Quote: Originally Posted by
hartigan
Is the DA processing done before the signal is sent down the cable or after?
NO DA processing before the signal is sent. Take the CD audio for example, the signal itself is digital, no need convert to analog before send via TSOLINK
hartigan
The reason I ask is because some people purchase high-end sound cards with 24-bit DA converters and such. Is there any fidelity benefit to that type of hardware if using a TOSLINK cable from the on-board audio/sound card to the amplifier?
high-end sound cards with 24-bit DA converters is for it's analog output
Quote:
I'm planning on running a TOSLINK cable directly from the back of my Zotac IONITX-A-U (Uses a Realtek Azalea ALC622 5.1HD) into my Zapco DSP6-SL. If the Zotac is just sending the unprocessed digital bitstream over TOSLINK and the DA conversion is happening on my Zapco DSP, I don't see any need for a high end audio solution on the CarPC side of things. I'm assuming that the Zapco does this processing.
It seems that the high end sound card has more advanced function to process digital signal. One of them is "improve sample rate", for example, improve CD 44.1KHZ to 96KHZ. Another important point is high end sound card can hanle "Jitter" better. Note that Jitter is the killer in digital audio.
I have another question: if play mp3 on PC, what signal will be sent via TSOLINK? mp3 stream or uncompressed PCM stream? if is the latter, who decode the mp3 stream? the player software or the sound card?
