Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc. > How to Power a Laptop
Old 03-16-2009, 12:58 PM   #1
lewisdg is an unknown quantity at this point
Would this be ok for power a laptop?
http://www.maplin.co.uk/module.aspx?...FQo1Qwod0ASCpQ
hard wire this into ignition switched 12v feed, have a switch for the laptop power button and away you go
r have I got this wrong
lewisdg is offline   Reply With Quote
Old 03-16-2009, 03:13 PM   #2
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
It should work, although my guess is, it really isn't to be used as a permanent solution.
Enforcer is offline   Reply With Quote
Old 03-16-2009, 03:52 PM   #3
Enforcer
Thanks for the reply....looking at your other posts you seem to know your stuff!
But I'm curious as to why you say it would not be good long term if it is installed well? what would be the alternatives for a laptop carPC ? and how are they better?
I'm very new to this so I'm looking to learn what's what
cheers
Lewis
Old 03-16-2009, 06:34 PM   #4
Confusion Master
Enforcer's Avatar
I'm not that familiar with laptop installs, however I have heard their is a carnetix PSu that is done especially for laptops.
Why do I think it's not good long term? Because of the nature of the unit and how laptops are normally used in the car.
Normally they will be used briefly or just charged, they are unlikely to be used day in and day out for a good period of time. Also I used to work for Maplins and have some knowledge of the products they do
Old 03-16-2009, 06:41 PM   #5
rodweb is an unknown quantity at this point
Also by adding a Carnetix or an Opus (which I use) you will have acces to regulated 5 volts which will be very handy to power up additional hardware such as USB hubs and DVD drives. You have to ask Opus to provide the right firmware for a laptop to auto start it but I prefer pressing the button myself. I have the Opus configured to output 19 volts which is what my HP laptop expects and this also powers my monitor which can handle up to 24 volts. the 5 volt rail powers two USB hubs and will power a USB DVD drive when I get round to it.
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
rodweb is offline   Reply With Quote
Old 03-16-2009, 08:09 PM   #6
thewizard's Avatar
thewizard is on a distinguished road
You want to stay away from any laptop power supplies that have an adjustable voltage slider or switch. Normally if they accidentally get moved to a lower voltage the laptop simply will not detect it presence and won't charge, however moving the other way and feeding it too much voltage can result in disaster. Mine is hard wired but it is a fixed voltage specific to my laptop. (19VDC).
thewizard is offline   Reply With Quote
Old 03-16-2009, 09:08 PM   #7
joey7415963 is an unknown quantity at this point
Also I tried the same power supply, and it wouldn't work with my HP laptop, really don't know why and before anyone says it, it was the right voltage/current etc!
joey7415963 is offline   Reply With Quote
Old 03-17-2009, 09:22 AM   #8
Thanks for the replys guys.......I bought the power adapter today to test, my laptop expects an input of 18.5v.....so I just set it to 18v and all is working fine. I can get around the switch moving voltages by covering over the switch, so that should stop it moving accidently......also this unit has a built in 5v USB charger port with lots of different tips.....so I can also power the USB hub from this.
I went on a 2 hour drive for work and I had my laptop turned on and powered by the adapter - there was very little heat coming from it....it was just warm. I'll keep testing it to see how it holds up but so far so good
Old 09-20-2009, 01:01 PM   #9
jaguar999 is an unknown quantity at this point
Hi,
I have bought a similar product here in Bangalore, India.
It cost me 750INR (~15USD). It does not have a 5Volt option.
Its working fine but the only problem is that i am getting a lot of noise in the sound when i use this. I connected this to the Cigarette lighter power supply.
Can some one help. How to get rid of the noise.
Regards
Gaurav
jaguar999 is offline   Reply With Quote
Old 09-20-2009, 01:23 PM   #10
justchat_1 will become famous soon enough
Quote: Originally Posted by jaguar999 View Post
Hi,
Regards
Gaurav
Are you comfortable putting a noise filter inline with the unit? Ideally you would need a cigarette lighter extension cable with built in noise filter but I don't think they make them.
openMobile - An open source C# Front End
- Currently Recruiting Developers -
Available for download on sourceforge
justchat_1 is offline   Reply With Quote
Old 09-20-2009, 01:56 PM   #11
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
http://www.mp3car.com/vbulletin/car-...ing-guide.html
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-20-2009, 03:51 PM   #12
Thanks DarquePervert and justchat_1 for such a quick reply.
I will read the suggested thread.
If i cud get away with the noise, this China product will be worth the money
Old 09-20-2009, 05:16 PM   #13
moelsaied88 is an unknown quantity at this point
i have a question along the same line. I am using something very similar for my laptop setup, and for the audio i use a gli to clean the sound, but im also getting interference over the video. i have a lilliput 619 and when i run the laptop off battery the signal is perfect but when i have the power connected theres some bad interference. any suggestions? thanks in advance
moelsaied88 is offline   Reply With Quote
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 24 06-25-2009 07:31 AM
Xterra; Dell Laptop, mounted t/s install TTUStephen Show off your project 3 02-26-2009 05:03 PM
How can I use a laptop as a carpc? turbocad6 Laptops, Netbooks, Tablets, UMPCs, etc. 0 07-11-2007 01:55 AM
