Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc. > How to Power a Laptop
Old 05-24-2009, 09:02 PM   #1
singh763173 is an unknown quantity at this point
Laptop On When Key in ignition
Hi all, ive been looking around at the other threads but couldnt make sense of it all :|
I have a Dell Inspiron 1501 which i want to use with a Xenarc MDT X700 monitor.
What i want to know is, how can i get the laptop to start when the keys in the ignition? Im sure a wire needs to be fed from the battery etc.
I use a amp which turns on when key in ignition so im sure it runs similar to that, can the amp be used to aid this?
Also do i need to strip the wiring from the Plug (UK Plug) and use that in the wiring?
Please help
Many thanks
Ajay Singh
singh763173 is offline   Reply With Quote
Old 05-24-2009, 09:12 PM   #2
Powering a laptop on key in ignition
Hi all
Im a computer techy so know my way around hardware and software but this is a new venture for me... please help
I have a dell inspiron 1501 which i want to be turned on when the key is in ignition and gone to sleep when the keys out of ignition (or summin where the battery isnt used or drained when not in use).
I dont want to use a power invertor because that just looks ugly in my honest opinion ( http://yourgadgetstore.com/images/ca...r_inverter.jpg )
I have a subwoofer in my boot which is connected to an amp. the amp switches on when the key is in ignition it has a line from the battery, a remote and a ground. Can this be used to aid the power to the laptop?
Please help
Many thanks in advance
Ajay Singh
Old 05-24-2009, 10:45 PM   #3
rodweb is an unknown quantity at this point
Pretty sure the carnetix has a mode that allows you to turn a laptop on.
Have a search though, you need to solder some wires onto the switch of your laptop. I soldered wires from the laptop power switch onto the modem phone line connectors on the laptop and I plug my start button into the phone connector. The carnetix can be set up to "press" the switch the same way.
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
rodweb is offline   Reply With Quote
Old 05-24-2009, 11:16 PM   #4
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
The answer to that question is WAY too easily available for you to get someone to type an answer. Search it and you'll find your result in about 2 minutes.
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 05-25-2009, 01:38 AM   #5
drewbp is an unknown quantity at this point
Auto laptop turn on module by W3bmast3r. ShutControl for turn off.
drewbp is offline   Reply With Quote
Old 05-25-2009, 05:58 AM   #6
W3bmast3r? Is that software? i was hoping to use Centrafuse... is that still possible?
thanks for both your replys
Old 05-25-2009, 06:05 AM   #7
sorry for my ignorance, ive found that ur talking about a relay box.
how would i implement this? my main issue is wiring.
Old 05-25-2009, 06:09 AM   #8
are you talking about the carnetix psu?
thanks
Old 05-25-2009, 06:15 AM   #9
thanks
Yup. I use an Opus, butr I think Carnetix might be easier.
RodW
Old 05-25-2009, 06:19 AM   #10
oh ok. would the p1900 work? and is it easy to wire up?
from what i can see, id need to make my own power cable from the psu to the laptop.
is this how this person has done there setup.. http://www.avbrand.com/projects/carpc/installation/
id like to do summin similair but without that ugly invertor
thanks
Old 05-25-2009, 08:19 PM   #11
bump!
anyone? please
Old 05-25-2009, 08:27 PM   #12
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Threads merged, please do not start the same threads in more than one forum.
Enforcer is offline   Reply With Quote
Old 05-25-2009, 09:13 PM   #13
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
spooooons
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 05-25-2009, 09:29 PM   #14
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
Quote: Originally Posted by Curiosity View Post
spooooons
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 05-26-2009, 04:45 AM   #15
sorry mate... wasnt sure where to post it so posted it twice. Thanks anyway!
can anyone help with regards to wiring please? :/
Remote control laptop start up vqstatesman Laptops, Netbooks, Tablets, UMPCs, etc. 1 09-20-2009 09:57 AM
Xterra; dell laptop, mounted t/s, GPS TTUStephen Show off your project 0 02-25-2009 02:40 PM
Laptop Power On - No Ignition Power musters Laptops, Netbooks, Tablets, UMPCs, etc. 4 10-19-2007 12:06 AM
