Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 09-09-2009, 05:36 PM   #1
egoaudio is an unknown quantity at this point
Sound card for 3 way front stage + sub
Hello all,
I'm a newb to the carpc world but not to car/home audio. First off want to say thanks to those who make this site what it is. Secondly, thanks in advance for the help that you are willing to give if you respond to this thread.
So I'm going down this carpc road and atm all I really want to do is:
1. Store and access music easily.
2. The power to adjust crossover points, slopes, phase, time alignment, eq, signal level easily.
Since I have a three way front stage plus sub I want to be able to process all of these within the computer. I am aware that I need a nice sound card, will this one do for the front stage:
http://www.mp3car.com/vbulletin/clas...soundcard.html
I might only need this since the sub could receive signal from a pass through and be crossed over via amp.
While we're on the subject, what are your opinions on external sound cards? Such as:
http://www.pssl.com/!kwhp91n8iGebgG5...io-Interface-s
Also, wondering about processing power. How much is sufficient? There are a couple car comps in the f/s section that seem like they would work fine:
http://www.mp3car.com/vbulletin/vbcl...?do=ad&id=2012
http://www.mp3car.com/vbulletin/vbcl...?do=ad&id=2477
http://www.mp3car.com/vbulletin/vbcl...?do=ad&id=1783
One of the new items f/s on mp3car is the fanless intel pc:
http://store.mp3car.com/product_p/ccc-207.htm
Would that be enough processing power for running asio with vst's for processing along with an interface program like roadrunner for selecting songs?
Best regards,
Erik
Last edited by egoaudio; 09-10-2009 at 08:53 PM. Reason: adjust wording, ask another question.
egoaudio is offline   Reply With Quote
Old 09-10-2009, 11:12 PM   #2
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
it looks like you are on the right path-- i have the esi gigaport, and, if i had a infinite amount of money, i would have swapped it out by now...
the problem with the gigaport is that its driver only supports asio output, and all audio programs only support 1 asio driver for both input and output, with no option to load any other drivers, so you must figure out another way to get the audio either into the audio program, or out to the card, or both.
i have currently been having problems using vst eq's--they will cause pops and delays in the audio stream. i am unsure were the problem is originating from, but is corrected by removing any vst eq. i am currently using a intel 945gclf with 1.2ghz (i think?) dual core atom processor, 2gb ram, and have 6 crossovers setup (highpass, and low pass for a active 3way setup), all at 4th order. it stays around 50-60% cpu usage during normal use.
as for accessing the audio processing easily, it is just not possible--
here is a pic of my dash with Console brought up(i changed my config a little, but you get the idea) on a 7" liliput 629GL monitor:
it would be downright dangerous for me to tweak anything in console if i wasn't parked, and even if your were the passenger, it would still be hard (i need to lean forward to see what i am doing on the screen).
soundman98 is online now   Reply With Quote
Old 09-11-2009, 12:13 AM   #3
Thanks so much for your response. Nice to know someone has gone down a similar road.
So let me see if I've got this straight about the asio stuff and the gigaport:
The gigaport will not allow you to input the audio stream into a program for modification?
It only allows for the audio to be output? How did you get around it?
Anyone know of other sound cards that allow for both? This one looks like the ticket:
http://www.amazon.com/Asus-Xonar-Del.../dp/B001I2ERS0
To bad about the adjusting not being easy. I've been accustomed to the pioneer deh-p880prs head unit which has an awesome interface for processing. I've just been looking for something with more options.
This is somewhat discouraging but I'm glad that you're telling me this now so I don't continue thinking it's that easy.
Wow, 50% processor usage. That's kinda high. Would more ram help?
I'm going with an 8" screen if everything seems feasible. Hopefully the extra inch will help a bit.
I've got a few computer programmer friends who may be able to wright a program interface making console more user-friendly for our "audio 3/4 way" situation.
Best regards,
Erik
Old 09-11-2009, 06:12 AM   #4
_Dejan_'s Avatar
_Dejan_ is an unknown quantity at this point
Just few hints:
1.) Sound Card must have ASIO AND Internal Routing(DirectWire, ReWire or something similar)
2.) SC must have as possible low crosstalk, and maybe swappable OPAMP's(Not must but is good feature)
3.)A lot of CPU power min. Dual core 2GHz especialy if you would like watch movie(DVD) otherwice your sound will sturtering if you will run CPU intensive application...
4.) You need "basic audio skils" how to setup crossovers, TA...
5.)For VST host is best to use Console or AudioMulch(I use this now).
6.) Look for phase linear or FIR filters(Electr-Q Full version)
7.) For TA I think is best/easy Voxengo Sound Delay
8.)Maybe you can look for DRC(Digital Room correction)
9.) Happy tuning
_Dejan_ is offline   Reply With Quote
Old 09-11-2009, 11:23 AM   #5
Cycfari's Avatar
Cycfari is an unknown quantity at this point
I temporarily stop pursuing this option as I found much difficulties getting all the programs to work nicely on my test PC. I tried VAC->VST's in Console->Asio Out. Major problems that I still can't overcome :
1. ASIO Volume control within RR / Frontend
2. Auto & error free Startup of VSTs upon PC bootup or return from hibernate
3. Some Software min screen resolution are > 800 x 600 (my screen res)
So far I've only tried to configure it in Stereo mode (2 Channel) with my DAC. Once I can get it right, I'll try it out with the ASUS D2 Xonar with 6 outputs for 3 way active Front Stage.
Cycfari is offline   Reply With Quote
Old 09-11-2009, 11:33 AM   #6
Quote: Originally Posted by _Dejan_ View Post
Just few hints:
Check, this unit seems like it will work:
http://www.m-audio.com/products/en_us/Delta1010LT.html
I'll just have to go the custom built pc route since it doesn't look like the prefab pc's accept internal sound cards in their tiny enclosures.... unless using a 90 degree pci adapter, even then it would be a tight fit I'm sure.
I couldn't seem to find a crosstalk specification. What am I looking for here?
This should fit the bill:
http://www.newegg.com/Product/Produc...82E16819116072
Zero problems here.
THank you for the recommendation. Those were the two that I have seen many using. I'll give them a try first.
Check
Check
Check
9.) Happy tuning
Thanks abunch for your suggestions Dejan.
Old 09-11-2009, 12:53 PM   #7
soundman98's Avatar
Just few hints:
9.) Happy tuning
great summary Dejan! personally, i have never tried audio mulch, and have only watched the youtube demo videos, but based on that, i would have to say that Console and Audiomulch are very similar-- it is really personal preferance to which one you pick-- like deciding between honda and toyota (i think audiomulch includes a bunch of plugins, whereas console doesn't, but is cheaper...)
as far as getting the esi usb card to work, i have resorted to using the windows wdm drivers, and asio4all to get it to work...not the best solution, but it works...
for the processor usage, you must remember that each vst plugin uses some amount of cpu resources, some more than others, and these can add up very quickly--i really don't think that 50% is all that bad--when i first started playing with everything, i tried 3-31 band parametric eq's(where you can adjust both the frequency, and the level)...the system went up to 100%, and then bsod a couple minutes later (i also had a problem with a different usb soundcard then, so it might have just been the soundcard causing the bsod)...
if i get a chance over the weekend i will post some screenshots of my current setup and the Console display screen that shows how much resources are going to each individual plugin. i also have some faulty drivers on my system, so that also tends to slow it down some...and running programs in the background (winamp playing FLAC files, and gps logger).
Old 09-11-2009, 01:25 PM   #8
soundman98's Avatar
0.5:how are you sending vac into console, and then using asio out? (i would really like to do this in my setup)
1. using VAC, you will need to enable volume control, and set it to the windows default sound output.
2. auto startup is as easy as dragging a shortcut of your saved setup to the startup folder. dejan created a software at some point to turn off the opwer button, and turn it back on after hibernation? i think? dejan?
3. not one of my biggest problems, but it is slightly anoying to have a plugin control screen take up the Entire display...
here are some screenshots of listed cpu usage and console usage-- also not, that with rr minimized, cpu usage dropped to about 30%...
Old 09-14-2009, 06:18 AM   #9
_Dejan_'s Avatar
1.) If VAC doesn't work then you will hard find solution. Maybe Jack can do this...
2.)Im have problems with resume from sleep/hibernate with Console(like it do not turn on all VST plugins and sound come only from few speakers) with AudioMulch I don't have this probelm with SAMA VST plugins...
3.) this is hard to do on small screen... I currently work on 1024x786 and is hard too... As Im see AudioMulch have some remote option but Im not shure if is for configuration... Other option is edit crossovers on your desktop pc and copy it to carpc...
@egoaudio:
1.) If have Intrernal routin(If I remember it have it) is ok choise
2.) You can see crosstalk graph on some reviews or tests...
3.) It will be ok also you can overclock it
4.) Great
5.)Test BOTH because is avalible Trial version for both VST hosts. I use AudioMulch because with Console Im have problems after resume from sleep/hibernate...
Yes Im write one application which start Console(You can select saved file too to direct open your configuration), then turn on Console and minimize it...
Now I fill start writing plugin for CF which will have same option, but you can switch beetwen configuration files(example: SQ Setup, More Bass setup, SUB off setup...) and restart application on resume from sleep... First I will make it for AudioMulch later for Console too..
Old 09-16-2009, 01:17 PM   #10
Alright everyone, thanks for all the input! I've got my laptop functioning properly with audiomulch and winamp as my front end. Also everything autostarts as desired so all is well here. I'm really only using the carpc for music so I think the arby's winamp skin is the best fit for me. I've only got one last thing that I want to add........ remote control.
What kind of remote control solutions are you guys running?
Ideally, I'm looking for a basic control unit. Play, next, previous, pause, etc. But one "advanced feature" I want on it is the ability to choose different playlists quickly. Here is a shot of my screen.
Maybe a software that allows for mapping buttons into winamp? I don't have much programming experience so I won't be able to build a program to do this..... wish I could. I've looked into girder but I can't seem to get it to work with this remote:
http://www.pioneer.eu/eur/products/2...510/specs.html
Maybe it's the infrared sensor that I'm using. Any suggestions for IR sensors for this software?
Any advice will be much appreciated.
Best regards,
Erik
Old 09-16-2009, 01:34 PM   #11
This looks like it would be fun. I can mount my own buttons for it anywhere I want!
http://www.ultimarc.com/ipac1.html
EGO
Old 09-16-2009, 05:17 PM   #12
Or better yet, instead of individual buttons, I can link them to a n 8 way joystick and fab something up to fit in my ride. Maybe in one of the cup holder for easy access!
http://www.happcontrols.com/joysticks/50800010.htm
EGO
Old 09-16-2009, 09:01 PM   #13
soundman98's Avatar
look in the build section-- there was a recent build in a white civic that only uses a small numeric pad to control everything. in one of the posts he lists the program he used to map the keys to different functions.
the pioneer unit will not work easily-- there would be a lot of programming involved.
look around for media center remotes-- most of these should be able to do everything you want.
Old 09-30-2009, 12:43 AM   #14
Alright everyone. I took the dive and have all of my components functioning. My sound card is the m-audio 1010lt. My computer is just like this one:
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
I have Audiomulch lined up with asio settings and I have all my signals routed appropriately for a 3way front stage plus sub............ Here's my problem:
There seems to be distortion every time the bass hits a little bit. I've tested the audio on my HIFI home theater towers, my studio monitors and on raw woofers... All the same type of distortion. I should also mention that I have individually tested each and every vst that I have downloaded and regardless of whether there is a vst in the audio signal, there is distortion in the signal, most noticeable in the bass region (45-160) but I can tell there is something off in the entire signal as well.
I have also tried 4 different pairs of RCA's. I am positive this is not the problem.
Any ideas?
I have also gone straight from the audio input in audiomulch to the audio output and there is still distortion. Where could this be originating?
Winamp? Already checked to make sure EQ was not on.
Any assistance will be greatly appreciated.
Best regards,
Erik
Old 09-30-2009, 02:57 PM   #15
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
I suspect it is a driver issue and/or audio stream problem.
Looks like you have Windows 7 or Vista?
Which audio stream from winamp are you using? WAVE, Directsound, ASIO or Kernal Streaming audio stream?
People testing Windows 7 on the m-audio forums have indicated if using Kernal Streaming output in foobar/winamp might correct crackling .
Also, make sure you have muted the SW RTN on channels 1-8 in the driver control panel. For more details see here.
http://www.mp3car.com/vbulletin/high...ml#post1158758
OT: Did you finish your home array project?
System always under construction
durwood is offline   Reply With Quote
sound card recommendation Stealth915 Car Audio 6 02-28-2008 04:47 AM
Old sound card....ARRRRRRRRGH! jontz General Hardware Discussion 5 01-13-2008 11:51 AM
usb sound card gti4dr General Hardware Discussion 2 10-16-2007 08:24 AM
Can anyone recommend a USB sound card? jedi7001 Car Audio 1 10-17-2005 09:06 PM
Need advice on which sound card to use mtmsol General Hardware Discussion 2 06-22-2001 01:39 PM
