Go Back   MP3Car.com > Mp3Car Technical > GPS > iGuidance GPS Software
Old 08-12-2008, 10:38 AM   #1
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
Iguidance / GPS question - Problems Locking?
Sorry for the crappy phone cam pic..
Ok, a lot of times it takes FOREVER for Iguidance / my GPS to lock onto some satellites.. When I go into GPS info I often times see this:
The gray lines on the bottom.. Those are the satellites the GPS sees, right? Sometimes it will stay gray for 10-30 minutes and sometimes another gray one will pop up while another one goes away etc.. What does this have to do with? My GPS? Comport settings? Iguidance?
Thanks!
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 08-12-2008, 10:52 AM   #2
dhantiflag's Avatar
dhantiflag is an unknown quantity at this point
what gps reciever?
dhantiflag is offline   Reply With Quote
Old 08-12-2008, 10:53 AM   #3
Raw Wave
tbird2340's Avatar
Rikaline 6010 GPS
Old 08-12-2008, 12:23 PM   #4
Marvin Hlavac's Avatar
Marvin Hlavac will become famous soon enough
Where in your car is the Rikaline 6010 located? Does it have good view of the sky in many directions? Is it possible the car's windows have too much metallic content in the tint, thus making weak satellite signals even weaker inside your vehicle? How many green bars do you usually get, when you get them at all?
Marvin Hlavac is offline   Reply With Quote
Old 08-12-2008, 03:28 PM   #5
Raw Wave
tbird2340's Avatar
I have it just sitting on my dash in the upper right corner.. My front window doesn't have any tint on it and it's got a pretty good view of the sky.. I guess I can try holding it out the window and seeing if it locks faster.
Usually 3-5 green bars when it does get them..
Thanks for the help.
Old 08-12-2008, 05:08 PM   #6
3 to 5 is bad. Yes, hold it out the window of your car to see if you get substantially better results. No wonder it takes forever to acquire a fix, if the reception inside your car is so poor
If you cannot find a place inside you car where the unit performs better, then you may consider buying a more sensitive unit (such as the popular BU-353).
Old 08-13-2008, 08:10 AM   #7
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
I was having similar problems with a BU-353 until I moved it to a better position. I now get lock-on in around a minute or 2 with 8 sats.
Machinehead is offline   Reply With Quote
Old 12-07-2008, 08:53 PM   #8
Raw Wave
tbird2340's Avatar
What is a better position though? I have it sitting on my dash with a clear view out the front window.. Where does everyone put theirs generally?
I was about to buy a BU-353 but then read your post saying you have the same problem with a BU-353...
Old 12-07-2008, 09:00 PM   #9
nobb will become famous soon enoughnobb will become famous soon enough
Do you have the problem after a fresh boot, or only after hibernation?
If its only with hibernation, then Ive been having the same problem after switching from a Via m10k motherboard to a Jetway j7f2we2g. Might be able to fix it with devcon.
http://www.mp3car.com/vbulletin/faq-...de-devcon.html
nobb is offline   Reply With Quote
Old 12-07-2008, 09:11 PM   #10
Raw Wave
tbird2340's Avatar
I'll double check tomorrow but I'm 99% it's both fresh boot or hibernation.. Thing is, it's intermittent.. Sometimes it will take 20 minutes to get a lock, sometimes 1 minute, sometimes never and the GPS is in the same place every time..
Old 12-08-2008, 08:36 AM   #11
Raw Wave
tbird2340's Avatar
Well I did a fresh reboot this morning and it took 3 1/2 minutes to get a lock and bounced between 4-9 satellites being locked so that isn't too bad.. Maybe it is hibernation that is the issue but I have been using devcon...
I'll see what happens on the way home from work (coming out of hibernation).
Old 12-08-2008, 09:07 AM   #12
That's approximately where I have it, now your windshield could be causing interference. The best way to check that is to put the receiver outside your vehicle to see if that improves lock-on time.
There's also the possibility that you're in a spot with bad satellite coverage. I don't believe those satellites are geosynchronous, so there is the possibility that's the case.
Centrafuse Problems - GPS, Voice Recognition, Freezing kevlar Centrafuse 2 08-13-2007 04:18 PM
How to set iguidance as my gps in my road runner. shinjetko Road Runner 10 05-22-2006 05:32 PM
iGuidance and gps question Yevmeister GPS 4 03-13-2006 11:51 PM
Motorcycle GPS question.. JackMan GPS 7 01-16-2006 02:17 AM
