Go Back   MP3Car.com > Mp3Car Technical > GPS > iGuidance GPS Software
Old 05-12-2009, 12:49 PM   #1
WuNgUn's Avatar
WuNgUn is on a distinguished road
iGuidance "Can't install Windows Service"
Anyone get this in Vista?? Never seen it before, and actually, never had a problem before this install...
What's the deal?
TIA
WuNgUn is offline   Reply With Quote
Old 05-12-2009, 04:29 PM   #2
WuNgUn's Avatar
Anyone? I gotta have nav!!
Old 05-12-2009, 05:08 PM   #3
Injector's Avatar
Injector is on a distinguished road
do yourself a favor, loose vista
Injector is offline   Reply With Quote
Old 05-12-2009, 06:39 PM   #4
WuNgUn's Avatar
I wish I could!!
XP will not install on my HDD...gets a blue screen before it shows me the HDD's...
It's SATA, so I nLited the drivers into setup...no go.
Mounted the HDD in my desktop, and presto...installs!
Plug it back ito the car, and blue-screen...
Been thru the BIOS...
Been thru drivers...
Been thru different install disks...
Been thru a zillion partition utilities...
Wiped it clean...
FixMBR
FixBOOT
Ever since I installed W7, XP will not go back on that drive
Old 05-12-2009, 07:00 PM   #5
WuNgUn's Avatar
Running iGO now...
Old 05-12-2009, 07:31 PM   #6
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Which version of iGuidance?
And as far as loading xp... have you tried Killdisk? Zero out the drive completely? It did run XP once upon a time right?
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 05-12-2009, 07:40 PM   #7
Injector's Avatar
i was just about to mention that, as well as using a live bart pe cd to install windows from a live enviroment
Old 05-12-2009, 10:34 PM   #8
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
I've been running iGuidance on vista x64 for some time without issue. If your PC is blue screening at all you have serious issues with the OS layer, which should be fixed before attempting application installs.
blk02si is offline   Reply With Quote
Old 05-13-2009, 01:39 AM   #9
Tidder's Avatar
Are you running the install of iguidance as administrator? (Right click, run as admin or something)
Tidder
Try RevFE
Best Quote EVER!!
Old 05-13-2009, 04:47 PM   #10
WuNgUn's Avatar
Version 4
KillDisk huh? 500GB worth of zeroing...what'll that take, 3 or 4 days? lol
I'll keep it in mind...
So far Vista is working okay and iGO is working okay. Only issue I'm having is with the CF TPMS messing up CF. The 2.0.0.8 version runs a little better, but it causes CF to hang when resuming...
The latest version causes CF to become unresponsive at times.
What bothers me is, I can install XP to the same 1/2TB drive from my desktop PC perfectly fine!! Only when the drive is connected to the MS-7191 does it behave like this...
Damn ATI chipset!
Old 05-13-2009, 04:48 PM   #11
WuNgUn's Avatar
I think I tried a PE CD on it before, and it wouldn't start either! lol
Old 05-13-2009, 04:49 PM   #12
WuNgUn's Avatar
Blue Screen is during XP install...not when working from the OS.
Old 05-13-2009, 07:33 PM   #13
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Rather than KillDisk I have a suggestion that may help your XP install experience and take far less time.
Install XP as normal, but when it comes to the point in the install where you format the HDD, do a FULL format.
When you do a quick format, the disk is not checked for errors and bad clusters aren't noted and written around. A quick format only creates a partition table and nothing more.
The full format does the actual disk check and will work around unusable areas of the HDD.
Now, if you DID do a full format, what is preventing you from simply purchasing another HDD for the CarPC and/or the OS? HDDs are cheap these days.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 05-13-2009, 10:26 PM   #14
Injector's Avatar
i'm not familiar with your setup but i know some dell pcs doe the same thing, when installing xp when the setup starts to detect drives it blue screens because in the bios raid was turned on even tho not raid was configured, does your mobo have raid built in.
Old 05-14-2009, 08:15 AM   #15
WuNgUn's Avatar
It doesn't make it that far...blue screens when it tries to detect the HDD's...
Windows XP LAN Boot install – no floppy or CD-ROM Zip-Lock Software & Software Development 29 10-20-2008 01:29 AM
How to install Media Center on Windows XP Home Defiler XP MCE 3 12-23-2007 08:39 AM
Do I need to install all states for my iguidance ? shinjetko Newbie 11 05-25-2006 12:58 AM
install windows 95 in 4.47mb churnopol Software & Software Development 3 09-30-2003 07:36 AM
windows install Stine161 Software & Software Development 2 09-21-2002 11:43 AM
