Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 02-20-2007, 07:05 PM   #286
HIPPOhifi's Avatar
Quote: Originally Posted by durwood View Post
Yes. Here comes the bad news...right?
The bad news is that the solution would be more expensive, you could use multiple Bloat units but I need to verify this with some software. The difference would have been approximately $50US for additional channels in comparison to current $139US Bloat special.
HIPPOhifi
HIPPOhifi is offline   Reply With Quote
Old 02-20-2007, 07:07 PM   #287
Car Audio Moderator
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Oooh the BeBoB also mentions I8S in addition to I2S....I wonder if that means 8 channels???
durwood is offline   Reply With Quote
Old 02-20-2007, 07:11 PM   #288
Car Audio Moderator
durwood's Avatar
Well considering an ALpine PXA-H701 retails for around $800US, I don't see a problem with pricing just yet.
Our current software needed is $150 for Frequency Allocator + $50 for console +$50 for VAC (for those whose soundcards won't do audio stream capture like Audiotrak's Directwire or M-Audio's/other pro cards)+the cost of a good soundcard.
Old 02-20-2007, 07:12 PM   #289
Laptop, Tablets, UMPC Moderator
turbocad6's Avatar
139x4= $556....
I think if a solution like this really worked it would be worth that... but the problem is even I had 4 of them, could they all work at the same time? then theres the 4 dedicated motherboard usb ports required....
this is the solution that is necissary I think, but built into one usb or firewire interface...
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 02-20-2007, 07:20 PM   #290
HIPPOhifi's Avatar
Felix-
I missed your post about BeBoB. THat might be what we need, however I still see a DSP chip involved (trying to eliminate that). Maybe there is no way around that. But maybe that is what some of these pro-USB solutions are using. Look at what I found at quick glance:
This might be what we have to do instead of USB to I2S. Any other thoughts anyone?
I am not against the BeBoB but a number of things come to mind:
a. Does the software allow for control of each channel individually?
b. What is the specific voltage out?
c. What components used in the DAC/opamp section
I can't seem to find detailed specifications. Google isn't telling me much either. If the board is completely powered from USB that would concern me as there is a lot of components, indicating inferior parts. I will fling them an email and ask for a copy of the schematic of the break out box. Does anyone know the price?
HIPPOhifi
Old 02-20-2007, 07:24 PM   #291
HIPPOhifi's Avatar
Yes that is 8 channel audio.
HIPPOhifi
Old 02-20-2007, 07:24 PM   #292
Car Audio Moderator
durwood's Avatar
I found something else just now..something called DICE.
Firewire though---we wanted USB since it is more uiversal
http://www.1394ta.org/Press/2006Pres...ngWithDice.pdf
Old 02-20-2007, 07:26 PM   #293
HIPPOhifi's Avatar
Do you have a link to Frequency Allocator, maybe I download an eval.
HIPPOhifi
Old 02-20-2007, 07:30 PM   #294
Car Audio Moderator
durwood's Avatar
www.thuneau.com
ooops typo. Fixed
Old 02-20-2007, 07:35 PM   #295
_
4v out would be the minimum IMO.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 02-20-2007, 07:37 PM   #296
HIPPOhifi's Avatar
Thanks for the link, I will post back in 8hrs or so with some results.
HIPPOhifi
Old 02-20-2007, 07:43 PM   #297
Car Audio Moderator
durwood's Avatar
Cool Thanks for taking the time on this.
Old 02-21-2007, 07:53 AM   #298
HIPPOhifi's Avatar
Will take a look at this tomorrow at work, my home internet has gone over quota.
HIPPOhifi
Old 02-21-2007, 02:29 PM   #299
Felix509's Avatar
All the Digital channels you would ever need...
Digital Audio via Ethernet
AES50 standard, used for pro audio applications... Supposedly very low jitter and latency, and LOTS of channels... Not much info out there..
It looks like I8S is similar to TDM(Time Division Multiplexing) or maybe the same with a different name??
Ours is the age that is proud of machines that think and suspicious of men who try to.
___________________________________
Current SYSTEM
AMD64X2 2.5
Xenarc
ZAPCO DSP-6
ARCAUDIO SE Amps
Rainbow Profi CS365 & Profi Vanadium 12"
Felix509 is offline   Reply With Quote
Old 02-21-2007, 08:57 PM   #300
HIPPOhifi's Avatar
Good News
Good News, working perfectly with the following setup. Excellent seperation in frequencies with the foobar digital crossover plugin and as a bonus all software/plugins are free.
Hardware
PC with 32bit Vista
2 HIPPOhifi Bloats
Sennheiser HD650's
Software
ASIO4ALL 2.7
Foobar2000 v0.9.4.2
Foobar2000 ASIO Plugin Download Here
Foobar Digital Crossover Plugin Information Download Here
It took about an hour or so to get all the applications configured but it wasn't difficult to setup. I spent most of the time configuring ASIO4ALL. The foobar setup was very easy. The foobar xover plugin was very good, you can select 4 frequency groups (sub, low, mid & high) with variable start and finish frequencies for each group. From 1st to 10th order curves, 6db to 60db respectively. All the settings you would expect from a software xover.
Fire away the questions...
HIPPOhifi
diy usb audio with optical in / out Raas Off Topic 5 05-01-2008 03:03 AM
USB audio box with optical and stereo craigyb General Hardware Discussion 2 03-13-2008 05:29 AM
usb to mini 3.5mm audio? scott_fx Input Devices 3 02-10-2007 08:08 PM
FS: Edirol UA1X USB Sound Adaptor 94 Cobra R Classified Archive 11 06-29-2005 06:51 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 09:52 AM
