Now Im back from garage. Im spend 3h with trying to get work DirectSound.
In AudioMulch Im select DirectSound
Then Im for Input device select Line 1(Virtual Audio Cable)
Set buffer to 8192
For Output Im select Speakers (Claro Halo)
Set buffer to 8192
In Audio Input Im assign to SoundIn: Line1(Virtual Audio Cable) CH1&CH2
In Audio Output Im assign to SoundOut: Speakers (Claro Halo) CH1&CH2 (TW)
AuxOut1: Speakers (Claro Halo) CH3&CH4 (SUB)
AuxOut2: Speakers (Claro Halo) CH5&CH6
AuxOut3: Speakers (Claro Halo) CH7&CH8 (MID)
No mather to which Output I connect signal allways play only from tweeters :S So from other speakers I can't get sound.
Console:
If I select DirectSound I can from combobox select only modex which are 2 channel for example something like this:
44100Hz/24Bit/1CH
44100Hz/24Bit/2CH
48000Hz/24Bit/1CH
48000Hz/24Bit/2CH
96000Hz/24Bit/1CH
96000Hz/24Bit/2CH
I think I will change soundcard to some other PCI card which have Internal routing and Windows 7 support but first I must find it...
Quote: Originally Posted by
summer69guy
what is you power suply and your soudn card?
Power supply is M4-ATX which work good. Soundcard is Claro Halo XT
