Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc. > How to Power a Laptop
Old 03-29-2009, 07:25 AM   #1
funkd is an unknown quantity at this point
Laptop power questions
1. Let say, I have install a 300w inverter directly to my battery (with relay), and plug in a laptop AC adapter (70w), will it damage my power supply/laptop?
2. Is it recommended to connect a powerboard to the inverter to power other electrical goods such as, powered usb hub, monitor etc?
The inverter: http://jaycar.com.au/productView.asp...T&SUBCATID=680
I appreciate the help!
funkd is offline   Reply With Quote
Old 03-29-2009, 03:21 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
No. Using an inverter that is 300 watts to power something that needs only 70 watts will not hurt the 70 watt device. The inverter will only supply what is needed by the devices plugged in. It will not "push" 300 watts through it.
I don't know what you mean by 'powerboard'. Do you mean a power strip?
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 03-30-2009, 04:24 AM   #3
Awesome, thanks for that!
And yes, power strip would I be able to use one - is it recommended?
Thanks for you help!
Old 03-31-2009, 04:29 AM   #4
NSFW is an unknown quantity at this point
I'm using an inverter for my laptop CarPC, I think it's only 100 watts but that's plenty. I am using two passive (powered by the laptop) USB hubs, so the laptop's power supply just plugs directly into the inverter.
I am looking for a way to use a powered USB hub, but I'd rather do that without running more 120v wiring through my car. You could use a power strip but it seems like a waste of space, and a waste of power. On the other hand I am still looking for 12v power for a bigger USB hub so I haven't got a much better idea...
My touchscreen uses 12v power, so it's powered from (what used to be) the cigarette lighter circuit.
NSFW is offline   Reply With Quote
Old 04-01-2009, 11:53 PM   #5
merlin12volt's Avatar
merlin12volt is an unknown quantity at this point
someone correct me if I am wrong
Since your powered hub does nothing more then supply 5vdc to one pin and ground to the other, it would stand to reason that you could get one of these http://www.dealextreme.com/details.dx/sku.688 a usb to usb cable and a 12volt cigarette adapter to hardwire since I know you said that the screen uses the cigarette lighter.
There is another way to go about this by building a simple voltage regulator circuit, but odds are, if you are asking this question, you probably either know nothing about that or aren't interested.
Either way hope this helps.
merlin12volt is offline   Reply With Quote
Old 04-02-2009, 02:12 AM   #6
Actually I bought something very similar, cracked it open to get rid of the cigarette lighter plug, soldered in some wires, spliced those into my cigarette lighter circuit... and had no luck. The USB hub just stopped working when I connected my hacked power supply.
I probably screwed something up. But at that point I wanted my car back (was working on another under-dash project at the same time) so I just went back to my passive 4-port hub rather than trying to diagnose what went wrong with my hacked power supply.
Someone here was working on a purpose-built USB power supply but I lost track of that thread. Time to search...
Old 04-02-2009, 02:38 AM   #7
Found two, but neither is what I was looking for...
http://store.mp3car.com/Automotive_P..._p/pwr-022.htm
http://store.mp3car.com/Carnetix_CNX..._p/pwr-016.htm
I am pretty sure there's a third one...
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 24 06-25-2009 07:31 AM
2007 Ford Fusion Carputer (version 2.0) FusionFanatic Show off your project 43 04-20-2009 05:56 PM
Auto Power on/off using laptop stevey500 General Hardware Discussion 6 12-11-2008 02:30 PM
USB power up and power down questions! HiJackZX1 General Hardware Discussion 1 03-03-2008 11:31 PM
Cigarette Socket Power Questions jfeinman Newbie 8 02-26-2008 08:40 AM
