Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 10-08-2009, 12:58 PM   #61
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
ah, i see. i have lost interest in sq competitions with a car computer for now, mostly because of the extra cost that i can't afford right now (my kicker cvr's in a box thats way too small, and pioneer component tweeters that aren't good for anything but factory replacements). i might think of competing later, but for now, i am the only judge of my cars sound system.
i can definatly see an issue with taking the audio off the onboard driver for a sq setup, and while i have not heard a difference, i will believe you when you say that asio has better quality output--it could be my poor setup that is limiting me.
soundman98 is offline   Reply With Quote
Old 10-08-2009, 01:11 PM   #62
_Dejan_'s Avatar
_Dejan_ is an unknown quantity at this point
Quote: Originally Posted by summer69guy View Post
like me....i relaly find that following some iacas ruel maes my sound better for my tatse too....if i want to most sound quality possible ....i lower my bass a litle....if i play music for Me ...i i know that this deraded a little my frontsage...i add more bass
For me is reversed. I usualy set sub to minimum and use it only to fill range under 63Hz All other range play my front system and I don't like to much bass...
Today Im remove my minipci express UMTS card and will see if I will have crackling/pooping or no... Also Im switch sample rate to 96kHz/24Bit.
As Im say Im hear diference in my audio setup beetween DirectSound and ASIO4ALL too. I have system which can be used for SQ competition(Audison VRx amp's, Hertz Mille speakers...) but I make it for myself...
_Dejan_ is offline   Reply With Quote
Old 10-10-2009, 01:49 PM   #63
popi79's Avatar
popi79 is an unknown quantity at this point
sound quality solution...
go to ebay and
1.get an audigy 2zs or xfi etrememusic.
2.get an pci flex adapter.
3.go to google and find a plugin for winamp called "volume logic" this will actively will take care of your compressed music problems, like ones ore loud the others are low volume; you will not be sorry.
remember: onboard sound is not as powerful as a dedicated sound processor plus you will take load off the cpu also.
let me know if you need more help.
"SUDDEN RUSH OF BLOOD THE THE HEAD (S)"
popi79 is offline   Reply With Quote
Old 10-10-2009, 04:49 PM   #64
soundman98's Avatar
My computer doesn't like pci adapters-it refuses to post once their installed.
After looking over the reviews for the plugin you recommended, I really don't think it is very good at all. It looks like it has not been supported since 2005, and some users have reported fatigue after extended listening sessions- a sign that it is creating psychoacoustics- ie. Tricking the brain into thinking it is hearing something it is not.
There was also a review by a sound expert- who listed exactly what the software does: it makes certain frequencies louder, and others softer, IMO, ruining the audio(ESP. Since it is only a 5 band eq). I really don't think that program could be used in a true sq type install- I think it's deficiencies would be immediatly apparent.
Old 10-11-2009, 04:36 PM   #65
_Dejan_'s Avatar
Quote: Originally Posted by popi79 View Post
go to ebay and
Im not shure for who are you write this post but this "solution" is not acceptable...
1.) audigy 2zs or xfi etrememusic are not SQ sound card.
3.)Are you kidding? Who use WinAmp in car? Many of users use some frontend which is user friendly and optimized for touchscreen... Win amp is good for listening mp3's or any other compressed music at home when you have mouse and keyboard, but for SQ you have alternative players...
Old 10-12-2009, 03:46 PM   #66
kross is an unknown quantity at this point
Road Runner uses Winamp in the background for playing music.
kross is offline   Reply With Quote
Old 10-12-2009, 05:45 PM   #67
_Dejan_'s Avatar
Im think that RR use own media engine, but because I don't use there is no need for thi plugin
I think I will risk and buy/try Audiotrak Prodigy 7.1 HiFi or maybe M-Audio Delta 1010LT and see how work...
Old 10-12-2009, 06:05 PM   #68
Madboy is on a distinguished road
RR uses almost whatever you want it to use - winamp / foobar / wmplayer / itunes / fmod
its up to you..
HeadUnit : Car-Pc | Processor : Soundblaster Audigy 2 ZS | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Hertz HT-25 | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI | Wiring : Sommer , Neutrik
Madboy is online now   Reply With Quote
Old 10-12-2009, 06:41 PM   #69
summer69guy is an unknown quantity at this point
http://chezcaro.forumdediscussions.n...um-ana-t24.htm
loook at this site...there is a ton of sound card ....it is in french...but i think that you will understand...
Carputer:
Psu: DCX6.360-H
Mobo: Intel D945GCLF2
Ssd: ssd ocz solid state 30gb
ram : 1024 meg kingston 667 mhz
Sound card : asus xonar d2 pci
Fan : one nexus and one noctua
case : i'm building a new one
summer69guy is offline   Reply With Quote
PCI Sound Card With RCA? 356Speedster General Hardware Discussion 28 05-12-2009 08:21 PM
sound card recommendation Stealth915 Car Audio 6 02-28-2008 04:47 AM
Old sound card....ARRRRRRRRGH! jontz General Hardware Discussion 5 01-13-2008 11:51 AM
VIA EN1500G Faulty Sound Card? Splash-X General Hardware Discussion 2 12-16-2007 11:27 AM
Any opinions on the Phillips Aurillium external sound card? UMM General Hardware Discussion 1 02-27-2004 04:39 PM
