Quote: Originally Posted by
qpwoeiruty999
oh yeah i found one on ebay, but enden 5days ago...!!
but i hope there will be more for sale soon...
alright i will try to look at your thread
what about the Audiotrak PRODIGY HD2? i has replaceable opamps like the x-meridian..
here is the specs i found:
PCI audio interface based on VIA VT1721 (Envy24HT-S)
PCI card supplied with standard and low profile metal bracket
24 bit / 192kHz playback (analog & digital)
24 bit / 96kHz recording
high quality AKM AK4396 120dB(a) S/N ratio DA converter for extremly high quality 2 channel audio playback via RCA output connectors (5Hz - 40kHz frequency response)
triple OpAmp design for audio output with three high quality Fairchild NE5532 OpAmps on separate sockets (can be exchanged for tuning & customization)
headphone output with 1/8" connector routed via JRC4580 dual OpAmp
analog line input with 1/8" connector via AKM AK5353/7 102dB(a) S/N ratio AD converter (20Hz - 40kHz frequency response)
optical S/PDIF digital output following IEC-958C standard, can be used for stereo audio playback (PCM) and multichannel streams from such sources (AC-3 or DTS data)
EWDM driver for all current Windows Versions
