Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 11-03-2006, 03:04 PM   #136
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
THE XFI is using a whole new dsp chip.
System always under construction
durwood is offline   Reply With Quote
Old 11-03-2006, 03:18 PM   #137
joesmith136 is on a distinguished road
That sucks
joesmith136 is offline   Reply With Quote
Old 11-03-2006, 03:21 PM   #138
Dragonknell911's Avatar
Dragonknell911 is on a distinguished road
Yeah, but it's a good reason to stick with the audgiys if your going cl anyways
like this one
REBUILDING!!
Dragonknell911 is offline   Reply With Quote
Old 11-03-2006, 03:24 PM   #139
Car Audio Moderator
durwood's Avatar
Quote:
That sucks
Agreed. The XFI is using a much better chip with more resources available. The 10k1 and 10k2 chips used in the live,original audigy and audigy 2 have been around for so long. One can only hope the Kx project is expanded.
Old 11-03-2006, 03:27 PM   #140
Car Audio Moderator
durwood's Avatar
like this one
I don't think the audigy 4 is supported either. Nothing later than 2. Even the newer audigy se and value are not supported.
Correction: Audigy 4 is partially supported.
http://kb.kxproject.lugosoft.com/list.html
Old 11-03-2006, 04:54 PM   #141
XC-C30's Avatar
XC-C30 is on a distinguished road
well, those hwo have a non-kx-supported card, can still use the thuneau frequency allocator.... downside: $90, but hey, life isn't free and it never will be. I'm probably gonna test it out soon (somewhere januari-februari, I think). So I'll let you guys know how it went.
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 11-05-2006, 01:46 AM   #142
Car Audio Moderator
durwood's Avatar
I just tried it out yesterday and I hope you have a fast processor. Here is what I tested it on...
Pentium 4 2.6 ghz 800Mhz FSB HT
512MB DDR400
Audigy1 PCI
KX driver
ASIO4ALL installed and active
Winamp with ASIO out and VST plugin
Frequency Allocator Demo running
~40-50 CPU usage!
I think my poor mini-itx carputer would choke.
Anyone else tested it yet?
Old 11-05-2006, 02:11 AM   #143
XC-C30's Avatar
well, I had a duron 800 I was going to use, but since the minimum requirements of the FA are P4 2.0, I'm looking to buy something faster with a mobile CPU. and that's a hell of a lot CPU usage hope I can find a 3.2GHz mobile CPU or something than and apart from the fairly high CPU-usage? any comments on features and use?
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 11-05-2006, 08:34 AM   #144
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
yeah - this was what I was worried about.
I'm looking to rebuild my carPC, and have been looking at 3.0+ GHz desktop processors.....looks like I'll have to stick with em...
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 11-05-2006, 11:33 AM   #145
well the most portable/smallest fastest computer I have is a tosihba satelite with a desktop 2.8 ghz in it
REBUILDING!!
Old 11-05-2006, 10:33 PM   #146
XC-C30's Avatar
looked up some CPU's, might considder to but a DSATX. An M2 won't supply the needed output.... Most 3G+ cpu's are70+ watts +about 15-20watts for memory, so you won't get there with only 96watts that the M2 supplies on the 12v
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 11-05-2006, 11:25 PM   #147
Car Audio Moderator
durwood's Avatar
Just string multiple M2's together and it will be fine. There is a recent thread on it in the power section.
I didn't get a chance to fully test FA. I was playing with the demo (which might limit what features I can use) and all I got out of my home speakers was low frequencies. The routing was a bit strange so I might have to experiment later some other time.
Old 11-05-2006, 11:46 PM   #148
XC-C30's Avatar
yeah, I know, you can use multiple M2"s, but that"ll cost as much as 1 DSATX. yeah I know, that way you can add more equipment lateron... but are you gonna do that?
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 11-06-2006, 12:58 AM   #149
I'm pretty sure 15-20 watts is an over exageration for ram, unless you meant two modules
REBUILDING!!
Old 11-06-2006, 01:03 AM   #150
btw, http://www.newegg.com/Product/Produc...82E16813170012 , heres a good option for a small powerful crazy expensive pc
oh and this one:
http://www.logicsupply.com/product_i...roducts_id/489
REBUILDING!!
AutoTap used to develop custom software! Dodger1417 Engine Management, OBD-II, Engine Diagnostics, etc. 5 09-25-2006 11:51 AM
comparison of GPS Software gunsandrosses Newbie 4 06-28-2006 10:56 PM
CarPal Bluetooth Module & Digimoto Software....A Very Good Combo.. jmciver Engine Management, OBD-II, Engine Diagnostics, etc. 6 06-16-2006 05:08 PM
Sony Vaio PCV-RX670 w/Sony 15" flat panel thousands of $ worth of software, mint clean customs Classified Archive 2 11-15-2005 02:38 PM
CoPilot Software or USB GPS Receiver package Zip-Lock Classified Archive 5 05-13-2004 08:30 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
