Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc. > How to Power a Laptop
Old 04-26-2009, 08:34 PM   #1
soopahfly is an unknown quantity at this point
Laptop power up idea.
I'm no wiring guru, so you guys may be able to work out the best way to plumb this in.
I think it should be straight forward enough to make a basic startup/shutdown controller for a laptop, with minimal soldering.
To power up, you would solder two wires to the power on switch. This is where the wiring chaps would come in. How would you wire this up to a relay to only provide a momentary connection between the two points?
Once this bit has been figured out, follow this post to fool your laptop into thinking there is a UPS present to activate the shutdown.
http://www.mp3car.com/vbulletin/383433-post21.html
Here is the thing. In your windows power settings, you can set the behaviour of the power switch once you've booted into windows. If you tell it to "Do Nothing" when the power button is pressed in windows, then everything should work.
Does this sound OK, or have I lost the plot at 01:33 on a Monday morning?
soopahfly is offline   Reply With Quote
Old 04-27-2009, 04:38 AM   #2
CLUCK is an unknown quantity at this point
Setting windows to 'do nothing' when the power button is pressed will not help.
The hardware setting will power down the PC after abut 5 seconds, then up, then down...
Here is the diagram to build the circuit. I made this exactly and it works 100% on my laptop.
The capacitor allows the coil of the relay to be energized until the capacitor stores a charge, thus de-energizing the coil. The resistor bleeds off the charge of the capacitor when positive voltage is removed from the other side of the coil. You can increase the output time by simply changing the value of the capacitor. This one will give you about a 1/2 second output.
http://www.the12volt.com/relays/page5.asp
Connecting to laptop switch will require you to open it up and locate the switch contacts.
Use your multimeter to find which 2 pins on the switch have continuity when the switch is pressed. These are the 2 you need to connect to.
Use the lines from point 87 and 30 on the relay.
Good luck
CLUCK is offline   Reply With Quote
Old 04-27-2009, 04:46 AM   #3
Not wanting to poo poo your idea, but are you sure those relay terminals are correct?
Surely if I bridge the power switch buttons with 87 and 30, then I'm going to be putting 12v across the momentary switch.
As this normally needs no voltage, just to complete the circuit wouldn't this be better to make an earth contact instead?
Old 04-27-2009, 06:32 AM   #4
Yep it's all OK.
12v power runs across 86 & 85, which charge the coil that then creates continuity across 30 & 87, which has NO voltage.
The diagram does indicate voltage on the line but you just don't need to put any on it for your application.
You get a 1/2 second of continuity across 30 & 87, when 85 & 86 have 12V.
I'll build you one if you pay the right price but where is the challenge for you.
Old 04-27-2009, 06:32 AM   #5
chrisngrod is an unknown quantity at this point
Have you ever noticed that with any computer holding down the power switch will cause the motherboard to cut the power off completely? Like when your computer freezes and you have to do a hard reboot?
Anyways apparently this setup has been proven by more than just Cluck. I like the diagram he posted up btw.
http://www.mp3car.com/vbulletin/user...rn-module.html
I would recommend using the USB feature posted there.
chrisngrod is offline   Reply With Quote
Old 04-27-2009, 06:34 AM   #6
I do like a good challenge!
The only part of this project I'm not looking forward to is fabricating a screen in the dash!
Old 04-27-2009, 06:38 AM   #7
Have you got a shutdown and AMP turn on delay sorted yet ?
These were painful for me.
What car?
Where you located ?
Old 04-27-2009, 06:43 AM   #8
It's going to go in a 1994 Toyota soarer.
The power off should be straight forward enough as long as shoving 5v to Pin 8 on the RS232 port fools the computer into thinking there is a UPS connected.
Remove 5v, computer initiates shut-down. Where this thread uses an inverter and regular PC power supply to give out 5v, I'm going to use a second 12v socket running a usb charger plug to give me the 5v. I'm cheating and I'm still going to keep the headunit, so this will take care of remote power on for the amplifier. I've got some component speakers, and a Vibe 10" subwoofer to power.
I've got plans to build a couple of "Hot Plates" in the boot, so that I can connect directly onto one and have a switched 12v source, or connect to the other and have constant 12v, but not worked out how I'm going to mount it all yet.
I'm in Sheffield.
Old 04-27-2009, 07:06 AM   #9
Sheffield hey, my stomping ground for about 8 months in 2004. Had to get back down under for some sunlight.
Car and plans sound sweet.
Old 05-10-2009, 06:11 AM   #10
blackcar is on a distinguished road
instead of wiring it to s switch and adding a relay to make it "momentary", why not just wire it to a "monetary" switch?
then you can skip the relay, no?
blackcar is offline   Reply With Quote
Old 05-10-2009, 07:11 PM   #11
FirebirdPheonix's Avatar
FirebirdPheonix is an unknown quantity at this point
Wake on lan (WOL)
Ive seen a few people on other threads post about wake on lan. Some people rigged relays that would fake the computer to think there was incoming data and would wake up the computer.
FirebirdPheonix is offline   Reply With Quote
Old 05-10-2009, 08:41 PM   #12
If you have a switch you have to press it each time you want the laptop to start.
My setup is automated, it comes on when I turn the ignition key.
Old 05-10-2009, 11:05 PM   #13
walky_talky20 is on a distinguished road
If you are running a laptop, for shutdown you can just set the power options to be "When running on battery" - "System Hibernate" after 1 min. That should take care of shutdown, as long as your battery will last 2 minutes or so (1 minute for the timeout, 1 minute to hibernate). Momentary relay for power on would handle startup and you're all set.
Edit: Just found this. I knew someone here was selling a ready-made laptop startup controller.
** Denotes an "in car" post
In-Car posts made from passenger seat - Be safe, Don't Post and Drive.
walky_talky20 is offline   Reply With Quote
Old 07-17-2009, 10:12 AM   #14
VENDOR - XoByte
M3Sharif's Avatar
M3Sharif is an unknown quantity at this point
miniSpark StartUp/ShutDown Controller w WOL
Hi,
I work for a start-up company called XoByte that has a prototype PC StartUp/ShutDown Controller called miniSpark. It utilizes Ethernet WOL Magic Packets to wake (or turn on your PC). It also has the ability to command your PC to shut-down or Hibernate.
I posted a feature list and link to a demo video in the "New Products" Thread if anyone's interested.
http://www.mp3car.com/vbulletin/vend...oller-wol.html
M3Sharif is offline   Reply With Quote
Old 07-23-2009, 09:07 AM   #15
Hekim is an unknown quantity at this point
How much $ ?
Hekim is offline   Reply With Quote
Review: M4-ATX 250 Watt Intelligent Power Supply Bugbyte The Review Palace 10 11-17-2009 10:32 AM
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 24 06-25-2009 07:31 AM
What Power Supply for Laptop Install? D3LTR33 Newbie 6 08-04-2008 07:41 AM
Laptop and Power Cord Idea hoodlum Laptops, Netbooks, Tablets, UMPCs, etc. 6 01-08-2007 10:48 AM
