Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 10-17-2006, 04:00 PM   #1
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Software options for Tuning
For the Wiki article on this subject, please see this link: http://www.mp3car.com/wiki/index.php...g_via_Software
If you have more information to add to this, please do so!
ASIO: (Audio Stream Input Output) is a protocol for low-latency digital audio specified by Steinberg.
ASIO provides an interface between an application and the sound card. Whereas Microsoft's DirectSound is typically for stereo input and output for consumers, ASIO provides for the needs of musicians and sound engineers. ASIO offers a relatively simple way of accessing multiple audio inputs and outputs independently. It also provides for the synchronization of input with output in a way that is not possible with DirectSound, allowing recording studios to process their audio via software on the computer instead of using thousands of dollars worth of separate equipment. Its main strength relies in its method of bypassing the inherently high latency of operating system audio mixing kernels, allowing direct, high speed communication with audio hardware.
Find more here: FAQ: All You Need To Know About ASIO
VST: Virtual Studio Technology and its acronym VST refer to an interface standard for connecting audio synthesizer and effect plugins to audio editors and hard-disk recording systems. VST and similar technologies allow the replacement of traditional recording studio hardware with software counterparts.
  • VST Effects:A VST effect is a type of VST plug-in that is generally used to process audio. Types of VST effect include (among others) reverb processors or phaser effects.
    VST Effects can be used in real-time when used with an appropriate software and hardware configuration, such as a sound card that supports ASIO, software that bypasses Windows' slower audio engine and so offers much lower latency times, allowing for effective real time playing. Modern Macintosh computers typically ship with low-latency audio drivers.
VSTSHELL for combining/wiring/stringing VST plugins together
  • Console is a VSTSHELL that works with ASIO. It routes the cards in and outs and gives you the ability to wire up multiple VST plugin effects how you want them. It does not stream audio from the actual media player unless the output of the player is ASIO.
Audio Stream Capture to use with VSTSHELL programs and ASIO
  • VAC - designed to capture the audio signal from media players using KS/Direct sound/WDM to be routed to VSTSHELL programs or any program that needs/uses ASIO.
  • Reaper - captures the audio stream with the "REAroute" function built inside of it.
  • See this thread for how it was used
  • Directwire - Only available on ESI PRO and some Audiotrak Cards
  • Some M-Audio cards also have this capability. The 410 and Firewire 410 can do it for sure.
  • Another option is to use the SPDIF OUT looped back to the SPDIF IN if the card has both available.
    See this thread.
Software
31-band 1/3 octave EquilizersOther EQsTime AlignmentPhase ControlCrossoverChannel AllocatorRTA
  • TrueRTA
    • 1 (free) - 1/3 ($39.95) - 1/6 ($69.95) - 1/24 ($99.95) octave versions
RTA Mic
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 10-17-2006, 04:09 PM   #2
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
kxproject drivers if you are fortunate enough to have a compatible pci card:
http://kxproject.lugosoft.com/
You can 'digitally rewire' the card with this software. Time alignment, eq, phase control among others (plug-ins may be required)
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 10-17-2006, 04:13 PM   #3
_
does it have a 31band EQ?
and does it have crossover functionality?
I've been meaning to play with it some more in the car, but I simply haven't had a chance. If it does, it seems it would be the end all be all solution.
Jan Bennett
Old 10-17-2006, 04:23 PM   #4
MySQL Error
scott_fx's Avatar
it only has a 10 band right now, but it's just a matter of having someone code a 31 band eq plugin. it does have x-over functionality. i think the best bet for using this in the car pc environment is finding the rare compatible emu card on ebay. I believe (if memory serves me) that it has higher output voltages and better components.
M10k
My Car Pc Install
Old 10-17-2006, 04:36 PM   #5
_
bah on the 10 band....useless....
I wish I were an EE and could code on the fly, I'd design a sound card to work that would include software like we needed
yeah right!
Jan Bennett
Old 10-17-2006, 04:37 PM   #6
Naamanf's Avatar
Naamanf is on a distinguished road
Having somone that can program plug-ins for EMU cards would be the way to go. My card came with some simple eq/delay/phase plugins. Being able to make them more advanced would be key.
2007 Tahoe
Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
My Install
Naamanf is offline   Reply With Quote
Old 10-17-2006, 04:40 PM   #7
Naamanf's Avatar
The only draw back I see is having enough outputs. For a simple system it might work but for more advanced there may not be enough channels available. It would take a seriously good solution to make me think about ditching the H900.
2007 Tahoe
My Install
Old 10-17-2006, 05:20 PM   #8
_
http://www.diyaudio.com/forums/showt...threadid=88455
There's a thread I've started on DIY for some others assistance.
Also, I started one here - but the first response I got was a little on the condescening side since it has to do with car audio and all....
http://www.audioforums.com/forums/sh...ad.php?p=72691
Jan Bennett
Old 10-17-2006, 05:23 PM   #9
MySQL Error
scott_fx's Avatar
you are in a different class with the 900...but for general information: i believe the kx drivers will allow you to rewire all the i/o ports so they are all output.
M10k
My Car Pc Install
Old 10-18-2006, 07:47 AM   #10
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
I played around with the kxdrivers for my audigy card, but from what I remember, the crossover function did not allow for slope adjustment. I would prefer to be able to play with crossover slope before I even think about using a software EQ. If only winamp could use ASIO. There is a really nice EQ plugin made by Nevi were you can pretty much draw your EQ curve. it was really buggy though and heavy CPU usage. You could do a -60db notch filter on it though.
I also looked into TI, they make an 8 channel DSP development board. I wanted to buy it and do my own programming on it, but cost was not feasable. >$2000
http://focus.ti.com/docs/toolsw/fold...dxpdk6727.html
The computer is fully capable of processing the audio in anyway we want. I would love to dump my PXA-H701 just to show my buddy its not needed.
System always under construction
durwood is offline   Reply With Quote
Old 10-18-2006, 08:06 AM   #11
Car Audio Moderator
durwood's Avatar
Red-
I am really liking what your found here. Nice find! I was looking for a crossover software ap like this 3 years ago. Now to find something with time delay. hmmmm...
Old 10-18-2006, 09:47 AM   #12
_
It is: see this page: http://otachan.com/
Quote:
out_asio(dll).dll (dll version) Ver. 0.67 ASIO出力プラグイン (2006/10/4)
out_asio(exe).dll (exe version) Ver. 0.70 ASIO出力プラグイン (2006/10/4)
out_asio(x64).dll (x64 version) Ver. 0.71 ASIO出力プラグイン (2006/10/4)
Jan Bennett
Old 10-18-2006, 10:11 AM   #13
XC-C30's Avatar
XC-C30 is on a distinguished road
if only threre was a program that had all this, really would save my day, 'cause now i'm looking into buying an UCS pro,but it costs like 900 bucks.... can't afford that at the moment.
but by using that frequency allocater I would already have an x-over? cuz i can't use the x-over on my amp
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 10-18-2006, 10:19 AM   #14
_
the frequency allocator would be your cross over. Chances are, it would be more accurate than the one on the amp anyways.
Very few amplifiers out there are accurate in that regard. One thing that's nice about the Stegs (but I'm not using this) is that you actually plug in the crossover to the amp. It's almost like a MAXI fuse, set at a predetermined point. you purchase them and plug them in.
Jan Bennett
Old 10-18-2006, 10:28 AM   #15
XC-C30's Avatar
yeah, i know.... but as you know maybe, i didn't go with the stegs at final desision. i bought 2 McIntosh amps instead for like 1/4 of the retail, and brand new!!!
thing is, the built-in x-overs only go from 80to 150Hz so couldn't use 'em anyway, even if they were accurate...
i hope i can find the frequency allocator in Belgium though....
or is it just to download from their website (i saw there was something to downoad)
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
AutoTap used to develop custom software! Dodger1417 Engine Management, OBD-II, Engine Diagnostics, etc. 5 09-25-2006 11:51 AM
comparison of GPS Software gunsandrosses Newbie 4 06-28-2006 10:56 PM
CarPal Bluetooth Module & Digimoto Software....A Very Good Combo.. jmciver Engine Management, OBD-II, Engine Diagnostics, etc. 6 06-16-2006 05:08 PM
Sony Vaio PCV-RX670 w/Sony 15" flat panel thousands of $ worth of software, mint clean customs Classified Archive 2 11-15-2005 02:38 PM
CoPilot Software or USB GPS Receiver package Zip-Lock Classified Archive 5 05-13-2004 08:30 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
