Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 07-11-2009, 08:05 AM   #1
_Dejan_'s Avatar
_Dejan_ is an unknown quantity at this point
SQ Sound Card
Hi everyone,
Im looking for best solution to use in my car.
For now Im find:
-Auzentech X-Fi Prelude 7.1
-ASUS Xonar Essence ST or STX (but looks like that ST is better)
-Xonar D2/PM or D2X
Im looking for PCI solution, but If is any card better in PCI-E I can use PCI-E x1 on raiser adapter.
I need:
-Work normal on Windows 7
-Work normal in Centrafuse
-Support hibernate/sleep and normaly resume from this states
If I will use sound processor(Audison Bit One) need:
-Optical out which support PCM out 24bit/48kHz
-Mic Input
-2CH RCA out(If is possible balanced)
If I will not use sound processor:
-6CH RCA out BALANCED
-Mic Input
-Crossovers, TA, EQ and phase control on EACH chanel
As Im say It must work in Win7&CF(As I know it doesn't support ASIO).
Thanks for any help.
_Dejan_ is offline   Reply With Quote
Old 07-14-2009, 04:24 AM   #2
efun is an unknown quantity at this point
I have the same question, which sound card is the best solution.
- Audison BitOne
- RR under Windows XP
How about E-MU 404?
efun is offline   Reply With Quote
Old 07-14-2009, 06:01 AM   #3
_Dejan_'s Avatar
- Audison BitOne
How about E-MU 404?
As I know E-MU 404 is USB so is not option...
Old 07-15-2009, 08:13 AM   #4
PCI cards: http://www.emu.com/products/welcome.asp?category=505&
I have a small box to hold the car pc, can not install PCI card.
Any SQ difference between USB and PCI?
Old 07-15-2009, 08:38 AM   #5
_Dejan_'s Avatar
As Im say Im looking for good solution which must have all what I need and work without ANY problems in Windows7 AND hibernate/sleep. USB cards have BIG issues with hibernate/sleep...
Also please wait that first Me find PCI-E or PCI solution and then we will try find solution for you otherwise nobody will not receive answer an all will be mixed...
So can anybody help me with Best sound card for my project? Price is not so important but if will be 1000$ I will realy long think about it...
Old 07-15-2009, 09:14 AM   #6
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
emu, the 404 is a fine selection to work with a bitone.
dejan, all thats needed is a card that either supports the kxproject drivers(some older sound blaster cards--full listing on their site), or has a wdm compatible driver that can be supported by asio4all.
so far, to get 6 outputs, i have used a older sound blaster card and kxproject drivers, a creative x-fi usb card+asio4all, and am currently using a esi gigaport hd+asio4all(my setup went usb becasue i did not have room for the pci card). all of these were setup to have 6 active outputs, using console to handle vstplugins for crossover, and eq.
soundman98 is offline   Reply With Quote
Old 07-15-2009, 09:27 AM   #7
_Dejan_'s Avatar
Hi,
Thanks for your answer.
Currently I don't know if I will continue use BitOne. If in Elettromedia will fix my noise problem then I will use it otherwise I will go for other solution.
Also Im not shure for ASIO because Centrafuse doesn't support it so I can't use ASIO drivers...
Are kxproject drivers supported in Win7?
Regards, _Dejan_
Old 07-15-2009, 09:43 AM   #8
soundman98's Avatar
Hi,
Regards, _Dejan_
i really have no idea if kx would be supported by vista/win7, the project is no longer being updated(i want to say the last update was in 05-06), mostly becasue the chipset that it uses is no longer being manufactured(to my knowledge).
I feel that you are misunderstanding asio slightly, so i will go a little more in depth: there are not any FE's or OS's that support asio, only audio programs like cubase, and console(there are many, many more-they are really called vst hosts). basically you will setup the computer to route its audio through the vst host, and in the host, you modify the audio, and then run it out to the speakers. all of this is done outside of the FE of your choosing.
my setup:
to get audio to my speakers, i have setup a virtual audio cable as my primary audio output in windows, then i have setup asio4all, and enabled the VAC as the input, and my audio card as the output in its menu, when i open up console, i go to asio devices, and the VAC shows up as a input, and my audio card shows up as a output. from there(every program is different, this is how console is setup...)i drag my input(VAC) onto the screen, and output(gigaport) onto the screen, and then add any crossovers and eq's that i feel i need. after that i make connections(wire all the devices) and setup the audio however i need to.
after this, i lauch rr and will hear music(now thats all that matters ).
Old 07-15-2009, 10:57 AM   #9
_Dejan_'s Avatar
hi,
I don't know nothing about ASIO but I will start reading about it...
Also Im not shure if this will work in CF because CF use normal mixer for volume and sound output...
RR can use plugins in winamp so can work with ASIO if Im right understand in few posts when Im see that talk about ASIO...
Old 07-15-2009, 11:31 AM   #10
soundman98's Avatar
hi,
there is a asio wiki that you should take a look at. I had been in the same boat, as you-- knowing nothing about it, and tried to read everything that i could on it, but just ended up confused and wondering if it would work. (in fact my thread is a couple below yours-- its called ASIO questions and setup)
after downloading console, and the other programs, and playing with it, it all just started to click into place.
i currently am not using any plugins with either winamp, or rr-- this is where the virtual audio cable comes in-- by setting windows to use the VAC for sound output, any sound that the computer generates goes directly into my audio setup--it doesn't have a choice... i am not very familiar with cf, but i beleive that my exact setup would also work with cf (becasue i am routing the computer audio instead of just the winamp/rr audio).
console supports a couple different driver types, so as long as your onboard sound has a wdm driver you should be able to use console-- i would highly recomend that you download the demo to try to understand how this all works--it sounds very complex once it is all written out... but once you get it in front of you, it should be much easier to understand.
Old 07-15-2009, 01:17 PM   #11
nalav's Avatar
nalav is on a distinguished road
It mostly depends on the hardware. Cheap USB devices won't have the hardware they need to produce high quality sound, but this is the same with PCI. Possibly the biggest difference is that it's able to be located outside the computer case, which potentially takes it away from electrical interference from the computer that could be affecting the sound. Though only audiophiles might notice a difference in the sound from this. The higher priced USB sound devices, just as the higher priced PCI sound cards, will be able to produce better sound quality. There is no inherent sound quality loss or gain simply by using USB, other than a few ms of latency that you won't even notice.
nalav is offline   Reply With Quote
Old 07-16-2009, 09:26 AM   #12
The reason I post here is trying to find the solution about bitone, sorry if mixed up this post
Old 07-16-2009, 01:33 PM   #13
_Dejan_'s Avatar
I think for use with BitOne is best USB-SPDIF "adapter" Why?
It doesn't need drivers(Problem with Hibernate/sleep solved).
But Im not shure if I will continue use it...
Regards, _Dejan_
Old 07-20-2009, 11:04 AM   #14
_Dejan_'s Avatar
Ok new Info.
-Card must be on PCI slot
-6 outputs, 1 mic input
-ASIO support(Console and VST plugins for crossover, TA, EQ)
So models for which I know:
-Asus Xonar Essence ST + H6 DAC board (Can't find anywhere)
-E-MU 1820 (Discontinued product and need aditional "Box")
-Asus Xonar D2
-Auzen X-FI™ Prelude 7.1
-HT Omega Claro Plus+ (ASIO???)
-CLARO halo XT (ASIO???)
Old 07-21-2009, 03:10 PM   #15
soundman98's Avatar
becaue console only supports one asio device for both input and output, you are going to end up either using asio4all, or will be looping the audio through the soundcard(looping it through multiple devices is the least efficient method)...
i would have to say that any of those cards are going to work.
PCI Sound Card With RCA? 356Speedster General Hardware Discussion 28 05-12-2009 08:21 PM
sound card recommendation Stealth915 Car Audio 6 02-28-2008 04:47 AM
Old sound card....ARRRRRRRRGH! jontz General Hardware Discussion 5 01-13-2008 11:51 AM
VIA EN1500G Faulty Sound Card? Splash-X General Hardware Discussion 2 12-16-2007 11:27 AM
Any opinions on the Phillips Aurillium external sound card? UMM General Hardware Discussion 1 02-27-2004 04:39 PM
