Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 11-25-2006, 11:00 AM   #241
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
I've ordered the Auzentech sound card (user replacable opamps and clocks). Yes, it's only 1/8" jacks, but I'm going to see if I can desolder the end plate, and resolder on RCA jacks.
mobo: MSI 945GM2 H-F - I went with this board for a few reasons. I knew that I was going to need a good deal of processing power if I was going to run all of this software. The Pentium Ds are cheap and powerful. That and the fact that this board has the ALC 880 audio chipset on it, which is capable of running bit perfect. If I ever decide that I want to use the optic out (if this sound card doesn't work for me), I know that I can just use the onboard optic out and have bit perfect.
processor: Pentium D 915 2.8 GHz
memory: 1 gig DDR2 667
hard drive: I'm looking at using a solid state drive for the OS and all programs. However, since XPe is going to be supporting USB booting, that might change to a 6 gig or so solid state USB drive, which would probably be faster than the CF card in the first place. Else, for media and video, I'll have at least a 400 GB SATA 3 drive in there, possibly 2.
video: just using onboard, no need for a bad *** video card for this kind of a set-up (an an 8" screen).
Now I'm just trying to narrow down the software side of things.
Thinking TrueRTA (just need to pick a mic now)
Allocator
Console
Not sure about the EQ, would like a standalone where I don't have to purchase another package and use the EQ plugin...but I'm not sure on it yet.
Ideas? Thoughts?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 11-25-2006, 11:18 AM   #242
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Ok so you decided to change the whole mobo setup and all. That Azuentech Meridian looks nice. A review would be nice when you get it. ALso, you don't want to use 1/8" to RCA adapters? Worried about noise I take it?
Reasonable mic options for True RTA:
http://www.guitarcenter.com/shop/liv...nt+mic&x=0&y=0
Did you have something against the plugin/EQ? Did it give you problems? Just curious.
System always under construction
durwood is offline   Reply With Quote
Old 11-25-2006, 11:48 AM   #243
_
Noise, adding another adapter in line, and the fact that the 1/8" jacks just aren't as secure as the locking RCAs I use.
Thanks! I've been hearing that the Behringer isn't the best, but because it's cheap, it's what people use. I'm not willing to go cheap to that extent. What mic are you using?
It's probably just ignorance really. I have a hard time believing that the free plug-ins for WinAmp would work as well and be as accurate as others. Again, it's probably just ignorance speaking....hehehe
I'm going to try the free ones first, but I wanted to have a few options in case.
Jan Bennett
Old 11-27-2006, 08:48 AM   #244
Car Audio Moderator
durwood's Avatar
I went cheap and use the Behringer Mic. Of course it's been over a year since the last time I actually used an RTA. I prefer to sit and listen for hours and experiment, then use the RTA when I think I am close. I am still learning though. There are probably more options out there, but those are readily available.
Ya you have a point about those 1/8" plugs. I had one loose at a comp once and didn't even realize it until it was too late.
As far as the EQ's there could be problems. If there is money behind it its more likely to work better. I haven't determined if there is any problem with the free ones yet, but Fryedaug seemed to be having some problems.
I was thinking the other day too...There might be a problem using these programs with a video program/DVD playback. Is there any DVD/video player that uses ASIO?
Old 11-27-2006, 09:04 AM   #245
_
one of the things I've read is that you will have problems if you are watching video. There has been talk about using a delay on the video, but since I don't watch video/dvd on my carpc I'm not to worried about it, but that might change with this new set-up since it will be on display more and not just for sound.
Jan Bennett
Old 11-27-2006, 10:00 AM   #246
Car Audio Moderator
durwood's Avatar
I don't really watch DVD's very often either but at shows people love to see it in action. So again this is where the KX driver project has a one up on the ASIO method, since all the processing is done within the soundcard.
...back to more testing and research.
Old 11-28-2006, 07:43 AM   #247
crabbdaddy is on a distinguished road
Red.. which Auzentech sound card?
"Auzentech sound card (user replacable opamps and clocks)"
96 cobra
suspension: MM CC plates, H&R super sport, bilsteins, steeda:bump steer kit, X2's, moly SFC's, triax shifter. MGW handle, cobra knob. Audio:RUX-C701, PXA-H701, MRV-F545, MRD-M1005, SIR-SC-H1, DMHD1000, Polk/Momo MMC6500, MM2104
crabbdaddy is offline   Reply With Quote
Old 11-28-2006, 08:41 AM   #248
Car Audio Moderator
durwood's Avatar
Probably the Meridian. Sounds like a very promising soundcard. (It also has 5V output voltage on the analog outs with potential for a max of 8Vp-p.) *DROOL
Old 11-28-2006, 09:58 AM   #249
tube audio / pc
doesnt seem anymore are around.
http://global.aopen.com.tw/products/mb/ax4b-533tube.htm
http://club.aopen.com.tw/News/News_s...nguage=English
another good read if you want to mod your digital for tube sound.
http://www.fortunecity.com/rivendell...a/vasfda.html#
now if we could replace the opamp on the SC with a tube pre... that would be cool. i have seen it done somewhere.. ill keep searching.
96 cobra
Old 11-28-2006, 10:05 AM   #250
_
http://www.auzentech.com/site/products/x-meridian.php
I can't find the bit about the clocks any more, and i can't find the bit about 8v outs any more either....
anyone else find it?
Jan Bennett
Old 11-28-2006, 10:14 AM   #251
Car Audio Moderator
durwood's Avatar
It's on that page within the specs section
Quote:
-Swappable DIP type OPAMP controlled preamp out circuit (4pcs output control OPAMP IC with DIY socket
-5Vrms (Differential DAC output with gain adjustment / approximately full swing from +/- 8V dual power supply)
-Proper OPAMP control circuit (large capacity 1A +8V, -8V, dual power supply circuit) for high quality audio quality, prevent audio distortion at high volume level.
I don't think it would have swappable clock since that is usually soldered on the board.
Old 11-28-2006, 10:22 AM   #252
Car Audio Moderator
durwood's Avatar
Nice!
Old 11-28-2006, 02:58 PM   #253
Car Audio Moderator
durwood's Avatar
Just an FYI:
Frequency Allocator does not do Time alignment. It does one big generic delay on the output from what I have read.
Frequency Affirmer (Not available yet, but sometime in Dec/Jan) will do room correction / time alignment from what I have read over.
Also after more extensive reading, this video codec called "ffdshow" will do video delay somehow so that video will not be out of sync when using Frequency Allocator.
http://sourceforge.net/projects/ffdshow/
I ran into a little extra money so I think I can finally try the full version of Frequency Allocator and a new soundcard.
Old 11-28-2006, 04:43 PM   #254
_
ffdshow is the same codec that StreetDeck uses I believe.
Good to know that it is capable of this.
I'll be looking into Frequency Affirmer as well...thanks for the heads up!
Jan Bennett
Old 12-01-2006, 06:24 PM   #255
_
Just an FYI:
Updated on the op, thanks for the info
Quote:
Frequency Affirmer(Not available yet, but sometime in Dec/Jan) will do room correction / time alignment from what I have read over.
Is this on their forum or somewhere else? I've seen the Arbitrator, which apparently does Time Correction. Perhaps this is what you are referring to?
I was reading where the lite version of allocator doesn't include the arbitrator information....so I'm guessing that if you buy the full version of allocator, you get the arbitrator with it?
Jan Bennett
AutoTap used to develop custom software! Dodger1417 Engine Management, OBD-II, Engine Diagnostics, etc. 5 09-25-2006 11:51 AM
comparison of GPS Software gunsandrosses Newbie 4 06-28-2006 10:56 PM
CarPal Bluetooth Module & Digimoto Software....A Very Good Combo.. jmciver Engine Management, OBD-II, Engine Diagnostics, etc. 6 06-16-2006 05:08 PM
Sony Vaio PCV-RX670 w/Sony 15" flat panel thousands of $ worth of software, mint clean customs Classified Archive 2 11-15-2005 02:38 PM
CoPilot Software or USB GPS Receiver package Zip-Lock Classified Archive 5 05-13-2004 08:30 AM
