Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc. > How to Power a Laptop
Old 01-09-2009, 09:46 AM   #1
Startingline13 can only hope to improve
Laptop to Carnetix
Alright before i get flamed, understand that I have thoroughly searched through the forums a number of times over the last 18 months. I have my car PC put together but am having difficulty understanding one last piece. I want to connect my laptop to the Carnetix CNX-P2140.
I understand that I need to cut open the barrel plug from the laptop adapter and split the three ends (+, Ground, and comm wire) to put into the Main jumper to the Carnetix. Can I use something such as a universal laptop car adapter from Ebay, hack that open and plug it into the laptop -----> Carnetix instead of using the battery power chord that came with the laptop?
If so, any reccomendations/warnings?
Regards,
Dave
Startingline13 is offline   Reply With Quote
Old 01-09-2009, 12:21 PM   #2
WarDriver's Avatar
WarDriver is on a distinguished road
Use a multi-meter on your non-hacked adapter to find the voltages and go for it on that eBay find.
Be warned - not all laptops will charge the battery when connecting to a carnetix.
-WarDriver-
Server Administrator
Outdoor Nut
My DC to AC Inverter Mod
My Laptop Remote Switch
WarDriver is offline   Reply With Quote
Old 01-09-2009, 12:44 PM   #3
FusionFanatic's Avatar
FusionFanatic is an unknown quantity at this point
I had bought a cheap laptop adapter off eBay for my Dell Inspiron 8000 (used in my first carPC setup). the original AC power brick had 3 wires that plugged into the laptop. the eBay adapter I bought used the same 3-pin plug, but only used 2 wires.
so just be aware (depending on the manufacturer) that whil the plug itself will be the same, the wiring behind it may not be. in my case it didn't matter as the laptop still charged even though it was missing the 3rd wire, but in newer laptops it may be a requirement.
you may be better off trying to find a used OEM AC power brick and hack the plug off of that instead. good luck
FusionFanatic is offline   Reply With Quote
Old 01-09-2009, 02:17 PM   #4
I'll try the multimeter when I get home this evening. I will also try to find a used adapter of the same model as you recommended. One final question, so even if for some reason the Cartinex doesn't charge the battery, will it atleast keep it at the current power level? i.e. Stays at %100 as long as I do not use the battery?
Old 01-12-2009, 11:29 AM   #5
if it doesn't charge the battery, then it can't keep it at 100% either.
your laptop shouldn't drain the battery while the Carnetix is powering it, but like any laptop it will still slowly lose its charge over time when it's not powered. so if the carnetix can't charge it in the car, then you'll have to charge it back up from a home AC outlet every once in a while.
Old 01-12-2009, 01:16 PM   #6
Heh I like that funny image.
Alright I have one last question. Where exactly do I snip the laptop power adapter cable, to split it to carnetix? I've done a lot of searching here, as well as google and can't come up with a clear answer, or a picture.
Old 01-14-2009, 10:27 PM   #7
there is only 1 cable that plugs into the laptop. you can "snip" and splice it at any point in that cable.
Old 01-15-2009, 01:31 PM   #8
So any point before the power adapter, correct?
I'm sorry if these questions seem redundant, but like I said before, I have not been able to find any other resource to find a solution to these questions. I appreciate it all.
Old 01-15-2009, 09:19 PM   #9
StraightXRS is an unknown quantity at this point
ok a snipped my cord but i am only seeing two wires inside my cable....there is silver wire , and then there is another insulated wire with what looks like copper wire. so these two should be ground and power correct? Only having two wires would mean that i dont have a comm wire right?
StraightXRS is offline   Reply With Quote
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 24 06-25-2009 07:31 AM
New Laptop Project! LeeVD Laptops, Netbooks, Tablets, UMPCs, etc. 3 11-22-2007 01:59 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
