts:
Soundweb - 24bit 48k DAC's, 48k internal processing
London - 24bit DAC's, 48k/96k selectable internal processing
Single rack space design - both
z_lust is offline   Reply With Quote
Old 01-29-2008, 11:41 AM   #33
I'm checking on current pricing. I can't publish dealing pricing, but I'm showing retail @ $2539 with line input cards (mic, line & AES available and change the price). I'm pretty sure we had a major price cut on this model in '07, so I've email the sales mgr asking for updated pricing. I'll follow up with a corrected price when I hear back. These devices were over $5000 when they first came out back in 1997, and we only recently dropped the price after moving manufacturing to the US.
You can pick up 9088's on ebay, they usually go for under $800, a steal when you consider what it can do.
There are only a few places that will do a box sale on these (we frown upon that as these devices require programming to pass audio), but I can help source these for anybody that is interested.
I do not know anybody that has done the 12v mod. I will be the first (hopefully with help here). If I can provide schematics, is there somewone here who colud help with the circuit modification?
Old 01-29-2008, 12:31 PM   #34
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
wow, nice stuff... that looks so cool, & the software end looks to be more impressive that the 480 software for sure, since the software is going to be your whole interaction with the unit as a car install, I now see what you mean... cool
turbocad6 is offline   Reply With Quote
Old 01-29-2008, 12:39 PM   #35
Just got confirmation, major price drop.
Suggested selling price (we don't have 'Retail' pricing):
3088-LL $2032
3088-DD $2600 (AES I/O)
9088-LL $2660 (down from $3799)
Old 01-30-2008, 09:26 AM   #36
thekl0wn's Avatar
thekl0wn is on a distinguished road
In terms of units around the 3sixty range, are there any options with S/PDIF in?
Planning [----X-----] 40%
Programming [-X-------] 20%
Parts [-----X----] 50%
Install [X--------] 5%
See Me In A Pink Skirt
thekl0wn is offline   Reply With Quote
Old 01-30-2008, 08:43 PM   #37
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
envisionelec could probably whip something up for the DC-DC PSU. He already did for the behringer units.
System always under construction
durwood is offline   Reply With Quote
Old 01-31-2008, 11:14 AM   #38
The 9088 digital card only supports AES.
In the Soundweb London line, the digital cards support AES or S/Pdif
A BLU-16 8x8 with digital cards is $2849 suggested selling price.
1996 BMW 525tds - iBus integrated and OEM look Bimmerstyle Show off your project 65 10-23-2008 12:07 PM
Car 5.1 Dsp Options Vs Pc 5.1 Dsp port20 Car Audio 13 05-29-2006 03:10 AM
VIA and Mini-box Announce First Sub-$300 Car PC Kit Goofus General Hardware Discussion 27 03-13-2006 12:28 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
