Quote: Originally Posted by
jp886913
I am definately open to suggestions on what sound cards would give me a reasonably close or better sound than 210 I am also curious as to if there are any soundcards capable of running a 3way setup
That's entirely dependent on how you plan on controlling your audio....EQ, XO, etc.
You will need 7+ outputs most likely, unless you're using an outboard processor, in which case you just need a single output (optical or analog).
This is all up to you really. Start researching sound cards based on what you will need and make your decisions based on that.
