Go Back   MP3Car.com > Mp3Car Technical > Car Audio > High End Solutions
Old 02-07-2007, 06:58 PM   #106
Dennis5587's Avatar
well its not even windows i think... its actually console, cause i can have music playing out of a sound card, and different music playing out another, windows will actually recognize many sound cards, 0-N or something like that...
However console is only letting me output to one sound device, think this is because i don't own it? If so I'll blow the 50, and keep moving
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Dennis5587 is offline   Reply With Quote
Old 02-07-2007, 07:20 PM   #107
mezz64's Avatar
Ah yes i see what you're talking about now, I have the registered version of console 1.6 and I see no option to specify more than one input/output device.
98' Honda CR-V
http://www.superbluecrv.com
mezz64 is offline   Reply With Quote
Old 02-07-2007, 07:49 PM   #108
Car Audio Moderator
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
So multiple single dacs are out. It has to be all integrated into one chip then. TI has some other DAC chips that are multi-channel
durwood is offline   Reply With Quote
Old 02-07-2007, 08:19 PM   #109
mezz64's Avatar
Nothing over 8 outputs though, so thats a max of 4 stereo outputs. And those chips require clock signal and USB integration. Although the TAS1020A I mentioned earlier might take care of both of those problems.
98' Honda CR-V
Old 02-07-2007, 09:13 PM   #110
Dennis5587's Avatar
is there software that can create a virtual sound card, that can then route the signals to different sound cards?
While we're at it, does anyone have an extra flux capacitor, mine broke....
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Old 02-07-2007, 09:39 PM   #111
mezz64's Avatar
Here is some great reading on usb dac's in general: http://www.head-fi.org/forums/showth...hlight=usb+dac lots of info.
98' Honda CR-V
Old 02-07-2007, 11:16 PM   #112
"Firewire devices are (generally) more recommended than USB. Firewire is not "processor dependent" like USB is, and usually experiences much fewer conflicts with the computer compared to USB." Quoting an article I have here on reviewing most mainstream audio interfaces. This is why you don't see many interfaces using USB to record or playback large amounts of audio.
There are options though if you do what to stick with USB that are alreay put together. First off you can get a USB to ADAT converter and an 8 channel line mixer, with preamps to boost your output voltage. Or you can get somthing like the MOTU 828 seen here http://www.sweetwater.com/store/detail/828MkIIusb/
My thoughts on this are the drivers are going to be the most important thing. I know that our EMU has the ability to take the windows output and send it to one of 20 channels doing whatever processing you want to do to it individually isolated to that single channel. You can also route this to most high end software DSP's right within the built in patch mixer.
I think you are looking at major, major, software issues along with limited bandwidth and processing power to run USB. If you are going to bother getting all this stuff together, why not just upgrade your PC a little and run a PCI based card that does everything you want it to do, and boost the output voltage on a pre-existing unit? They do exist. Behringer makes a 230 dollars ADAT mixer that comes with 8 preamps with individual outputs. I doubt you can get 8 volts, but something like this seems like a more viable solution.
Why re-invent the wheel?
comet28024 is offline   Reply With Quote
Old 02-08-2007, 12:05 AM   #113
mezz64's Avatar
You know you make a great point, if things go as planned I'll have room for a PCI card which will end up being a much more integrated solution and use less processor power. This is still an interesting idea though, at least the high output voltage if nothing else.
98' Honda CR-V
Old 02-08-2007, 12:33 AM   #114
Laptop, Tablets, UMPC Moderator
turbocad6's Avatar
Quote: Originally Posted by RedGTiVR6 View Post
I'm really worried about size there. I for one don't have anywhere left to put something like that in the car. At that point, we might as well go with the DBX drive rack and just modify the PSU like people have done in the past.
hey red, thanks for that... the dbx driverack is exactly what I've been looking for all along, just didn't know it, wish there was a big kiss smiley, although I doubt I'd ever use it on anyone else
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 02-08-2007, 06:59 AM   #115
Car Audio Moderator
durwood's Avatar
You defected! Noooo.... hahahaha. Enjoy that piece. If money wasn't an option and competing with it didn't put me in the highest class, and I had the room, I would have done it too.
Old 02-08-2007, 07:06 AM   #116
Car Audio Moderator
durwood's Avatar
I think the problem for PCI is the space requirements. Not sure though. I prefer the PCI route and RED already has a PCI card with 4V outs, but I think she was looking for a USB DAC vs USB soundcard, although I think anything more than a 2 channel stereo USB DAC becomes a soundcard.
YEs. It's called Virtual Audio Cable (VAC). It should be listed in the software options for tuning thread.
Old 02-08-2007, 07:45 AM   #117
turbocad6's Avatar
nah man, no defection here, I do still need to do my da conversion & the driverack is just one solution for one car, I'm still interested & involved here
I didn't even think about this pushing a car up to the pro class in competition, not an issue for me, I have no plans to compete, but I could see how that could be an issue too...
Old 02-08-2007, 07:58 AM   #118
Car Audio Moderator
durwood's Avatar
Yep they get you with either any processing equipment powered by 120V, or modifications to existing equipment if I remember correctly. IF you want to run with the big big dogs then that is the way to do it.
Well good to hear you'll still be involved. I didn't think you could resist other ideas in this realm.
Old 02-08-2007, 08:42 AM   #119
_
As stated above, size is a concern, a BIG concern in an install in a car.
Point taken, that's why I wanted to facilitate discussion.
Why? Because I'm already doing that. I already have an x-meredian that has close to 5v outputs. I'm already modifying it.
I have another reason I want to design something like this...another reason that I see something like this being very beneficial.
As stated above...SIZE SIZE SIZE!!!!
because the wheel as I see it being needed still doesn't exist.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 02-08-2007, 08:45 AM   #120
_
that's what I thought too...but apparently in USACi isn't not a rule...who knows...
My goal for my current project (which is already underway and is completely aside from this thread) is to compete with the big dogs without having to necessarially go to processing like the DriveRack and the like.
Jan Bennett
diy usb audio with optical in / out Raas Off Topic 5 05-01-2008 03:03 AM
USB audio box with optical and stereo craigyb General Hardware Discussion 2 03-13-2008 05:29 AM
usb to mini 3.5mm audio? scott_fx Input Devices 3 02-10-2007 08:08 PM
FS: Edirol UA1X USB Sound Adaptor 94 Cobra R Classified Archive 11 06-29-2005 06:51 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 09:52 AM
