Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 07-22-2009, 01:31 AM   #16
_Dejan_'s Avatar
_Dejan_ is an unknown quantity at this point
Quote: Originally Posted by soundman98 View Post
becaue console only supports one asio device for both input and output, you are going to end up either using asio4all, or will be looping the audio through the soundcard(looping it through multiple devices is the least efficient method)...
i would have to say that any of those cards are going to work.
Ok if Im understand you. Console support only one device this mean If I disable onboard sound card and use another for example Claro Halo XT I can use original ASIO drivers because I will use one device?
After talking with tech support Im 80% to take HT Omega Claro Halo XT sound card... It have swapable OPAMPS, 8xRCA outputs, optical IN and OUT, Headphone out, Line-in, mic, coaxial in&out, AUX-in, CD-in...
_Dejan_ is offline   Reply With Quote
Old 07-22-2009, 07:38 AM   #17
rodweb is an unknown quantity at this point
Just take the time to understand ASIO before you rush in like I did. I bought one of these a couple of weeks ago
See: http://www.cakewalk.com/products/UAUM/UA1G.asp
Despite lots of warnings in the manual about problems with the device not being found and possible problems of swapping it from one USB port to the other, it worked perfectly.
Problem for me is that ASIO does not give you a master volume control so I could not get good functionality out of roadRunner and the Satnav volume punched me through the roof when the sound went from 4% to 100% volume unexpectedly...
RR (and probably CF) needs hte master volume control for full functionality.
There is a recent thread about my experiences, search for my posts.
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
rodweb is offline   Reply With Quote
Old 07-22-2009, 07:45 AM   #18
_Dejan_'s Avatar
As I know with ASIO you can control Master Volume but you can't control Wave volume...
Old 07-22-2009, 07:47 AM   #19
qpwoeiruty999 is an unknown quantity at this point
This holds true in my case also
qpwoeiruty999 is offline   Reply With Quote
Old 07-22-2009, 07:49 AM   #20
The above card has no Master volume control in the windows mixer. RR moves WAVE and Master together. Here was my post
http://www.mp3car.com/vbulletin/road...d-card-rr.html
RodW
Old 07-22-2009, 07:59 AM   #21
_Dejan_'s Avatar
I will look your thread.
In Cf if you don't have enabled "Master as PRE" then move WAWE volume if you enable this then move master volume(If I remember corect).
If your sound card doesn't have Master volume this is little strange because usualy Sound cards have Master volume control...
Another option is using Line Driver with remote for controling output...
Old 07-22-2009, 09:52 AM   #22
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
i can't be sure of CF, but rr uses the windows volume control, so if this is not availible, it wont work (my initial problem was not enabling the volume control option for vac).
soundman98 is offline   Reply With Quote
Old 08-24-2009, 06:56 AM   #23
_Dejan_'s Avatar
I have problem with my ASIO setup :S
I don't know how to "route" all audio to ASIo Input on my soundcard ASIO driver. Can someone help me?
Im try use VAC+ASIO4ALL+Console+VST plugins but without good SQ results. I get some random popping...
What Im do?
In VAC:
Cables: 1
SR: 22050 .. 96000
BPS: 8 .. 24
NC: 1..2
Max inst: 20 Ms per int: 7
Stream fmt: Cable range
Volume control: enabled
Connected source lines: Line
Clock corr.: 100%
ASIO4ALL:
Latency compenstation: 32 Samples(For in and out)
Hardware buffer: disabled(Im try enable it but is same)
Kernel Buffers: 2 (Im try 4 to but is same)
Always Resample 44.1kHz <-> 48kHz: disabled
Force WDM Driver To 16Bit: disabled
Asio Buffer size: 2048 (Im also try 1024, 512, 256)
Can someone help me how to play music direct to ASIO input from CF?
Old 08-24-2009, 03:47 PM   #24
soundman98's Avatar
this is still one of my biggest problems(random pops)-- and i have also been looking for a solution--the problem is that console only accepts one asio driver-- so you can only have one input/output device (the reason for asio4all)
i have gotten the pops to be very minimal by increasing the interupts(in VAC) to the max(i beleive it is 15).
just to let you know, heres what didn't work for me:
vac-- changing the clock speed-- this made it worse- but only briefly made it better, (i still think that there are mulitple clocks that are not being synced properly) changing the type of cable- no difference. changing the cable format type- little difference.
in console, i have also tried changing the syncronization delay(in properties, under the audio tab, it will be at the bottom after selecting asio driver) in console, to both the max, and the minimum, but it doesn't seem to change anything.
and in asio4all, i have am currently running:
latency compensation-- 1024 in and out (max)
asio buffer size -- 2048(max)
don't remember the other settings.
my next step is to find a midi driver for winamp (or at least a way to pipe computer audio into a simulated midi device and bypass vac and asio4all).
this winamp--vac--asio4all--console thing, is like 2 bandaids on a rash...
Old 08-24-2009, 03:52 PM   #25
_Dejan_'s Avatar
Interupts(in VAC) you can increase up to 20.
For winamp and WMP is avalible ASIO plugin so you don't need VAC and ASIO4ALL...
Old 08-24-2009, 04:03 PM   #26
soundman98's Avatar
i am not near my car, so it could be 20, i just remember putting it up to the highest number and it started working better
the problem though, is that you are only allowed the one asio driver(it takes over both the input and output) in console, and are not allowed to mix and match drivers (you can't have asio output, and wdm driver input) if this was the case, it would make software like VAC and A4A useless.
edit: i am also using console to divide the signal to the different speakers, and the wdm drivers for my equipment would only allow on pair of outputs, so i am forced to use some sort of asio drivers to route a signal to all 3 pairs of speakers.
by using a midi driver, i am hoping that i can bypass VAC and A4A, and use the asio driver for my usb soundcard(my soundcard is only output, not any input-part of my issue).
Old 10-06-2009, 01:17 PM   #27
summer69guy is an unknown quantity at this point
did you fidn a way o bypass vac and a4a?
Carputer:
Psu: DCX6.360-H
Mobo: Intel D945GCLF2
Ssd: ssd ocz solid state 30gb
ram : 1024 meg kingston 667 mhz
Sound card : asus xonar d2 pci
Fan : one nexus and one noctua
case : i'm building a new one
summer69guy is offline   Reply With Quote
Old 10-06-2009, 04:51 PM   #28
soundman98's Avatar
i ended up using audio mulch, and am now using the windows drivers for my sound card-- becaue audio mulch allows me to have more than 1 wdm driver output.
Old 10-06-2009, 05:23 PM   #29
could you say me how to do this with audiomulch?
Carputer:
Psu: DCX6.360-H
Old 10-07-2009, 12:24 AM   #30
kross is an unknown quantity at this point
I, too, switched to Audio Mulch, and am happy to be rid of asio4all. I still use VAC for input, but I just use the regular Windows DirectSound driver for output. My audio is happier.
kross is offline   Reply With Quote
PCI Sound Card With RCA? 356Speedster General Hardware Discussion 28 05-12-2009 08:21 PM
sound card recommendation Stealth915 Car Audio 6 02-28-2008 04:47 AM
Old sound card....ARRRRRRRRGH! jontz General Hardware Discussion 5 01-13-2008 11:51 AM
VIA EN1500G Faulty Sound Card? Splash-X General Hardware Discussion 2 12-16-2007 11:27 AM
Any opinions on the Phillips Aurillium external sound card? UMM General Hardware Discussion 1 02-27-2004 04:39 PM
