Go Back   MP3Car.com > Mp3Car Technical > GPS > iGuidance GPS Software
Old 10-23-2009, 01:03 PM   #1
hpric is on a distinguished road
Iguidance Volume issues
I'm hoping someone could help me out here. I have the volume in iguidance V4 set all the way down to where it only shows one bar and its still extremely loud. I'm not sure what is going on here but it wasn't doing this before in my old pc. I'm using an external soundblaster card but I don't think that has anything to do with it. Anyone have any ideas?
I've tried playing around with the volume line in RR config but still the same and its driving me nucking futts
hpric is offline   Reply With Quote
Old 10-26-2009, 05:49 PM   #2
Geez no one has any idea? The files sound fine on my home pc but in the car they come through at full blast
Old 11-02-2009, 03:22 PM   #3
Keem is on a distinguished road
Are you using it in RR? If so there is a seperate setting for volume in RR.ini (editable in RRConfig)
Keem is offline   Reply With Quote
Old 11-02-2009, 03:34 PM   #4
it happens in both cases with RR and stand along, However if I go to the iguidance folder and actually click on one of the sound files it comes through perfectly. Bur when the program is running the sound is amplified to a point where I have to mute it altogether. If I have my music playing loud then the iguidance volume doesn't come through as loud as when there is no music playing
Old 11-02-2009, 03:36 PM   #5
Maheriano will become famous soon enoughMaheriano will become famous soon enough
Happens to me sometimes too, you got to play with all the volumes:
Winamp
Windows
iGuidance
You probably have the Winamp volume way down meaning you have to turn up the volume in Windows (RoadRunner) to nearly full blast. Then even that one little bar in iGuidance is going to be loud as hell.
Try decreasing the Windows volume and increasing the Winamp volume by actually opening Winamp and adjusting the volume in its GUI. That does it for me.
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 11-02-2009, 03:37 PM   #6
I have and still can't figure it out. I've even uninstalled and reinstalled IG just to make sure and stil
Old 11-03-2009, 11:43 AM   #7
What? Dude, if you turn your Windows volume all the way down to the first notch, there's no way it's going to still be blasting the iGuidance voice. How can it? Can you open iGuidance on its own inside Windows with the volume all the way down and see what it does?
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
Old 11-03-2009, 12:57 PM   #8
That is exactly what happens. The only time the volume level is normal is when I close everything and actually click on the sound file from within the iGuidance sound folder, any other time the volume is through the roof.
Old 11-04-2009, 12:55 AM   #9
What are your mixer settings like?
Old 11-04-2009, 08:30 AM   #10
Nope, I think I've tried everything, (pc volume, winamp volume, soundcard mixer volume and iGuidance volume all the way down and still the voice prompts are loud. The only time it comes through a tad lower is when I have music playing at a loud level and I get nice normal level when I manually click the sound file within the iguidance sound folder
Old 11-05-2009, 11:58 AM   #11
And this is happening when running iGuidance outside Road Runner?
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
Old 11-05-2009, 07:37 PM   #12
sxott is on a distinguished road
Sorry but that doesn't make any sense. You must be confused about something. No matter what you do to volume if the system volume is low nothing loud can come through. Therefore the only possible answer is that it is changing the system volume somehow.
My Install
sxott is offline   Reply With Quote
Old 11-10-2009, 12:17 PM   #13
and yet that is exactly whats happening. The only time I can control the Iguidance volume is when I click on the actual sound file. PC volume down, winamp volume down, Iguidance volume down to one bar still = Super loud iguidance voice prompts.
Old 11-10-2009, 05:37 PM   #14
Are you using SPDIF? This will ignore your Windows volume slider since it's digital and it's either on or off.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
Old 11-10-2009, 06:09 PM   #15
I'm using this card and wouldn't the SPDIf affect all volume not just Iguidance?
http://us.creative.com/products/prod...=17751&listby=
iGMon - Solution for integration between iGuidance and Road Runner (I hope) b8bboi RR Plugins 570 11-05-2009 03:49 PM
Windows has multiple levels of volume controls. How to set properly? GreenMachine Car Audio 12 07-31-2007 02:05 PM
Road Runner Volume Issues ! ! ! rewindnottm Road Runner 8 03-20-2007 04:38 AM
iGuidance file issues. seanz0rz GPS 9 02-25-2006 12:59 PM
iGuidance and Frodoplayer display issues? wallaceacura Software & Software Development 11 07-16-2005 02:09 AM
