Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 02-07-2007, 06:08 PM   #406
freudie1 is on a distinguished road
Quote: Originally Posted by durwood View Post
Did you have a price range? Or special features you wanted? The ESI gigaport would make your life easy if it has Directwire. Someone said it does but on their webpage I didn't think it directwire was included or worked with it.
M-Audio Firewire 410 is a good choice too. It has routing features in its software I thought.
Any other choices? THe M-Audio 410 requires a firewire port (already using my pcmcia slot for a usb 2.0 card adapter) and the ESI gigaport doesn't support directwire (is this 100% required).
I'm currently using an audigy 2 nx, but obviously want to upgrade so I can ditch my old phoenix gold eq230.
freudie1 is offline   Reply With Quote
Old 02-07-2007, 08:10 PM   #407
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
direct wire isn't 100% required. There's other options out there.
Can you use a PCI card?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 02-08-2007, 01:24 AM   #408
No pci options
Unfortunately (well fortunately in some respects) I'm using my old Toshiba Satellte with a 2.4GHz Celeron and a gig of memory. Plenty of horsepower for the car (and I mounted the laptop quite well under the passenger seat) but leaves a little to be desired for my pro audio tastes.
The laptop has a single pc card slot which I currently have populated with a two port usb 2.0 card (the two usb ports built into the laptop are 1.1 hence the desire for the pc card).
Is there such a thing as pc card to PCI???? Never looked, wouldn't be 100% shocked to find such a monster though.
Assuming the answer is "no", I'm on the quest for the ultimate usb sound card that can work with the software (xover, 1/3rd octave dual eq, time alignment) that you guys are enjoying with the pci cards. Would love to ditch the old phoenix gold eq and move everything into the laptop.
What to do???
Old 02-08-2007, 01:36 AM   #409
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
there is such an adaptor, but it's rediculously expensive, like you could by a new core 2 duo laptop for that price kinda expensive, so that's not an option really
you can get a pcmcia card that has 2 usb's & firewire, that would be a good way for you to go really...
turbocad6 is offline   Reply With Quote
Old 02-08-2007, 01:44 AM   #410
Yes I've seen those cards, so back to the question: Which sound card then if I have the expansion card giving me usb and firewire? The m-audio 410? Its a bit pricey and from what I can tell about three years old. Anything comparable and cheaper? They seem to be about $234 and up.
Old 02-08-2007, 08:18 AM   #411
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Here is a list I put together for External Soundcards. Focus on the Pro-Audio cards. How many channels do you need?
You might be able to get something around the $200 mark if you only need 4-6 channels. Keep in mind, if you plan on using Frequency Allocator you need something to capture the audio stream. If the soundcard does not have the ability to do this you will probably need to buy VAC @$50. That is why Directwire is important. The M-Audio Firewire 410 also has something similar to Directwire with their drivers.
EDIT:
So all you need is an EQ? If that's all you need that can be done with your current soundcard. Check the WIKI. I wrote an article about using a 31band EQ inside of Winamp.
System always under construction
durwood is offline   Reply With Quote
Old 02-08-2007, 09:02 AM   #412
Need more than just a 13/rd eq
EDIT:
No I want all of my processing in the carputer (i.e. xover = freq allocator, eq, and time alignment).
Did you forget a link or am I missing something, I don't see a list/link that you are referring to for the usb cards.
Thanks for all your help, this is a good resource.
Old 02-08-2007, 09:05 AM   #413
Car Audio Moderator
durwood's Avatar
Ok I understand. Oops on the link
Here you go(it's inthe car audio FAQ)
http://www.mp3car.com/vbulletin/car-audio-faq/88081-ultimate-usb-firewire-external-soundcard-list.html
You might want to do some reading over in www.thuneau.com forums too to find out some of the cards people are using.
Old 03-15-2007, 08:47 AM   #414
Car Audio Moderator
durwood's Avatar
Ok, this was requested and I whipped this up really quick. It's only a piece of the puzzle but if you want to know how to use Console, this a basic guide. There will be a more indepth on available when I have time that will be posted in the WIKI so that others can feel free to add to it or make changes to correct anything I miss. For now here you go. I ahd to split it into two parts to get it to fit on this board.
Old 03-18-2007, 10:56 PM   #415
Car Audio Moderator
durwood's Avatar
Guides for Console VST plugins AND KXproject driver tuning are up in the Wiki.
http://www.mp3car.com/wiki/index.php...g_via_Software
Old 03-20-2007, 09:45 AM   #416
BenOBS's Avatar
BenOBS is an unknown quantity at this point
Great Job Durwood!
Carputer Athlon X2 4200+
800tsv - Audigy 2 ZS - PowerMate - Wifi 802.11n
All Audio Tunning done via Software. 7 channels.
CDT ES-07 - HD2 - DRT25
ED Nine.2x
ED Nine.4
ED Nine.1
ED 110v.2 (x2)
BenOBS is offline   Reply With Quote
Old 11-15-2007, 11:19 PM   #417
_
http://www.thuneau.com/forum/viewtopic.php?t=135
Wow - just wow....
Jan Bennett
Old 11-20-2007, 08:37 PM   #418
mrpee1881 is an unknown quantity at this point
Quote: Originally Posted by RedGTiVR6 View Post
So does this mean you can achieve the same quality of sound w/o all the audio tuning that comes with the vst plugins mounted using the console?
Install and use this with winamp, configure it accordingly with the chanels, test for correct asio driver and your all set?
If so then the 20+ pages on this subject has been simplified to this? Can't be.
mrpee1881 is offline   Reply With Quote
Old 11-20-2007, 08:43 PM   #419
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
I take it you are going to try this Jan? IF you do, let us know how it goes. This might be the answer that is needed.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 11-20-2007, 09:11 PM   #420
_
I'd suggest reading up on what allocator does specifically, it's just a piece to the puzzle...
Jan Bennett
AutoTap used to develop custom software! Dodger1417 Engine Management, OBD-II, Engine Diagnostics, etc. 5 09-25-2006 11:51 AM
comparison of GPS Software gunsandrosses Newbie 4 06-28-2006 10:56 PM
CarPal Bluetooth Module & Digimoto Software....A Very Good Combo.. jmciver Engine Management, OBD-II, Engine Diagnostics, etc. 6 06-16-2006 05:08 PM
Sony Vaio PCV-RX670 w/Sony 15" flat panel thousands of $ worth of software, mint clean customs Classified Archive 2 11-15-2005 02:38 PM
CoPilot Software or USB GPS Receiver package Zip-Lock Classified Archive 5 05-13-2004 08:30 AM
