Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 08-04-2009, 02:25 PM   #1
Madboy is on a distinguished road
Asio ( Console/AudioMulch ) + Kx + Hibernate
hi all
im sorry in advance if its not the right section
this topic involves many topics and i tought it would be the best place to get answers from
now for the issue
im having problems using asio with kx and hibernation
im using kx 3545b with audigy 2 zs ( sb0350 )
on win xp pro sp3
routing :
winamp ( hqprocsoft + ks ) -> kx recording to asio -> console/audiomulch -> src 2/3 , 4/5 , 6/7 -> kxlt ( profx ) output to amps
the problem im having is when i return from hibernate with audiomulch/console
i need to restart the asio audio output ( power on console / enable audio on audiomulch )
after that everything works ok
i figured out that the vst shells are trying to access asio before its initialized
i found some "solutions" and ill describe what i tried
option 1 :
using hibernate trigger to close audiomulch before hibernating
and open it after
*tried using both autoit3 and just a regular command line
good :
it works ok and i get sound
not good :
for some reason hibernate trigger opens up multiple audiomulch's ( varies between 2-10 ) - couldn't trace what im doing worng
because of the multiple intances of audiomulch i get sound about 10 seconds after returning from hibernating and also audiomulch windows on top of my frontend ( rr )
option 2:
installing kx 3548
just a couple of days ago a new version of kx drivers were released which supposed to fix this problem
good :
i get sound after hibernation
not good :
sound is wierd and distorted - doing the enable audio thing again works
i reported this bug on kx forum , hopes it will be fixed soon
option 3:
click on enable audio without clicking it
for now im using this command in a button in rr ( using kanakey ) :
ACTIVATE;audiomulch||RUN;c:\Kanakey.exe|ALT C RETURN
good :
it works
not good :
need to manually press the button
ok now for the questions :
1.hibernate trigger
anyone with a solution for this?
i tried searching here and google on this issue and couldn't find nothing
2.anyone knows a way to "activate"/"getfocus" outside rr that i can write a command line for hibernate trigger just to press the enable audio button?
3.can anyone think on a different way to fix this issue?
4.anyone else using kx and asio and not having this problem?
important to say that i don't want to give up on hibernating cuz i don't want to wait a minute for my system to cold boot..
thanks alot in advance ,
madboy
HeadUnit : Car-Pc | Processor : Soundblaster Audigy 2 ZS | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Hertz HT-25 | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI | Wiring : Sommer , Neutrik
Madboy is online now   Reply With Quote
Questions/issues on Horm and Hibernate shahabmusic WinNT Based 1 05-04-2009 10:03 PM
Sound Processing and X-Meridian qpwoeiruty999 High End Solutions 11 01-13-2009 08:15 AM
ANOTHER hibernate problem.. YES I SEARCHED turbochris General MP3Car Discussion 4 02-06-2007 10:45 PM
Audio crash after hibernate (USB alerts) Peoples RR Bug Tracker 11 03-10-2005 02:29 PM
USB Sound Card with ASIO driver and volume control tbdombrosky General Hardware Discussion 0 02-04-2003 12:00 AM
