Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 12-01-2006, 06:29 PM   #256
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Quote: Originally Posted by durwood View Post
It's on that page within the specs section
I don't think it would have swappable clock since that is usually soldered on the board.
no swappable clock, but might be able to use an outboard clock none-the-less....
I've recieved my BurrBrown opamps, now I'm ordering new Female RCA ends!
http://www.wbtusa.com/nextgen/wbt0210ag.html for highs
http://www.wbtusa.com/nextgen/wbt0210cu.html for mids and lows
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 12-02-2006, 11:25 AM   #257
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Damn you go all out.
I am a cheap bastard. But I ordered this the other day:
http://www.audiotrak.co.uk/home_thea...gy71hifi.shtml
I didn't even realize until later it too has user replaceable opamps at half the cost of the Auzentech. I only get 2.5V output but that is sufficient for now. I still have to wait and see if the M10000 is going to be able to handle Allocator lite. I have a very bad feeling it just won't cut it so I am already looking into a new motherboard/processor. I think I might upgrade to a Pentium M since they are cheap. Now just to find a Mobo.
System always under construction
durwood is offline   Reply With Quote
Old 12-02-2006, 12:12 PM   #258
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
wow red. i let this thread go for a while. i can't wait to read about your results. as far as a mic is concerned. film industry uses senhiesers a lot. you should maybe look into those. If you were in the area i could get my hands on one for you to use... but you're not, so tough!
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 12-02-2006, 01:51 PM   #259
_
I'm looking here: http://www.sennheiserusa.com/newsite...?transid=cat30 and I'm not seeing any mics for reference tuning, perhaps they are called something different?
I know that my Sennheiser head phones are amazing.
Jan Bennett
Old 12-02-2006, 04:08 PM   #260
MySQL Error
scott_fx's Avatar
hmmm... i'm not sure about that one then. i didn't realize there was a difference. i'm a n00b
M10k
My Car Pc Install
Old 12-03-2006, 11:47 AM   #261
Car Audio Moderator
durwood's Avatar
Here are some measurement microphones that can be used for RTA.
http://www.bksv.com/3032.asp
Old 12-03-2006, 11:30 PM   #262
addissimo is an unknown quantity at this point
durwood-
Where are you getting the specs for the 2.5v output on the Prodigy? I thought I remembered reading it too, but can no longer find it. Have you found any good literature on Directwire or NSP? I've only found this: http://audiotrak.net/advancednsp_tutorial1.htm. It seems like a pretty solid soundcard if we can tweak the ouput chanel signaling through directwire.
I have also been looking for a simple vst based highpass filter so I don't have to go to the trouble of finding crossover modules for my old xtant amp. Anybody know of anything like this? I realize that Allocator will do this, but it seems to be 99% more complicated than it needs to for my use.
Thanks for your help
-Addis
addissimo is offline   Reply With Quote
Old 12-04-2006, 01:23 AM   #263
According to this converter, the Prodigy is more like 3.1+vrms output based on the 10dbv that the user manual supplies.
http://www.sengpielaudio.com/calculator-db-volt.htm
Anybody have a user manual for the directwire feature?
-Addis
Old 12-04-2006, 03:47 PM   #264
Car Audio Moderator
durwood's Avatar
-Addis
Actually I never read anything about 3.1V but I remember converting a value somewhere with that same link you provided. I might have been looking at a Prodigy lt which had 8dbV. I looked at a ton of cards and I don't remember now. If it has 3.1 that is even better. I will measure it when I get the card so we know for sure.
The directwire feature is really cool. That is one of the other reasons why I was looking at it. From what I have read about the directwire, you can use it to "wire" the soundcard to the ASIO outputs so that programs that don't use ASIO (such as Power DVD, Win DVD ) will still pass the audio stream off to any vst plugin in ASIO. When I receive the card I will will do my best to answer questions about the Directwire. This is all I could find for now:
http://www.esi-pro.com/getFile.php?t...wt192M_2nd.pdf
Another option to the Prodigy HiFi is the ESI Waveterminal192M. Pretty much has the same features. It was second on my list of soundcards I wanted to buy after I ruled out the Auzentech X-Meridian
You could use the Allocator lite for crossovers. I know its overkill but for $60 that is a huge bargain. Otherwise I think you might be able to find a "filter" vst on http://www.kvraudio.com
Old 12-06-2006, 05:58 PM   #265
Iceman_jkh is on a distinguished road
Prodigy 7.1 LT output voltages are 1V (0.99V) at full output (ie: full volume 60Hz pure sine wave).
I have one.. I measured it
Iceman_jkh is offline   Reply With Quote
Old 12-06-2006, 06:01 PM   #266
Possible alternate card choice to the Auzentech (which I think is superior but more $$):
http://www.sondigo.com/inferno
ASIO4ALL will need to be used with these cards unless they have specific drivers written to CAPTURE the audio streams from within windows (MME and WDM streams) and route them directly into the ASIO input buffers.
One benefit of the AudioTrak cards is the DIRECTWIRE 3.0 driver, which does that exact audio stream capture into ASIO.
Perhaps check with the manufacturer before purchasing.
Old 12-07-2006, 10:48 AM   #267
Car Audio Moderator
durwood's Avatar
Audiotrak really dropped the ball on this one. At least your has an output voltage of 1V. Is that peak or peak to peak?
I measured the Audiotrak Prodigy Hifi at 0.6Vp-p or 0.3V peak.
Has a good signal to noise ratio, but it doesn't list output voltages and does not have swapable opamps. It does say it is ASIO compatible though.
Old 12-07-2006, 05:39 PM   #268
Durwood> Pretty sure its 1V peak/amplitude (not peak-to-peak).
The Inferno card doesnt have swappable opamps, but the ones it uses are pretty darn good. Same as the stock Meridian card I think.
Might look at getting the X-Meridian. Question is.. does it have drivers similar to DIRECTWIRE - which capture ALL windows audio streams into ASIO and will it be a sufficient (read: audible) improvement over the Low Profile Prodigy 7.1LT that I have currently.
Old 12-07-2006, 06:05 PM   #269
Car Audio Moderator
durwood's Avatar
Well I didn't trust my DMM yesterday since its pretty beatup, so I brought the soundcard into work today and connected up an O'scope. 0.3V peak using a program called TTG to generate the pure tone Sinewave at 0dB. The Lynx soundcard that everyone rants about has about the same analog output level so I guess its no big deal. I just know its going to be easy to pick up noise once the signal leaves the card.
The Prodigy HiFi uses JRC 4580 opamps which I believe is the same as the X-Meridian. I knwo Auzentech doesn't have Directwire or doesn't have anything like it. That is an ESI/Audiotrak/EGo Systems thing. I just need to figure out how easy it is to switch between different direct wiring schemes or if everything can be wired up at once. ALso here is what I was told at Thunea about the Auzentech.
http://www.thuneau.com/forum/viewtopic.php?t=91
Old 12-08-2006, 09:55 AM   #270
_
I got paid today, purchased the True RTA software, am purchasing the RCA ends, and hopefully the mic and preamp as well. We'll see how much I have left as to if I want to go for the Allocator as well right now.
After reading that thread, I'm glad I went with my Pentium D. However, I'm hoping that once I get everything up and running I'll be able to better pick a processor for the car....
I'm going to see what I can find out about the ASIO drivers. I'm waiting on an email back from Auzentech right now. Once I get it I'll ask about ASIO.
Jan Bennett
AutoTap used to develop custom software! Dodger1417 Engine Management, OBD-II, Engine Diagnostics, etc. 5 09-25-2006 11:51 AM
comparison of GPS Software gunsandrosses Newbie 4 06-28-2006 10:56 PM
CarPal Bluetooth Module & Digimoto Software....A Very Good Combo.. jmciver Engine Management, OBD-II, Engine Diagnostics, etc. 6 06-16-2006 05:08 PM
Sony Vaio PCV-RX670 w/Sony 15" flat panel thousands of $ worth of software, mint clean customs Classified Archive 2 11-15-2005 02:38 PM
CoPilot Software or USB GPS Receiver package Zip-Lock Classified Archive 5 05-13-2004 08:30 AM
