Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Mp3Car Store Product Support Exchange > Infill T3
Old 04-11-2007, 01:07 AM   #1
irdrive is an unknown quantity at this point
Infill T3 GPS not working
I just installed Infill T3 in my car with StreetDeck. The computer is not detecting the GPS on Com 1. Can someone from mp3car.com help me?
I ran Sirf Info program and even before StreetDeck is run, the computer is saying "No Device" on COM 1. I've deleted the driver many times and tried deleting the entire COM 1 port many times too.
Also, before I bought the unit, I specifically asked mp3car.com if the GPS was Sirf III, and they said yes. But according to the model# on the bottom of the GPS antenna (X-150), it seems to be Sirf II.
irdrive is offline   Reply With Quote
Old 04-11-2007, 07:23 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
You really should be posting these issues in the Bug Reports forum.
Are you certain the GPS is connected to COM1? Check in the Windoze Device Manager.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 04-11-2007, 02:39 PM   #3
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
When did you buy this unit and from where?
If you boought this unit as hardware only or off of the ebay auction, please do not expect any form of support from the store as this was part of the terms of the sale.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 04-11-2007, 02:49 PM   #4
StreetDeck Staff
mpacesaints is an unknown quantity at this point
The T3 has had problems in the past on detection of the GPS (something to do with the 9 pin mini din coonection). Manually put it on com1 and save the settings. You should be fine.
mpacesaints is offline   Reply With Quote
Old 04-11-2007, 04:00 PM   #5
Purchased from store.mp3car.com.
Order date: February 14, 2007
Order#: 19256
Received on February 21, 2007
Didn't have time to install until recently.
Infill T3 with Infill Station
2007 Hyundai Sonata
Old 04-11-2007, 04:06 PM   #6
There's only one PS/2 connector that comes out of the unit, with "GPS" sticker on it. The window itself is not detecting the unit. Device manager shows COM 1-9. I've uninstalled Sprint Novatel drivers and the program. Thinking maybe StreetDeck was confusing with Sprint Novatel drivers as it uses three COM ports, one which is for GPS. So I uninstalled every COM ports, rebooted few times, and left only with COM 1. Still no device found.
2007 Hyundai Sonata
Old 04-11-2007, 04:32 PM   #7
_
Have you tried what mpacesaints suggested? Manually setting it?
Please let us know!
Jan Bennett
Old 04-11-2007, 04:40 PM   #8
What do you mean by manually putting on COM1? Do you mean opening the unit and making a direct connection to the board?
Or manually manipulating the settings from the windows? But GPSinfo program should be detecting the device on COM1. Currently the Windows device manager only shows COM 1. Do I need to change the port settings like baud rate?
2007 Hyundai Sonata
Old 04-11-2007, 09:14 PM   #9
Yevmeister's Avatar
Yevmeister is on a distinguished road
go to device manager, see the COM port aiisgend to your gps device, you cann keep it on 1 but i would put it on 2 or 3, then in you map software GPS setting select COM you have assigned in device manager, and baud rate of 4800 then you should not have any problems
Yev
R. T. F. M
Yevmeister is offline   Reply With Quote
Old 04-12-2007, 05:24 PM   #10
StreetDeck Staff
Old 04-13-2007, 02:34 AM   #11
Yev
Tried it but the Window itself was not detecting the GPS device. I removed the unit from the dash and unhooked both USB line to Blue tooth radio and Sprint USB antenna. I rebooted few times with nothing attached. Then attached the GPS antenna. Finally, Windows detected it, as well as StreetDeck. Thank you all for the support!
2007 Hyundai Sonata
Infill T3 with Streetdeck irdrive StreetDeck 8 04-09-2007 12:11 PM
infill t3 isamfarina Centrafuse 1 04-09-2007 10:46 AM
Infill T3 in the UK: Some questions discopanda Newbie 1 10-14-2006 07:50 AM
Infill T3 with Streetdeck wiring terrygold StreetDeck 5 09-24-2006 02:40 PM
MapMonkey Gps working but not on map BOND007BE Map Monkey 8 03-11-2005 10:02 AM
