Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 11-10-2006, 12:03 PM   #181
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Quote: Originally Posted by turbocad6 View Post
my first thoughts along these lines were that it will be processor intensive... my second thoughts were to use a dedicated machine for this, & then another as the actual carpc...
I mean the alpine is a dedicated box, so this could be too... a kvm could keep this managable through one screen... I don't know if I'm the only one who would consider multiple machines though... I have 2 motherboards going in my minivan right now, one for front & one for rear... adding a 3rd wouldn't be that intense for me....
I'd be afraid trying to run everything on one machine will cause issues, maybe a really fast dual core with a system that can take advantage of this, but I would rather do independant pentium m machines.....
so how crazy is running a dedicated machine for audio processing? would anyone else consider this?... imagine if it could run on linux... it could be kinda like the alpine in the end, BUT with everything we'd want... best audio quality with pc interface.... is this a consideration? I don't know enough about linux to do this, I guess a stripped down xp machine could do this well too.... maybe an xp embedded solution.....
Ya I was begining to think the same thing. It would be a total geek cool factor. I know for competing it would help me out because there is usally points for having an external processor. Having it all built into a headunit/computer just doesn't seem to count...BASTARDS! I look at it as an expense and space factor though. I liek that everythring I have takes up as little as space as possible and is hidden with still plenty of trunk room. Hmmm...
System always under construction
durwood is offline   Reply With Quote
Old 11-10-2006, 12:18 PM   #182
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
I'm not willing to consider multiple machines at this point. I simply don't have room for it.
Since I'm not concerned with ultimate sound quality while watching DVDs (which I don't do) and since I'm not concerned with audio in 5.1, I'm feeling that it won't be nearly as intense as the guys over on DIY are experiencing.
I'm also looking at running a micro-atx board with a Pentium D 3.4 GHz and 2 gigs of ram to do this.
Sure, powering it will be difficult, but there are ways around that now.
regarding linux - there were some guys int hat DIY thread that were talking about it, not sure if anyone followed through on it though.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 11-10-2006, 12:35 PM   #183
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
I guess this is true too... with a simple stereo setup there will be only 5-6 x-over points... I'm assuming the xovers will be the most intense part of processing...
turbocad6 is offline   Reply With Quote
Old 11-11-2006, 09:08 AM   #184
_
all, I've posted over there at DIY, but it seems my post has fallen on deaf ears since it's for a car and not home audio.
If some of y'all could possibly post over there and encourage a bit of conversation and show that there is a good deal of interest in this in a car, perhaps we could get a bit of talk rather than a bunch of folks who look down their noses at car audio....
Jan Bennett
Old 11-11-2006, 11:29 AM   #185
Car Audio Moderator
durwood's Avatar
On my way over....
Old 11-11-2006, 12:04 PM   #186
Car Audio Moderator
durwood's Avatar
Hey RED-
I posted over there so we will see. Also that wave program they are using looks like an EQ based program. You can pretty much use an EQ as a filter. FIR filters are harder to design than IIR filters- (a digital based analog filter/crososver) because there are not easy models to base them off of. It's probably easier to design an EQ based on FIR filtering. I wish I could explain it better but I am extremely rusty on my knowledge of it. I was doing a little research to jog my memory but I never seem to have time to get it done.
Old 11-11-2006, 02:08 PM   #187
FyreDaug's Avatar
FyreDaug is on a distinguished road
Heres something that I dont know if it has been mentioned or not. Heres my situation:
I have 2x200gb hdd full of music, .ogg, .flac, .mp3, .wma. The oggs and wma are few and far between but between the mp3 and flac I have some problems.
The 31band EQ in winamp will ONLY have an effect on lossless music, IE, my flacs, I can also not use the winamp bass/treble controls (which I like to keep both at -4% just to take a little edge off, but sometimes I turn it down to -25% on the bass for some songs, as its just easier to fiddle with instead of opening the eq.
The mp3 songs work fine with the winamp controls, but have 0 effect with the eq. I tested this by obviously using a flac and mp3 of the same song (which Roxette- The Look happened to be the test subject) and clearly 31bandeq=flac files
winamp bass/treble = mp3 files
I used to use this 4front EQ. Its 10band, but im going to test it out again with mp3 vs flac and see if it works for both. If it does, it looks like I have to downgrade my EQ.
FyreDaug is offline   Reply With Quote
Old 11-11-2006, 02:14 PM   #188
Car Audio Moderator
durwood's Avatar
Hmmm.. I used it sucessfully on mp3 files and cd audio files. I don't have any FLAC files. I'm using Winamp 5.24 and the vst plugin configured to use the free vst EQ from the first page of this post.
EDIT: I noticed every now and then it freezes on some mp3s when using ASIO output plugin only.
Old 11-11-2006, 09:24 PM   #189
FyreDaug's Avatar
"freezes" as in winamp locks up? I have that problem sometimes if thats what you are talking about. its kinda rare.
But it has NO effect on any of my mp3's, why would that be?
Old 11-13-2006, 08:11 AM   #190
Car Audio Moderator
durwood's Avatar
Yes, Winamp locks up. Probably just bad MP3's. I don't really know though.
I am not sure about your strange problem. Just remember though that a 31 band EQ makes small adjustments versus a 10 band. If you adjust a bunch of bands that are close together then you should see a more drastic change. If you notice a difference on the FLAC files though then you should notice a difference on your MP3's on any changes you make. What is your software/hardware setup exactly? I need more information and I will try to duplicate your problem.
Old 11-14-2006, 05:44 PM   #191
nubz69 is on a distinguished road
There is no need for a second computer. There is a need for a relatively powerful computer. I was able to run multiple plug ins as well as VSTi's on my old 1ghz AMD computer. What we are talking about here is very feasible with todays technology. I would post more of what I know here but I am moving to FL in Jan so I have very little time right now. I feel there are more then one way to achieve our goal. The questing I am pondering now is whither we should go about this project as an all in one solution (OS,media player,tuning,GPS) or should we attack this by adding to and modifying existing techniques? I feel the former would work better in the end but I feel that to truly make it would we would need to use a Linux based OS. The latter could work with windows or linux.
nubz69 is offline   Reply With Quote
Old 11-14-2006, 09:23 PM   #192
Abmolech is on a distinguished road
There are several reasons I decided to use a car pc for processing duties.
One of which is to do non-linear volume control off a single point. The idea is to maintain "C" weighting at any dB.
Is there a VST plugin available?
Abmolech is offline   Reply With Quote
Old 11-15-2006, 07:41 AM   #193
Car Audio Moderator
durwood's Avatar
Could you elaborate why you want to use "c-weighting" over "a-weighting". Do you have any proof that the volume control used by the computer/program uses "a-weighting"?
BTW: I am not using the computer to do my volume control at the moment, but I will be hopefully in the future.
Old 11-15-2006, 11:13 AM   #194
Most volume controls are "linear". Sure your pentameter is logarithmic, however so is dB rating.
Let us assume we set our system for "perfect" volume listening at a certain dB.
As soon as we change this dB (move the volume knob) then we start to move away from the "perfect" listening weighting.
http://hyperphysics.phy-astr.gsu.edu...nd/eqloud.html
The above site is quite good on human hearing. If you observe the loudness curves you will appreciate the different requirements and dB. The "standard" is 1000 Hz, as you change this dB notice the upper and lower frequency dB requirements deviate from the original point.
"C" weighting approximates these settings. (supposedly if you set your RTA microphone on this, you should aim for a "flat response")
How important is this?
I believe dB differences are the primary reason for a system sounding better/worse. In-fact I will go as far to say this THE main criteria for discerning difference between various electronic components. If they are level matched it is very difficult for human hearing to pick variations in most electronic equipment.
This loudness curve is the primary reason for the eq "smiley face" and peoples eternal fiddling with it. I suspect if this was setup to maintain this curve then much less "tuning" would be the result.
Old 11-15-2006, 11:58 AM   #195
Car Audio Moderator
durwood's Avatar
The reason I am bringing this up is that in SQ contests there is a section for linerarity at different volume levels. I had problems in this area at lower volumes. My volume control was adjusted using an Audiocontrol Master Volume control. It was a totally analog volume control. My guess is that it was linear.
I am interested in what you are saying because it could prove to be useful, but when you say "maintain c weighting" is that "c-weighting" to measuring equipment, or to the human ear (which is really a-weighting)? So you want a system that adjusts for equal loudness or basically alters the resposne based on the "Fletcher-Munson curve"? Am I understanding you correctly?
The problem you run into is that human hearing differs from measuring equipment. When they speak of C-weighting is good for home theater applications, then it goes against how we listen. How often do we listen at high volumes? Just because it has flat response doesn't always mean it sounds good all the time. Help me out here.
AutoTap used to develop custom software! Dodger1417 Engine Management, OBD-II, Engine Diagnostics, etc. 5 09-25-2006 11:51 AM
comparison of GPS Software gunsandrosses Newbie 4 06-28-2006 10:56 PM
CarPal Bluetooth Module & Digimoto Software....A Very Good Combo.. jmciver Engine Management, OBD-II, Engine Diagnostics, etc. 6 06-16-2006 05:08 PM
Sony Vaio PCV-RX670 w/Sony 15" flat panel thousands of $ worth of software, mint clean customs Classified Archive 2 11-15-2005 02:38 PM
CoPilot Software or USB GPS Receiver package Zip-Lock Classified Archive 5 05-13-2004 08:30 AM
