Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 09-22-2008, 12:41 PM   #1
skydeaner is an unknown quantity at this point
3 way active pc sound card
Will any of them do 3 way active crossovers and at least 4 channel time alignment? I dont have room for a deck and a monitor, so i want to get rid of deh-p880prs and i have a list off parts for my carpc i need except for a sound card. Am i just going to have to buy an active car audio crossover? I know 3 seperate stereo channels (or 2 stereo and 1 mono would be fine) isn't exactly what pc sound cards are made to do. Just let me know.
I have currently in my car, 3 amplifiers. 1 monoblock powers a set of 12" idmax woofers in the rear. 1 stereo amplifier drives the PG 6.5" woofers in my door panels, and the smallest stereo amp drives my 1" tang band tweets in the kick panels. I need all this running perfectly through my car pc lol. If i have to just use one stereo output on the sound card and run it to a 6channel car crossover and use software time alignment that is fine, i just want to find a better way.
skydeaner is offline   Reply With Quote
Old 09-24-2008, 09:29 AM   #2
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
http://www.mp3car.com/vbulletin/high...ns-tuning.html
System always under construction
durwood is offline   Reply With Quote
Old 09-24-2008, 01:10 PM   #3
lol looks like i will just run an active crossover, much simpler.
Old 09-24-2008, 03:10 PM   #4
Car Audio Moderator
durwood's Avatar
Giving up so easy? Why did you psych yourself out? It's not like you have to do much research to make it work. Did you look at the wiki? Or is it a matter of overwhelmed with the options and you wanted someone to say just buy this?
Old 10-05-2008, 10:20 PM   #5
yeah, it just looked a lil too time consuming. I can get a decent 3 way crossover for 80 bucks and i would rather spend 80 bucks than 8 hours of my time. Time is money to me.
Old 10-18-2008, 01:51 AM   #6
HyperZulu is an unknown quantity at this point
I don't mind spending 8 hours to research. My 6 channel crossover died and damaged one of the channels on my 4 channel amp. So instead of spending $150-300 on a new crossover, this may be better.
I have an old SB Live! 5.1 Platinum. Is it possible to just get the kx drivers and the crossover plugin to do 3way active? From what I've read, I can modify the jacks to make three of the four into outputs? I don't know if I wanna do any EQ duties. How is the winamp plugin in this regard? I have a hefty enough computer for processing it all, but I want to keep it simple.
HyperZulu is offline   Reply With Quote
Old 10-18-2008, 02:00 AM   #7
Looks like the winamp plugin is ok. It does 31 bands but nothing cool like the ability to tune individual channels or at least modifying each output individually. I guess that's OK 'cause the channels won't really overlap, but it is nice to notch down any peaks which only exist in a certain set of drivers without cutting output of another set of speakers.
Old sound card....ARRRRRRRRGH! jontz General Hardware Discussion 5 01-13-2008 11:51 AM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
Does sound card quality matter for optical out? PhatMo Car Audio 4 03-22-2007 10:15 AM
got sound? masch Newbie 20 11-17-2003 10:01 AM
